82514015
82514015
    CROUZET(高诺斯)
    MOTOR 82510 300RPM GEARBOX OVOID
82514015 数据手册
03/10/2015 www.crouzet.com 0.5 Nm 2.7 Watts Part number 82514015 Mechanical strength: 0.5 Nm Constant speed, dependent on supply frequency Wide range of speeds available Direction of rotation controlled by dephasing capacitor Permanent magnet rotor UL, CSA, VDE approved, comply with IEC standards Part numbers Type 82 514 015 2.7 Watts Type Direction of rotation Output speed Ratios (i) Voltage / Frequency 82 514 0 2 Sen 300 rpm 150 115Vac 60 Hz Specifications Motor Gearbox Maximum permitted continuous rated gearbox output torque for 1 million revolutions of gearbox output shaft (Nm) Axial load static (daN) Radial load static (daN) Absorbed power (W) Motor output (W) Maximum temperature rise (°C) Ambient temperature (°C) Weight (g) Wires length mm (approximately) Protection rating 82 510 0 81 021 0 0.5 1 8 2,7 0,31 50 -5 →+70 140 250 IP40 Accessories Voltages/Frequencies µF 0,27 ± 10 % 115 V - 50/60 Hz Dimensions (mm) 82 510 0 No Legend 2 fixing holes Ø 3.2 Fixing clip 3.5 across flat pushed-in shaft Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected V AC 250 Code 26 231 851 03/10/2015 www.crouzet.com Connections In parallel Motors 82 510 0 No Legend SA: Clockwise SI: Anti-clockwise Product adaptations Different voltages available Pinion on output shaft Special output shafts Special cable lengths Special output bearings Special mounting plate Special connectors Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected www.crouzet-motor.com 02/11/2015 Curves Graph of torque versus speed 82 514 0 No Legend RPM Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected
82514015 价格&库存
很抱歉,暂时无法提供与“82514015”相匹配的价格&库存,您可以联系我们找货
    • 20+982.7644320+127.13558
