88827044
88827044
    CROUZET(高诺斯)
    FUNCTION L TIMER 24-240VAC
88827044 数据手册
09/04/2015 www.crouzet.com 17.5 mm - 1 Solid State Relay 0.7A MHS2 Part number 88827044 Multi-function or mono-function Multi-range Multi-voltage Screw or spring terminals LED status indicator (relay version) Possibility of external load connection in parallel to the control input 3-wire PNP sensor compatible Part numbers 88 827 044 Type Functions Timing Output Nominal rating Connections Supply voltage MHS2 H - Ht 0,1s→100h Solid state 0,7 A Screw terminals 24 →240 V AC Specifications Timing Timing ranges (7 ranges) Repetition accuracy with constant parameters Drift Temperature Drift Voltage Display accuracy according to IEC/EN 61812-1 Immunity from micro power cuts : typical 1 s - 10 s - 1 min - 10 min - 1 h - 10 h - 100 h ± 0.5 % (IEC/EN 61812-1) ± 0,05 % / °C ± 0,2 % / V ± 10 % / 25 °C < 10 ms Supply Multi-voltage power supply Frequency (Hz) Operating factor Depending on version 50 / 60 100 % Output specification Rated power Maximum breaking current Minimum breaking current Voltage breaking capacity 2000 VA/80 W 8 AAC 250 VAC resistive 8 ADC 30 VDC resistive 10 mA / 5 VDC 250 VAC / 8 AAC resistive 250 VDC / 0,3 A resistive Electrical life (operations) 105 8 A 250 VAC resistive Mechanical life (operations) 10 x 106 2,5 kV / 1 min / 1 mA / 50 Hz 5 kV wave 1.2 / 50 μs Breakdown voltage acc. to IEC/EN 61812-1 Impulse voltage acc. to IEC/EN 60664-1, IEC/EN 61812-1 General characteristics Conformity to standards IEC/EN 61812-1 IEC/EN 61000-6-1 IEC/EN 61000-6-2 IEC/EN 61000-6-3 IEC/EN 61000-6-4 CE, UL, cUL, CSA, GL -20 →+60 -30 →+60 Certifications Temperature limits use (°C) Temperature limits stored (°C) Installation category Voltage surge category III (acc. to IEC/EN 60664-1) Creepage distance and clearance acc. to IEC/EN 60664-1 4 kV / 3 mm Protection (IEC/EN 60529) IP20 IP40 Degree of protection acc. to IEC/EN 60529 Front face IP50 Vibration resistance 20 m/s2 10 Hz →150 Hz acc. to IEC/EN 60068-2-6 Relative humidity no condensation acc. to IEC/EN 600682-30 Electromagnetic compatibility - Immunity to electrostatic discharges acc to IEC/EN 61000-4-2 Immunity to radiated, radio-frequency, electromagnetic field acc. IEC/EN 61000-4-3 93 % non-condensing Level III (Air 8 kV / Contact 6 kV) Level I (1 V/m : 2,0 G Hz →2,7 G Hz)  Level II (3 V/m : 1,4 G Hz →2,0 G Hz)  Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 09/04/2015 www.crouzet.com Level III (10 V/m : 80 M Hz →1 G Hz) Immunity to rapid transient bursts acc. to IEC/EN 61000-44 Immunity to shock waves on power supply acc. to IEC/EN 61000-4-5 Immunity to radio frequency in common mode acc. to IEC/EN 61000-4-6 Immunity to voltage dips and breaks acc. to IEC/EN 610004-11 Mains-borne and radiated emissions acc. to EN 55022 (CISPR22), EN55011 (CISPR11) Fixing : Symmetrical DIN rail Terminal capacity Single-wire without ferrule Level III (direct 2 kV / Capacitive coupling clamp 1 kV) Level III (2 kV / common mode 2 kV/residual current mode 1 kV) Level III (10V rms : 0.15 M Hz to 80 M Hz) 0 % residual voltage, 1 cycle 70 % residual voltage, 25/30 cycles Class B 35 mm 1 x 0,5 →3,3 mm2 (AWG 20 →AWG 12)  2 x 0,5 →2,5 mm2 (AWG 20 →AWG 14) Terminal capacity Multi-wire with ferrule 1 x 0,5 →2,5 mm2 (AWG 20 →AWG 14)  2 x 0,5 →1,5 mm2 (AWG 20 →AWG 16) Housing material Self-extinguishing Shock test IEC/EN 60068-2-27 15 g - 11 ms Short interruption on power line acc to IEC/EN 61000-4-11 0 % residual voltage, 250/300 cycles Dimensions (mm) Curves Function H Function H Timing on energisation 1 relay Curves Function Ht Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 09/04/2015 Function Ht Timing on energisation with memory 1 relay Connections Solid state output Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected www.crouzet.com
88827044 价格&库存
很抱歉,暂时无法提供与“88827044”相匹配的价格&库存,您可以联系我们找货
