02/11/2015
www.crouzet.com
5 Nm RC65 10 and 17 Watts 10 W Part number 80 817 014
Torque rating of gearboxes : 5 Nm, metal gears
Motors : nominal power 9 W to 15 W
Speed range : 1.04 to 208 rpm
Replaceable brushes
Part numbers
80817014
Type
Type
Voltage
Output speed (rpm)
Ratios (i)
10 W
808170
24 V
21
125
Specifications
General characteristics
Motor
Gearbox
Maximum permitted torque from gearmotor under
continuous conditions for 1 million turns (Nm)
Axial load dynamic (daN)
Radial load dynamic (daN)
Max. output power (W)
Nominal output (W)
Gearbox case temperature rise (°C)
Weight (g)
828100
810370
5
2
3
9,5
8,7
46
710
Made to order products, available on request
Motors :
Other supply voltages
Motor with 1 ball bearing at front (essential for vertical motor)
Shaft lengths at front and/or rear
Special interference suppression
5 pulses/revolution magnetic encoder
Other fixing flanges on front
Gearboxes :
Drawn cup needle bearing for 81 032 6
Special cover for 81 032 6
Special greasing
Special shaft
Other reduction ratios
Dimensions (mm)
808170 standard
No
Legend
2 tags IEC 760, series 4.8 x 0.5
7 across flats
Shaft pushed-in
Dimensions (mm)
Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected
02/11/2015
www.crouzet.com
808170 encoder
No
Legend
7 across flats
Shaft pushed-in
Dimensions (mm)
Gearbox shaft 79206478
No
Legend
Shaft pushed-in
Curves
Curve : torque/nominal speed 808170
02/11/2015
www.crouzet.com
Legend
No
rpm
Product adaptations
Special supply voltage
Optical or Hall effect encoder
Special connections
Special shaft
Special reduction ratio (40 ratios available from 4 to 3750)
Special materials for gears
Special ball bearings
Special adaptor plate
With 828105 or 828005 motor
With 82830 - 30 W motor
很抱歉,暂时无法提供与“80817014”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1597.42695
- 2+1567.90072
- 4+1538.37449
- 6+1479.14067
- 国内价格 香港价格
- 1+2178.530081+281.44910
- 2+1924.439672+248.62260
- 4+1888.141044+243.93310
- 6+1815.456316+234.54280
