Reversible synchronous geared motors with capacitor
Constant speed, dependent on supply frequency
Direction of rotation controlled by dephasing capacitor
Permanent magnet rotor
UL, CSA, VDE approved, comply with IEC standards.
Types
Applications
80 517 3
80 527 0
80 527 4
230-240 V
50 Hz
250
230-240 V
50 Hz
250
230-240 V
50 Hz
375
Voltages / Frequencies
- Valve actuation
- Blind, louvre and vane actuation
- Office equipment
- Boiler systems
- Amusement machines
- Vending machines
- Medical equipment
- Laboratory equipment
- Peristaltic pumps
Base speed of motor (rpm)
Output speeds (rpm)
Motors
250 rpm
8
6
4
3
2
1
0.5
0.33
0.1
Ratios (i)
375 rpm
30
15
12
9
10
4.5
3
1.5
0.75
0.5
0.15
Part numbers
12.5
25
31.25
41.66
62.5
83.33
125
250
500
750
2500
80 527 010
80 527 001
80 527 002
80 527 003
80 527 005
80 527 006
80 527 008
Standard gearbox shaft: see dimensions
General characteristics
Made to order products,
non stocked
2
Motors :
- other voltages/frequencies
- lead length
- boosted coils for performance
+30% higher than standard
(Please consult us)
- different lead exit angle relative
to gearbox
Gearboxes :
- other output speeds
- special shaft
- special lubrication
- ball bearing
Motor
Gearbox
Maximum permitted continuous rated gearbox
output torque for 1 million revolutions of gearbox
output shaft
Axial load (static)
Radial load (static)
Absorbed power
Usable motor power
Maximum temperature rise
Ambient temperature
Weight
Lead length (approx.)
Protection
82 510 3
81 037 0
82 520 0
81 037 0
82 520 4
81 037 0
N.m
5
5
5
daN
daN
W
W
°C
°C
g
mm
2
3
2.7
0.31
50
-10+70
410
250
IP40
2
3
3.5
0.98
50
-10+70
530
250
IP40
2
3
3.5
1.12
50
-10+70
530
250
IP40
Options : for made to order products non stocked
24-115 V 60 Hz
24 V 50 Hz
Round shaft 79 306 478 (see page 2/29)
Torque / Speed curves
80 517 0
80 527 0 - 80 527 4
mN.m
mN.m
4000 5000
3000
2000
800 1000
600
400
300
200
80 100
60
40
4000 5000
3000
2000
rpm
1/2 1
2 3 4 6 10 20
6 8 15
800 1000
600
400
300
200
100
80
60
80 527.0
80 527.4
rpm
1
2 3 4 6 10 15 30
8
Capacitors (supplied only on request)
Other information
For basic principles, see page 2/6
Motor 82 510 0
230-240 V 50 Hz
115 V 50/60 Hz
24 V 50 Hz
24 V 60 Hz
Motor 82 520 4
230-240 V 50 Hz
115 V 60 Hz
24 V 50 Hz
24 V 60 Hz
µF
V
Part number
0.33 ± 10%
0.27 ± 10%
8.2 ± 10%
6.8 ± 10%
400
250
63
63
26 231 801
26 231 851
26 231 711
26 231 148
0.12 ± 10%
0.39 ± 10%
15 ± 10%
12 ± 10%
630
630
63
63
26 231 903
26 231 924
26 231 729
26 231 727
2/30
Motor 82 520 0
230-240 V 50 Hz
115 V 60 Hz
24 V 50 Hz
µF
V
0.10 ± 10% 700
0.33 ± 10% 400
8.2 ± 10% 63
Part number
26 231 941
26 231 801
26 231 711
Dimensions
80 517 0 - 80 527 0 - 80 527 4 - 80 547 0
2
Ø L2 max.
80 547 024
80 547 015
56
65 max.
3
-0
-0
56
Ø 14-0,03
7 across flat
65 max.
230-240 V
50 Hz
250
Ø 8-0,022
1
80 547 0
80 547 016
80 547 017
80 547 018
80 547 019
80 547 020
80 547 021
15
13
17
Type
80 517 0
80 527 0
80 527 4
80 547 0
82 540 0
81 037 0
L1 (mm)
55.3
59.2
59.2
76.6
3
L3 max.
4 holes M4
depth 12
L1 max.
Ø L2 (mm)
35.8
51.3
51.3
65.3
19,7
(pushed-in shaft ←)
L3 (mm)
21.7
25.6
25.6
43
Shaft 79 206 478
(pushed-in shaft ←)
5
2
3
7.2
2.65
55
-10+70
860
250
Ø8
4
Ø 14
19,7 max.
In parallel
Motors 82 510 0 - 82 520 0 - 82 520 4
82 540 0
2
Connections
In series
Motor 82 510 0 only
230V - 240V 50 Hz version
80 547 0
mN.m
5000
4000
3000
2000
SA : clockwise
SA : clockwise
SI : anti-clockwise
SI : anti-clockwise
800 1000
600
400
300
200
80
SA
100
60
40
1/2
Motor 82 540 0
230-240 V 50 Hz
115 V 60 Hz
24 V 50 Hz
24 V 60 Hz
µF
V
Part number
0.22 ± 10%
0.56 ± 5%
15 ± 10%
15 ± 10%
630
400
63
63
26 231 908
26 231 922
26 231 729
26 231 729
SA
UN
2 3 4 6 10 20 rpm
5 8 15
1
SI
SI
UN
To order, specify :
Standard products
3
Part number
Example : Synchronous geared motor 80 527 010
Standard products,
non stocked
2/31
1
2
3
4
Voltage /
Output
Type
Option
Frequency
speed
Example : Reversible synchronous geared motor 80 517 0 - 230 V 50 Hz 20 rpm
很抱歉,暂时无法提供与“26231941”相匹配的价格&库存,您可以联系我们找货
