Standard Switches (Double Break) Series 83 106 / 83 109 / 83 112 / 83 154
Types
General specifications
Layout
83 106 0
- The NO and NC circuits must both be of
the same polarity.
Components
Material
- Case : polyamide (83 106 to 83 112)
- Case : Diallyl-Phthalate (83 154)
- Contacts : nickel silver
Actuators
- passivated mild steel
- roller : nylon
- adjustable screws : self-retaining
- plates : passivated mild steel (zinc)
Note : Fixing holes for these switches
have metal ferrules.
Approvals: UL - cUL
Features
Standard
Electrical characteristics
Nominal c
Nominal a
Thermal
Current rating at 250 V
A
A
10
17.5
N (oz.)
N (oz.)
N (oz.)
mm (in.)
mm (in.)
mm (in.)
mm (in.)
°C (°C)
Operations
mm (in.)
g (oz.)
4 (14.1)
1 (3.5)
20 (70.5)
12.75 (.5)
11.45+0.2 -0.25(11.45+0.2 -0.25)
0.5 ±0.2 (0.02 ±.008)
0.7 (.28)
-20 +85 (-4 +185)
107
0.4 x 2
8
Mechanical characteristics
Operating force - max.
Release force - min.
Permitted overtravel force - max.
Maximum rest position
Tripping point
Differential travel
Overtravel - min.
Ambient operating temperature
Mechanical durability
Contact gap
Weight
Contact type
C (Form C) SPDT
B (Form B) SPNC
A (Form A) SPNO
Operating curve
Number of
operations
Connections
Resistive circuit:
Inductive circuit
L = 5 ms
R
cos ϕ = 0,8
Mechanical life
Rating in
Amps
83 154
C
Actuators and mounting positions
Part numbers for standard actuators
A 70 500 888
Actuators-Length
mm (in.)
Flat R49 (1.92)
Pre-travel - max.
Differential travel
Total travel max.
N (oz.)
N (oz.)
mm (in.)
mm (in.)
mm (in.)
1.2 (4.2)
0.25 (.9)
6.2 (.24)
2.1 ±0.9 (.083
7.5 (.3)
±.035
Except where otherwise indicated, the flat and roller actuators are mounted as
shown in the dimensional drawings (mounted on the left).
Assemblies
Other information
For other forces, actuators, connections and temperatures,
please consult us.
Normally stocked items
Catalog products produced
to order
Products and specifications subject to change without notice.
Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com
3/20
1
83 109 0
83 112 0
83 106 4
83 106 7
83 111 0
83 111 5
83 154 0
Face terminals
Enclosed screws
Bistable, 2
actuator positions
Bistable, 2 push
button positions
Base mounting
by screws
Base mounting
by clips
Magnetic blow-out
switch
5
10
17.5
10
17.5
10
17.5
10
17.5
10
17.5
10
17.5
17.5
4 (14.1)
1 (3.5)
20 (70.5)
12.75 (.5)
11.45+0.2 -0.25 (.45+.008)
0.5 ±0.2 (.02 ±.008)
0.7 (.29)
-20 +85 (-4 +185)
107
0.4 x 2 (.016 x .08)
8 (.3)
4 (14.1)
1 (3.5)
20 (70.5)
12.75 (.5)
0.7 (.29)
-20 +85 (-4 +185)
107
14.5 (.3)
0.45 (1.62)
2 (7.19)
4 (14.1)
1 (3.5)
20 (70.5)
4 (14.1)
1 (3.5)
20 (70.5)
4 (14.1)
1 (3.5)
20 (70.5)
0.7 (.29)
-20 +85 (-4 +185)
107
8 (.3)
0.65 ±0.25 (.02 ±.008)
0.7 (.29)
-40 +125 (-4 +257)
107
