EZ240D12
EZ240D12
    CROUZET(高诺斯)
EZ240D12 数据手册
EZ Series • Compact design for low-profile applications; Ratings from 5A to 18A @ 600 VAC • SCR output for heavy industrial loads • AC or DC control • 1/4" fast-on terminals for easy installation • UL/CSA/VDE Approved, CE Compliant to EN60950-1 PRODUCT SELECTION Control Voltage 3-15 VDC 15-32 VDC 90-140 Vrms 18-36 Vrms 4-15 VDC 15-32 VDC 90-140 Vrms 18-36 Vrms 5A 12A 18A EZ240D5 EZ240D12 EZE240D12 EZ240A12 EZE240A12 EZ480D12 EZE480D12 EZ480A12 EZE480A12 EZ240D18 EZE240D18 EZ240A18 EZE240A18 EZ480D18 EZE480D18 EZ480A18 EZE480A18 AVAILABLE OPTIONS OUTPUT SPECIFICATIONS (1) Description Operating Voltage (47-63Hz) [Vrms] Transient Overvoltage [Vpk] Maximum Off-State Leakage Current @ Rated Voltage [mArms](5) Minimum Off-State dv/dt @ Maximum Rated Voltage [V/µsec] (2) Maximum Load Current (4) [Arms] Minimum Load Current [mArms] Maximum 1 Cycle Surge Current (50/60) [Apk] Maximum On-State Voltage Drop @ Rated Current [Vpk] Thermal Resistance Junction to Case (Rjc) [°C/W] Maximum I² t for Fusing 50/60Hz (1/2 cycle) [A² sec] Minimum Power Factor (with Maximum Load) 5A 12 A 18 A 12 A 18 A 24-280 600 0.1 500 5 150 38/40 1.5 2 102/93 0.5 24-280 600 0.1 500 12 150 143/150 1.5 2 102/93 0.5 24-280 600 0.1 500 18 150 191/200 1.5 1.1 182/166 0.5 48-660 1200 0.1 500 12 150 143/150 1.5 2 102/93 0.5 48-660 1200 0.1 500 18 150 191/200 1.5 1.1 182/166 0.5 INPUT SPECIFICATIONS (1) Description Control Voltage Range Minimum Turn-On Voltage Minimum Turn-Off Voltage Typical Input Current @ Nominal Voltage Nominal Input Impedance Maximum Turn-On Time [msec] (6) Maximum Turn-Off Time [msec] EZ240D5 EZ240Dxx EZ480Dxx EZExxxDxx EZxxxAxx EZExxxAxx 3-15 VDC 3.0 VDC 1.0 VDC 15 mAdc 300 Ohm 1/2 Cycle 1/2 Cycle 3-15 VDC 3.0 VDC 1.0 VDC 15 mAdc 300 Ohm 1/2 Cycle 1/2 Cycle 4-15 VDC 4.0 VDC 1.0 VDC 15 mAdc 240 Ohm 1/2 Cycle 1/2 Cycle 15-32 VDC 15.0 VDC 1.0 VDC 15 mAdc 1500 Ohm 1/2 Cycle 1/2 Cycle 90-140 Vrms 90.0 Vrms 10.0 Vrms 10 mA 10.6 k Ohm 10 40 18-36 Vrms 18.0 Vrms 2.0 Vrms 10 mA 1.8 k Ohm 10 40 GENERAL SPECIFICATIONS Description Dielectric Strength, Input/Output/Base (50/60Hz)(3) Minimum Insulation Resistance (@ 500 V DC) Maximum Capacitance, Input/Output Ambient Operating Temperature Range Ambient Storage Temperature Range Weight (typical) Encapsulation Terminals Mounting Screw Torque (8-32 UNC screw) [in lbs/Nm] Parameters 4000 Vrms * 109 Ohm 8 pF -40 to 80 °C -40 to 125 °C 1.5 oz (43 g) Thermally conductive Epoxy 0.25 Inch Faston 8-14/1.1-1.5 GENERAL NOTES 1) All parameters at 25°C unless otherwise specified. 2) Off-State dv/dt test method per EIA/NARM standard RS-443, paragraph 13.11.1 3) 240V, DC control models only, all others 2500VRMS 4) Heat sinking required, see derating curves. 5) Off- state leakage for snubbered version (suffix S, 240V version only) is 10.0mArms 6) Turn-on time for random turn-on versions is 0.1 msec (DC Control Models). * 240V, DC control models only WIRING DIAGRAM MECHANICAL SPECIFICATIONS THERMAL DERATE INFORMATION AGENCY APPROVALS Designed in accordance with the requirements of IEC 62314 EN60950 : Meets the requirements of sections1.5: 1,7: 2.9: 2.10.5.3: 4.2: 4.5: 4.7: E116950 LR81689 10139 UG (240 VDC Control Only) Rev. 022912 ANNEX - ENVIROMENTAL INFORMATION
EZ240D12 价格&库存
很抱歉,暂时无法提供与“EZ240D12”相匹配的价格&库存,您可以联系我们找货
