83186001
83186001
    CROUZET(高诺斯)
    检测开关 单刀双掷 操作寿命200万次 DC24V 6A AC250V 6A
83186001 数据手册
02/11/2015 www.crouzet.com V4 8318 Sealed Standard 83186 Part number 83186001 IP 67 protection Nominal ratings 0.1 A to 10 A / 250 VAC Minimum rating 1 mA / 4 VDC Operating temperature -40 °C to +125 °C Choice of actuators with 2 possible fixing positions Part numbers 83186001 Type Function Connections Standard 83186 I (changeover) W2S Specifications Electrical characteristics Rating nominal / 250 VAC (A) Rating thermal / 250 VAC (A) 6 7,5 Mechanical characteristics Maximum operating force (N) Min. Release force (N) Maximum total travel force (N) Max. permitted overtravel force (N) Maximum rest position (mm) Operating position (mm) Maximum differential travel (mm) Min. overtravel (mm) Ambient operating temperature for blade version (°C) Ambient operating temperature for wires/cable version (° C) Mechanical life (operations) Contact gap (mm) Weight (g) (tags version) 2,5 0,8 4,2 10 9,3 8,4 ±0,3 0,1 0,6 -40 →+125 -40 →+105 2x106 0,4 2 * Création * * Please consult us for X1 / X2 / X3 connections ** Cable version for types 83181, 83183 and 83186 Additional specifications Components Material - Case : polyester UL 94VO - Button : polyester - Membrane : silicon - Contacts : AgCdO or AgSnO2 gold-plated AgNi (dual-current) - Terminals : silver-plated, tinned brass - Cable/Lead : PVC Levers - Flat : stainless steel - Roller : stainless steel, polyamide roller Principles Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 02/11/2015 www.crouzet.com Dimensions (mm) Product Symmetrical version types 83180 / 181 / 183 / 186 No Legend OL = 7.6 max. Dimensions (mm) Product Asymmetrical version for types 83180 / 181 / 183 / 186 Dimensions (mm) Actuators 170A Flat Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 02/11/2015 Dimensions (mm) Actuators 170E Roller Dimensions (mm) Actuators 170 F Dummy roller Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected www.crouzet.com 02/11/2015 Dimensions (mm) Connections W2S Solder Dimensions (mm) Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected www.crouzet.com 02/11/2015 Connections W7S Faston 2.8 x 0.5 Dimensions (mm) Connections X1A Straight PCB output Dimensions (mm) Connections X1S Straight PCB output Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected www.crouzet.com 02/11/2015 www.crouzet.com Dimensions (mm) Mounting accessories Fixing pins No Legend X3 output Dimensions (mm) Mounting accessories Fixing pins No Legend X2 output Curves Operating curve 250 VAC Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 02/11/2015 www.crouzet.com Model 83181 is designed to operate equally well on dual-current (1 mA 4 V minimum) or medium-current (6 A maximum) circuits. However, a given product should only be used to switch one type of circuit during its working life. No Legend Number of cycles Resistive circuit Current in Amps Curves Switch rating with DC supply Model 83181 is designed to operate equally well on dual-current (1 mA 4 V minimum) or medium-current (6 A maximum) circuits. However, a given product should only be used to switch one type of circuit during its working life. Connections Actuators and fixing positions Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 02/11/2015 www.crouzet.com Other information Mounting - Operation See basic technical concepts Degree of protection - Tag version : →casing = IP67 →terminals = IP00 - Lead/cable version : →output/casing = IP67 To calculate force : divide the switch force by the coefficient in the table. To calculate travel : multiply the switch travel by the same coefficient. Product adaptations Special levers Specific fixings Special leads, cables, cable harnesses NF - UL - cUL approvals Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected
83186001 价格&库存
很抱歉,暂时无法提供与“83186001”相匹配的价格&库存,您可以联系我们找货