0.5 x 2 (.016 x .08)
11 (.3)
C
B
A
C
B
A
-20 +85 (-4 +185)
106
9 (.32)
-20 +85 (-4 +185)
106
8 (.3)
0.7 (.29)
-20 +85 (-4 +185)
107
8 (.3)
C
B
A
C
B
A
C
B
A
2
Contact type
C
C
3
2 solder
3 for 1/4˝ Quick Connects
1 screw
4
B 70 500 828
E 70 500 813
R49 (1.92)
Flat R47 (1.85)
Lever R26 (1.02)
R15.5 (.61)
1.2 (4.2)
0.25 (.9)
6.2 (.24)
2.1 ±0.9 (.083
8.4 (.33)
1.2 (4.2)
0.25 (.9)
6.2 (.24)
2.1 ±0.9 (.083
7.5 (.31)
2.8 (9.9)
0.45 (1.6)
3.2 (.125)
1.05 ±0.4 (.041
4.5 (.18)
4 (14.1)
0.8 (2.8)
1.45 (.057)
1.9 (.075)
±.035
Q 70 500 840
±.035
T 70 500 870
±.016
B9
21 416 364
Operation B9
Plate Mounting
Screw
4 (14.1)
1 (3.5)
1.5 (.059)
0.5 ±0,2 (.02 ±.008)
1.9 (.075)
Y 70 500 206
H 70 500 208
O2 70 500 218
Y Side plate
H Horizontal single-pole
mounting plate
O2 2-pole side
mounting plate
K2 2-pole vertical
mounting plate
To order, specify :
1
Switch Type
831060
831090
831120
831540
2
Contact Type
C
B
A
3
Connection
1
2
3
Example : 831810 C 2 • Ø
4
To order actuators separately, use the 8 digit P/N
Actuators
A
B
E
Q
5
T
B9
Ø = No actuator
Actuator Position
L - Left (Standard)
R - Right
3/21
3
Standard Switches
Dimensions
24
(.94)
2Ø 2.5± 0.1 (.1±.004)
Ø 7.5
(.3)
13 ± 0.1(.51±.004)
Ø2
L
–0
+ 0.01
+ 0.65
1.9 (.07)
8 (.31)
1
(.04)
10.5 (.41)
3)
.9
(1
7.8 (.31)
16.6 (.65)
(.1)
8± 0.1
(.31±.004)
12.8
(.5)
2.4
(.1)
2.4
OL=10.65 (.42)
4
(.16)
83 106 7
7.5
(.3)
83 106 4
6 (.24)
6.4 (.25)
83 106 - 83 109 - 83 154
Prof. 1.2
+0
Products
83 106 / 109 / 111
83 154
L
32 (1.26)
40 (1.57)
4.6
(.18)
4 (.16)
Ø8
(.31)
6
(.24)
16.6 (.65)
8.15 (.32)
7.6
(.30)
6.5
(.26)
8.8
(.35)
1.6
(.06)
23
(.91)
15.9 (.63)
83 112
83 111 5
2 (.08)
7.6
(.30)
83 111 0
13.6 (.54)
12.6 (.5)
7.2 (.28)
Ø 2 – 0.05 (.08 + .002 )
39.2 (1.54)
12.6 (.5)
46.4 (1.83)
13.6 (.54)
23 (.91)
mm (in)
36 (1.42)
Connections
6
(.24)
(.11)
8
(.315)
(Ø.125)
(Ø.06)
(Ø.06)
mm (in)
3/22
(.206)
(.32)
(.315)
(.032)
2.8 (.11)
(.25)
23.6 (.93)
6.2
(.24)
(.45)
8
(.315)
(.315)
8
(.315)
(.24)
3
2 (83 109)
0.8
(.032)
2 (83 106)
(.032)
1
Standard Switches
Actuators
Cross-section of actuators 1 x 6.4 mm (.039 x .252 in.)
A
R
Ø8 (.315)
x5 (.2)
47
(1
.85
93
(1.
49
F
3
(.12)
R
3
(.12)
6x (.24)
8.5 (.33)
12.2
(.48)
8
11.5
(.45)
M 2.5x12
7.5 (.3)
3)
1.9
9(
R4
E
(.32)
7.5
(.3)
B
Q
B9
T
6x8.5
(.24x.33)
19.4 (.76)
Ø8x5
(.315x.2)
(.315x.2)
R 26
.5
15
R .61)
(1.0
2)
(.24x.33)
3
mm (in.)
Assemblies
02
Y
K2
20 (.78)
52 (2.05)
20 (.787)
62 (2.44)
5.9 17.2 (.68)
(.23)
34.2
(1.35)
17.2 (.68)
4.6
(.18)
H
29.4 (1.16)
ép. 1.5 (.059)
M2
2.1 (.08)
Ø 4.2 (.165)
33 (1.30)
25 (.98)
Ø 4.2 (.165)
5.5
(.22)
13
(.51)
22.4 (.88)
4.7 7.3
(.185) (.29)
25 (.98)
Ø 4.2 (.165)
33 (1.30)
Unless indicated, the thickness of plates
is 1.5 mm (.059 in).
mm (in.)
3/23
很抱歉,暂时无法提供与“831060C3.QR”相匹配的价格&库存,您可以联系我们找货
