83160711
83160711
    CROUZET(高诺斯)
    检测开关 操作寿命1000万次 AC250V 6A
83160711 数据手册
| | SWITCHES.CROUZET.COM || 1 | | MICROSWITCHES | | 10/2019 MINIATURE MICROSWITCHES - POSITIVE BREAK 831607 › Coil spring snap-action mechanism with wiping contacts › Positive opening action according to IEC 60947-5-1 Annex K › Ratings from 10 mA 4 Vc to 6 A 250 Va › Very long life › Extended range of terminals › cURus approved › Choice of actuators: stainless steel or plastic Main specifications Positive break 831607 Standard Function I (changeover) I (changeover) I (changeover) I (changeover) I (changeover) I (changeover) R (normally closed) R (normally closed) R (normally closed) R (normally closed) R (normally closed) Electrical characteristics Positive opening action Connections W2 (solder) W3 (QC 6.3x0.8) W6 (QC 4.8x0.5) X1 (PCB, straight) X2 (PCB, rear) X3 (PCB, front) W2 (solder) W3 (QC 6.3x0.8) W6 (QC 4.8x0.5) X2 (PCB, rear) X3 (PCB, front) Dual-current (DORE) 83160702 83160704 83160706 83160796 83160786 ● ● ● ● ● ● 83160708 83160701 83160703 83160705 83160732 83160707 Rating nominal / 250 Va (A) Thermal current (Ith) (A) Mechanical characteristics Maximum operating force (N) Min. Release force (N) Minimum positive opening force (N) Max. Allowable overtravel force (N) Rest position max. (mm) Operating position (mm) Positive opening position (mm) Maximum differential travel (mm) Min. overtravel (mm) Ambient operating temperature (°C) Mechanical life (operations) Contact gap (mm) Weight (g) 83160794 83160797 ● ● ● 6 10 6* 10 4 1.5 18 200 15.7 14.8±0.3 13.5 0.3 1.3 -40 ➞ +85 107 1.2 7 4 1.5 18 200 15.7 14.8±0.3 13.5 0.3 1.3 -40 ➞ +85 107 1.2 7 Additional specifications - Case, Button: PBT GF (UL 94-V0 / GWFI 960 °C) - Cover: PC (UL 94-V0 / GWFI 850 °C), transparent - Contacts: silver alloy, gold-plated silver alloy (dual-current) - Terminals: brass (except W2/X: copper nickel), silver plated common - Levers: stainless steel or polyamide, polyamide roller - Degree of protection: IP40 (mechanism) - Recommended actuating speed: 0.1 mm/s to 0.5 m/s - Rated insulation voltage Ui: 250 V - Impulse withstand voltage Uimp: 4 kV - Certification marks: Product adaptations › Special levers : special shapes and lengths › Special connections : angled, screw with clamp (W5), full wiring with custom connector…. › Adjustable fixing by metal threaded barrel (SP9627) › Variant for irradiated environment Standard product Product made to order Contact us | | SWITCHES.CROUZET.COM || 2 | | MICROSWITCHES | | 10/2019 Principles Single break snap-action switch with positive opening action on NC contacts (1-2) according to IEC 60947-5-1 Annex K Changeover - SPDT (form C) Normally closed - SPST-NC (form B) 4 Curves Electrical life - Resistive load: 250 Va 6 A: 105 cycles - Inductive load (IEC 60947-5-1) : AC15: 250 Va 6 A: 0.3 x 105 cycles DC13: 24 Vc 20 W L/R = 40 ms: 3 x 105 cycles 120 Vc 20W L/R = 40 ms: 5 x 105 cycles * Dual-current models are designed to operate equally well on low current (10 mA 4 V minimum recommended) or medium-current (6 A maximum) circuits. However, a given product should only be used to switch one type of circuit during its working life Dimensions Product 831607 2,8 22,2 20,2 15,8 4 10 3,4 3,2 1 = 10,3 = 3 27,8 B Total travel position = 13.2 max. Connections W2 solder W3 quick-connect 6.3 x 0.8 W6 quick-connect 4.8x0.5 9,9 X1 for PCB, straight output 9,8 X2 for PCB, rear output X3 for PCB, front output 0,8 5 14,5 1,3 1,2x0,8 3,2 5,1 6,3 6±0,2 14,4 2,85 View A View A 1,2x0,8 | | SWITCHES.CROUZET.COM || 3 | | MICROSWITCHES | | 10/2019 Actuator mounting position Actuators 153EX roller 153FX dummy roller ,5 R2 R 5,5 R 5,7 F R2 4,3 0.5x8 153AX flat Actuators and mounting accessories Part numbers for standard actuators 79211670* 79211672* Flat 153AX R16.2 Actuators Roller 153EX R15.8 Operating force - max. N 4 Release force - min. N 1 Min. positive opening force N 18 Maximum rest position mm 16.2 Operating position mm 15.3 ±0,3 Positive opening position mm 14 Maximum total travel position mm 13.9 * We recommend that levers are mounted in our factories. See preferred part numbers in table below. For unmounted supply, please also order associated pin 79210424. Part numbers for standard actuators Two-pole 153A2XB R 24** ** Consult us 831607 microswitches with referenced actuators 831607 Standard I W2 I W3 I X3 R W2 R W3 R X3 153AX R16.2 79211670 ● ● ● ● ● ● Standard product Dummy roller 153FX R24.3 2.4 0.9 11 21.8 20.3 ±0,6 18 17.6 79211694* Actuators Actuators 4 1 18 21.3 20.5 ±0,45 19.2 19.1 79211668* 153EX R15.8 79211672 83160789 83160710 ● 83160787 83160711 83160714 Product made to order 153FX R24.3 79211668 ● ● ● ● 83160713 ● Contact us Flexible with roller 153B** Plastic 153V** | | SWITCHES.CROUZET.COM || 4 | | MICROSWITCHES | | 10/2019 Installation recommendations See “Basic technical concepts” How to order Use the 8 digit part numbers when they are defined Other cases, precise: Type of microswitch - Function - Connection - Contact* - Actuator* - Adaptation* * if needed Example: 831607 R W3 DORE 153AX R16.2 Examples of special adaptations Metal plunger and threaded barrel for heavy duty and precise setting (SP9627) Warning: The product information contained in this catalogue is given purely as information and does not constitute a representation, warrantly or any form of contractual commitment. Crouzet Automatismes SAS and its subsidiaries reserve the right to modify their products without notice. It is imperative that we should be consulted over any particular use or application of our products and it is the responsability of the buyer to establish, particularly through all the appropriate tests, that the product is suitable for the use or application. Under no circumstances will our warranty apply, nor shall we be held responsible for any application (such as any modification, addition, deletion, use in conjunction with other electrical or electronic components, circuits or assemblies, or any other unsuitable material or substance) which has not been expressly agreed by us prior to the sale of our products.
83160711 价格&库存
很抱歉,暂时无法提供与“83160711”相匹配的价格&库存,您可以联系我们找货
