TIMERS
TIMERS
88220
SERIES
MULTIFUNCTION MOTOR
TIMER WITH MEMORY
UL listed
CSA recognized
• Five Functions in One Unit
• Timing Range from 0.3 sec to 12 hours
• DIN-Rail, Plug-in, or Panel Mounting
DESCRIPTION:
The 88220 Series is a synchronous motor driven reset timer. The
timer is available in 2 standard time ranges from 0.3 sec to 12
hours. Time ranges are knob adjustable and all have a progress
pointer which displays the remaining time. Different functions (ON
Delay, Interval, One Shot) selectable through external wiring.
FUNCTION AND WIRING DIAGRAMS:
(Octal plug-in mounting shown)
"ON DELAY" Maintained Start Switch
4
SPECIFICATIONS:
5
3
6
2
7
1
Start N.O.
. . 24 VAC, 110 VAC, 220 VAC
. . ±10%, 60 Hz
. 3 VA
. . 1 x SPST Relay & 1 x SPDT
. . Relay
. . AgCdO
. . 8 Amp 1/3 HP
. . 220 VAC
. . 2.5 million operations
. . ±1.5% (except 4% on 6 sec
. . range)
. . +2% (except 5% on 6 sec
. . range)
. . 200 ms
. . -20° to +70°C (-4° to 158°F)
. . -20° to +55°C (-4° to 131°F)
4
Power
(Start Switch)
8
Output
5
3
6
2
7
Start
N.O.
Load
Input Power . . . . . . . . . . . . . .
Maximum power consumption
Output . . . . . . . . . . . . . . . . . . .
Contact material . . . . . . . . . . .
Maximum loading . . . . . . . . . .
Maximum switching voltage .
Mechanical life of relay . . . . .
Repeat accuracy . . . . . . . . . . .
Setting Accuracy . . . . . . . . . . .
Reset time . . . . . . . . . . . . . . .
Storage temp. rating . . . . . . .
Operating temp. rating . . . . . .
"ON DELAY" Momentary Push Button
1
Momentary
Contact
8
Delay
Output
Load
AC Supply
Delay
AC Supply
"INTERVAL" Maintained Start Switch
4
5
3
6
2
7
1
Start N.O.
"INTERVAL" Momentary Push Button
4
Power
(Start Switch)
8
5
3
6
2
7
1
Output
Load
Start N.O.
Delay
AC Supply
Momentary
Contact
8
Output
Load
Delay
AC Supply Reset
"ONE SHOT"
CROSS REFERENCE TABLE FOR:
Octal Plug Pins = Screw Terminals
4
3
6
2
7
1
Momentary
Contact
Load
5
8
Output
AC Supply
4
6
2
Delay
1
2
3
4
5
6
7
8
5
3
7
1
8
Start N.O.
DIMENSIONS: inches (mm)
24
A1
23
-16
18
A2
15
A1 15 24 23
16 18 A2
Type 88 225 0 (DIN - rail mounting)
1.48
(37.5)
Type 88 226 5 (octal plug-in)
with memory
1.38
(35)
without memory
8
6
7
1.89
(48)
.51
(13)
3.54 (90)
2.75 (70)
2.36 (60)
3.19 (81)
1.77
(45)
3.58 (91)
(5 20
.2
1
2
1.17 (45)
5
1.89
(48)
4
3
2.46 (62.5)
.16
(4.2)
FIXED
2.16 (55)
3.03 (77)
1.97 (50)
4.05 (103)
Max. Thickness
of panel .39 (10)
3.27 (83)
Nut M3
Type 88 226 0 (paneling mounting)
1.81
(46)
1.89
(48)
1.71
(45)
Panel cut-out
1.89
(48)
Max. Thickness
of panel .39 (10)
.47
(12)
3.94 (100)
1.81
(46)
Products and specifications subject to change without notice.
Consult factory for application assistance.
204 Airline Drive, Suite 300, Coppell, Texas 75019 / Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com
4-8
TIMERS
TIMERS
TRANSIENT
IMMUNITY
GENERAL FEATURES:
Built-in
MULTI-RANGE
MULTI-FUNCTION
2 model/3 time ranges
each cover
from 0.3 sec to
12 hours
on-delay, interval
and single shot in
on timer
CYCLE PROGRESS
dial shows
time remaining
in cycle
±2% SETTING
ACCURACY
MEMORY
±1.5% REPEAT
ACCURACY
when “on,”
holds time
during power
interruption
4
ADAPTER PLATE
available for field
interchangeability
(not shown)
OFF
MEMORY
ON
TIME RANGES
Model 1 (12 min.): .3 to 6 s, .5 to 12 min.
Model 2 (12 hrs.): .3 to 6 min., 3 to 60 min, .5 to 12 hrs.
ORDERING INFORMATION:
EXAMPLE
MODEL 1 (12 MIN.), 115V/60Hz, OCTAL PLUG-IN, 88 226 510
When ordering, select model, voltage/frequency and
mounting to determine part number in chart below
MODELING
MODEL
VOLTAGE/FREQ.*
OCTAL PLUG-IN
(PART NUMBER)
PANEL MOUNTING
(PART NUMBER)
BASE MOUNTING
(PART NUMBER)
MODEL 1
MODEL 1
MODEL 1
MODEL 1
(12
(12
(12
(12
MIN.)
MIN.)
MIN.)
MIN.)
24 V/60 Hz
115 V/60 Hz
220 V/60 Hz
220 V/50 Hz
88 226 509
88 226 510
88 226 511
88 226 504
88 226 029
88 226 030
88 226 031
88 226 011
88 225 029
88 225 030
88 225 031
88 225 011
MODEL 2
MODEL 2
MODEL 2
MODEL 2
(12
(12
(12
(12
HRS.)
HRS.)
HRS.)
HRS.)
24 V/60 Hz
115 V/60 Hz
220 V/60 Hz
220 V/50 Hz
88
88
88
88
88
88
88
88
88
88
88
88
226
226
226
226
512
513
514
508
226
226
226
226
032
033
034
014
225
225
225
225
032
033
034
014
4-9
很抱歉,暂时无法提供与“88225030”相匹配的价格&库存,您可以联系我们找货
