| | MOTORS.CROUZET.COM
|| 1
| | DCmind BRUSHLESS MOTORS
| | 01/2019
SQ75 motor with integrated SMi22 CANopen electronic board
››DC Brushless motor for position, speed and torque control
applications
››High precision thanks to the 4096 position per turn magnetic
encoder
››CANopen Communication bus (CiA 301 compliant and
implemented with CiA 402 drive profile)
››Enhanced safety via 2 Safe Torque Off (STO) inputs
››IP67 & IP69 direct drive according to IEC 60259 (except front
face & shaft output)
››Protection against wrong polarity
80350
80360
80370
General characteristics
Type
Part numbers
Nominal operating range
No-load characteristics
Speed of rotation
Absorbed current
Standby current ± 10 %
Nominal characteristics
Speed ± 10 %
Torque
Absorbed current
Output power ± 10 %
Efficiency
Maximal characteristics
Speed
Torque
Output power ± 10 %
Absorbed current
Efficiency
Other characteristics
Cogging Torque
Weight
80350
80360
80370
rpm
N.m
W
A
80350001
9 - 75
12Vc
1 700
1.1
50
12Vc
1 380
1
15.4
145
78
12Vc
1 000
2.5
262
34.5
60
24Vc
3 230
1
50
24Vc
3 000
1
15.4
314
85
24Vc
2 310
2.5
600
34.5
74
32Vc
4 500
2.4
50
32Vc
3 845
1
15.4
400
82
32Vc
3 100
2.5
750
34.5
68
80360001
9 - 75
24Vc
2 601
1
50
24Vc
2 230
1.3
14.4
304
85
24Vc
1 650
4
691
42
67
32Vc
3 270
1
50
32Vc
2 960
1.3
14.4
403
87
32Vc
2 160
4
905
42
69
48Vc
5 000
0.9
50
48Vc
4 540
1.3
14.4
618
87
48Vc
3 540
4
1 483
42
71
80370001
9 - 75
32Vc
2 300
1
50
32Vc
2 000
1.9
15.1
398
80
32Vc
1 650
5
864
40
67
48Vc
3 420
1
50
48Vc
3 130
1.9
15.1
623
86
48Vc
2 340
6
1 470
44
70
60Vc
4 320
1
50
60Vc
3 890
1.9
15.1
700
78
60Vc
3 170
6
1 800
44
68
mNm
Kg
45
2.4
45
2.4
45
2.4
50
2.7
50
2.7
50
2.7
55
3.3
55
3.3
55
3.3
Vc
rpm
A
mA
rpm
N.m
A
W
Accessories
Description
Starter kit: Dcmind Soft+CANopen software - Power/logic/CAN 3 m cables - USB to CANopen adaptor - CAN
terminal resistor - CAN double connector
Power supply cable M16, 3 m length AWG18
Part numbers
Input-Output cable M16, 3 m length AWG24
79513106
CAN cable M12, 1 m length AWG26
Combinations
79513105
79298664
27358015
PL AY ON COMBINATIONS
2 Choose The Gearbox
1 Choose The Motor
80350
80360
80370
OR MOTOR
+ 4.5 Nm BREAK
PLANETARY
GEARBOX | PM72
PLANETARY
GEARBOX | P81
1 - 2 - 3 Stages
1 - 2 - 3 Stages
RIGHT-ANGLE WORM
GEARBOX | RAD20
You have a project? Contact us on www.crouzet.com
Description:
The new SQ75 DCmind Brushless motors have an integrated drive and CANopen communication bus for Motion Control applications
up to 600 W nominal power and up to 6 Nm peak torque. More power, accurate precision, as well as enhanced safety and security features
to secure your application.
For more information about Crouzet’s SQ75 range, please visit www.crouzet.com.
| | MOTORS.CROUZET.COM
|| 2
| | 01/2019
Curves
Speed-torque and current-torque
80350
80360
3000
24V
2000
4000
32V
3000
24V
2000
12V
1000
1
1,5
2
2,5
1
2
Current (A)
Current (A)
50
40
12V - 24V - 32V
5
60
60
50
50
40
24V - 32V - 48V
30
2
2
3
4
5
3
4
5
6
7
Torque (Nm)
10
10
Torque (Nm)
60
30
32V
2000
Torque (Nm)
Current (A)
0,5
48V
3000
1000
1000
60V
48V
4000
Speed (rpm)
32V
Speed (rpm)
Speed (rpm)
5000
5000
4000
6000
5000
40
30
32V - 48V - 60V
2
3
4
5
2
Torque (Nm)
Torque (Nm)
3
4
5
6
7
Torque (Nm)
Nominal torque
Continuous running area
Peak torque
Cycling running area
Dimensions (mm)
80350 - 80360 - 80370
USB
CONNECTOR
4
48.5±0.35
94±0.1
5
10±0.1
2
30±0.3
3±0.1
Ø90
8
5±0.2
1/45°
Ø32-0.05
30±0.2
75±0.3
16 max
Ø14-0.018
145±0.3
1
6
75±0.3
9
5±0.2
7
Logic connector
CAN connector
Power supply connector
M5 x 0.8 depth7
2 colors LED for motor status
M5 x 0.8 depth thread 12
M6 x 1 at 90 ° on Ø56 depth 10.5
M5 x 0.8 depth 11.5
Parallel key 5 x 5 x 18 DIN 6885 A
B
C
D
E
F
G
H
I
J
L
L: 80350 140.6 max - L: 80360 153.1 max - L: 80370 178.1 max
Connection
Pin
Input / Output M16 connector - 18 pins
Power supply
M16 - 3 pins
Description
Pin
Description
1
Optional logic supply
14
0 volt
1
Output ballast
2
0 volt
15
STO2-
2
+VDC
3
Input 6 (analogic 1)
16
STO2+
3
0 volt
4
Input 5 (analogic 2)
17
STO1-
5
Input 1 (digital)
18
STO1+
6
Input 2 (digital)
7
Input 3 (digital)
8
Input 4 (digital)
9
0 volt
10
Output 1 (digital - PMW)
11
Output 2 (digital - PMW)
12
Output 3 (digital)
13
Output 4 (digital)
Pin
2
1
Description
13
3
4
15
5
6
12
11
18
10
9
Pin
14
7
8
16
17
CAN - M12 - 5 pins
Description
1
Not connected
2
Not connected
3
CAN_GND
4
CAN_H
5
CAN_L
3
4
5
1
2
User information
Product User Manual available on website, please read it before use.
Products on request
Please contact our Design LAB on www.crouzet.com. Examples: special shaft - board adaptation...
Warning:
The product information contained in this catalogue is given purely as information and does not constitute a representation, warrantly or any form of contractual commitment. Crouzet Automatismes SAS and its subsidiaries
reserve the right to modify their products without notice. It is imperative that we should be consulted over any particular use or application of our products and it is the responsability of the buyer to establish, particularly through
all the appropriate tests, that the product is suitable for the use or application. Under no circumstances will our warranty apply, nor shall we be held responsible for any application (such as any modification, addition, deletion,
use in conjunction with other electrical or electronic components, circuits or assemblies, or any other unsuitable material or substance) which has not been expressly agreed by us prior to the sale of our products.
很抱歉,暂时无法提供与“27358015”相匹配的价格&库存,您可以联系我们找货
