83880111
    CROUZET(高诺斯)
83880111 数据手册
22/10/2012 www.crouzet.com 83880 with cable output Metal plunger with threaded barrel Part number 83884103 IP 66/67 Metal case cUL approval Part numbers Characteristics Type of output 83 880 101 Metal plunger Standard Cable length 1 m 83 880 102 Metal plunger Standard Cable length 2 m 83 880 103 Metal plunger Standard Cable length 3 m 83 880 106 Metal plunger Standard Cable length 6 m CONTACT US Metal plunger Plunger with 90° roller Cable length 1 m CONTACT US Metal plunger Plunger with 90° roller Cable length 2 m CONTACT US Metal plunger Plunger with 90° roller Cable length 3 m CONTACT US Metal plunger Plunger with 90° roller Cable length 6 m 83 881 101 Metal roller plunger Standard Cable length 1 m 83 881 102 Metal roller plunger Standard Cable length 2 m 83 881 103 Metal roller plunger Standard Cable length 3 m 83 881 106 Metal roller plunger Standard Cable length 6 m 83 885 101 Metal roller plunger Plunger with 90° roller Cable length 1 m 83 885 102 Metal roller plunger Plunger with 90° roller Cable length 2 m 83 885 103 Metal roller plunger Plunger with 90° roller Cable length 3 m 83 885 106 Metal roller plunger Plunger with 90° roller Cable length 6 m 83 884 101 Metal plunger with threaded barrel Standard Cable length 1 m 83 884 102 Metal plunger with threaded barrel Standard Cable length 2 m 83 884 103 Metal plunger with threaded barrel Standard Cable length 3 m 83 884 106 Metal plunger with threaded barrel Standard Cable length 6 m CONTACT US Metal plunger with threaded barrel Plunger with 90° roller Cable length 1 m CONTACT US Metal plunger with threaded barrel Plunger with 90° roller Cable length 2 m CONTACT US Metal plunger with threaded barrel Plunger with 90° roller Cable length 3 m CONTACT US Metal plunger with threaded barrel Plunger with 90° roller Cable length 6 m 83 882 101 Roller plunger - metal with threaded barrel Standard Cable length 1 m 83 882 102 Roller plunger - metal with threaded barrel Standard Cable length 2 m 83 882 103 Roller plunger - metal with threaded barrel Standard Cable length 3 m 83 882 106 Roller plunger - metal with threaded barrel Standard Cable length 6 m 83 886 101 Roller plunger - metal with threaded barrel Plunger with 90° roller Cable length 1 m 83 886 102 Roller plunger - metal with threaded barrel Plunger with 90° roller Cable length 2 m 83 886 103 Roller plunger - metal with threaded barrel Plunger with 90° roller Cable length 3 m 83 886 106 Roller plunger - metal with threaded barrel Plunger with 90° roller Cable length 6 m 83 883 101 Steel metal roller lever (2 directions of attack) Standard Cable length 1 m 83 883 102 Steel metal roller lever (2 directions of attack) Standard Cable length 2 m 83 883 103 Steel metal roller lever (2 directions of attack) Standard Cable length 3 m 83 883 106 Steel metal roller lever (2 directions of attack) Standard Cable length 6 m CONTACT US Steel metal roller lever (2 directions of attack) Plunger with 90° roller Cable length 1 m CONTACT US Steel metal roller lever (2 directions of attack) Plunger with 90° roller Cable length 2 m CONTACT US Steel metal roller lever (2 directions of attack) Plunger with 90° roller Cable length 3 m CONTACT US Steel metal roller lever (2 directions of attack) Plunger with 90° roller Cable length 6 m Type Specifications Conformity to standards Protection against electric shocks Degree of protection IEC 60529 Degree of protection according to NEMA 250 Type 1, 3, 4, 6, 13 Electrical characteristics Connection Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 22/10/2012 www.crouzet.com Operating temperature (°C) -25 →+70 °C Assigned impulse voltage (Uimp) - V Assigned insulation voltage Ui (V) Thermal current I (A) Low-load switching - Minimum voltage (V) Low-load switching - Minimum current (mA) Assigned working characteristics (EN 60 947.5.1, UL 508) Use category according to IEC 947.5.1 Use category according to UL 508 Electrical protection Approvals 500 10 10 100 A300 = AC15 250 V 6 A Q150 = DC13 24 V 8 A AC15=250 V/6 A DC13=24 V/8 A A300 - Q150 Integral earth wire Short-circuit protection device : IEC/EN 60947.5.1 Fuse 6 AgC UL 508, UL 50 Mechanical characteristics Sequence Snap action Minimum operating force (N) Minimum operating force (Nm) Minimum total travel force (N) Minimum total travel force (Nm) Min. positive opening travel (N) Min. positive opening travel (Nm) Mechanical life (millions of operations) Vertical approach speed Horizontal approach speed (30° cam) Weight (g) 10 30 28 10 1 mm/min →0,3 m/s 220 Principles Function Four-terminal double break two-way contact element (form Zb) with positive opening NC contacts. The 2 moving contacts are electrically isolated from one another. No Legend Brown Black Blue Green-yellow Dimensions (mm) Product 83 884 1 Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 22/10/2012 www.crouzet.com 83 884 0 No Legend POP marking Max.tightening thickness 8.5 Product adaptations •Contact type •Rear output •Protective scraper seal •Length of cable/connector/stripping •Connector output •Low level contact Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected
83880111 价格&库存
很抱歉,暂时无法提供与“83880111”相匹配的价格&库存,您可以联系我们找货
