831704C1.BL
831704C1.BL
    CROUZET(高诺斯)
    SNSW 5A .110 NONE-MSHRUM BTN
831704C1.BL 数据手册
Subminiature Switches Series 83 170 DIN 41 635 B General specifications Layout Types Components Material - Case : polyester UL 94 VO - Button : glass-filled polyamide - Contacts : AgNi, gold-plated AgNi (dual-current) - Terminals : copper-nickel Actuators - flat : stainless steel - roller : stainless steel with polyamide roller Approvals: NF - UL - cUL Operating curve For type 83 170 0 Number of operations Resistive circuit: Inductive circuit 1 2 3 Features Electrical characteristics Current rating at 250 V Nominal Thermal A A Mechanical characteristics For type 83 170 4 Number of operations { Part numbers for standard products (no lever) terminal type c L = 5 ms R a cos ϕ = 0.8 Mechanical life Resistive circuit: Inductive circuit { c L = 5 ms R a cos ϕ = 0.8 Mechanical life Operating force - max. Release force - min. Total travel force - max. Permitted overtravel force - max. Maximum rest position Tripping point Differential travel Overtravel - min. Ambient operating temperature Mechanical endurance Contact gap Weight N (oz.) N (oz.) N (oz.) N (oz.) mm (in.) mm (in.) mm (in.) mm (in.) °C Operations mm (in.) g (oz.) Contact type Rating in Amps Rating in Amps C (Form C) SPDT B (Form B) SPNC not available in PC terminals A (Form A) SPNO not available in PC terminals Connections For type 83 170 9 Number of operations Resistive circuit: Mechanical life Actuators and mounting positions Rating in Amps Part numbers for standard actuators Actuators – Length mm (in.) Mounting positions Coefficient Tripping point mm (in.) Mounting positions Model 83 170 9 is designed to operate equally well on dual-current (1 mA 4 V minimum) or medium-current (5 A maximum) circuits. However, a given product should only be used to switch one type of circuit during its working life. Except where otherwise indicated, actuators are supplied unmounted. For factory mounting, specify mounting position L or R. – To calculate force : take the force quoted for the switch and divide by the coefficient given in the table. – To calculate travel : take the travel quoted for the switch and multiply by the same coefficient. Mounting accessories for PCB mounting: 5 / 6 / 7 / 8 See page 3/9. Other information For other forces, actuators, connections and temperatures, please consult us. Normally stocked items Catalog products produced to order Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/6 1 83170.0 831700C1.0 831700C2.0 831700C3.0 83170.4 831704C1.0 831704C2.0 831704C3.0 83170.9 831709C1.0 831709C2.0 831709C3.0 83170.4 SP 4967 831704C2.MBSP 831704C3.MBSP 831704C1.MBSP 83170.4 831704C1.MB 831704C2.MB 831704C3.MB 83170.9 831709C1.MB 831709C2.MB 831709C3.MB High current Standard Low current High force Standard Low current 10 12.5 5 6 0.1 5 6 5 6 0.1 1.5 (5.3) 0.3 (1) 1.8 (6.3) 10 (35.3) 9.2 (.36) 8.4±0.3 (.33±.01) 0.15 (.006) 0.5 (.02) -20 to130 (-4 to 266) 107 0.4 (.016) 1.7 (.06) 0.6 (2.2) 0.1 (.04) 1 (3.5) 10 (35.3) 9.2 (.36) 8.4±0.3 (.33±.01) 0.15 (.006) 0.5 (.02) -20 to130 (-4 to 266) 3.107 0.4 (.016) 1.7 (.06) 0.6 (2.2) 0.1 (.04) 1 (3.5) 10 (35.3) 9.2 (.36) 8.4±0.3 (.33±.01) 0.15 (.006) 0.5 (.02) -20 to130 (-4 to 266) 3.107 0.4 (.016) 1.7 (.06) 1.5 (5.3) 0.3 (1) 1.8 (6.3) 10 (35.3) 10.8 (.425) 9.9±0.3 (.39±.01) 0.15 (.006) 0.5 (.02) -20 to130 (-4 to 266) 106 0.4 (.016) 1.7 (.06) 0.6 (2.2) 0.1 (.04) 1 (3.5) 10 (35.3) 10.8 (.425) 9.9±0.3 (.39±.01) 0.15 (.006) 0.5 (.02) -20 to130 (-4 to 266) 106 0.4 (.016) 1.7 (.06) 0.6 (2.2) 0.1 (.04) 1 (3.5) 10 (35.3) 10.8 (.425) 9.9±0.3 (.39±.01) 0.15 (.006) 0.5 (.02) -20 to130 (-4 to 266) 106 0.4 (.016) 1.7 (.06) C B A C B A C B A C B A C B A C B A 2 3 1 2 3 4 5 6 7 8 4 A 79 253 327 B 79 253 326 C 79 253 328 E 79 218 454 F 79 253 329 Flat 170A R18.3 (.72) Flat 170A R24 (.94) Flat 170A R41 (1.61) Roller 170E R20 (.79) Dummy roller 170F R19.5 (.77) L 4 11.1±1.2 (.44±.05) L 7 13.2 ±2.5 (.52 ±.1) L 3 15.4 ±1.2 (.61±.05) L 3 13 ±1.2 (.51±.05) L 3 10.4±1.2 (.41±.05) R 1.5 9.2±0.6 (.36±.24) R 2 9.6±0.6 (.38±.24) D 79 218 491 L 79 218 493 Screw 170D R20 (.79) Transverse roller 170L R20 (.79) R 3.5 10.7 ±1.2 (.42 ±.05) R 1.5 14.5 ±0.6 (.57±.24) R 1.5 12 ±0.6 (.47 ±.24) MB Ø No Actuator Characteristics available upon request. 5 To order please specify : Example : 831700 C 2 • C L 1 Switch Type 831700 831704 831709 2 Contact Type A B C To order actuators separately, use the 8 digit P/N 3 4 Connection 1 2 3 4 5 6 7 8 Actuators 5 Actuator Position L - Left (Standard) A E R - Right B F C L D MB Ø MB SP4967 Example P/N is 831700 SPDT solder terminals “C” actuator mounted on the left. Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/7 3 Subminiature Switches DIN 41635 B Dimensions 83 170 Symmetric 2.4–0.1 (.09–.001) 83 170 with MB Button 19.8 ±0.2 (.73 ±.008) 7.5 –0.2 (.3.–008) 5–0.1 (.2 –.004) R 3.6 (.14) 2.4 ±0.1 (.1±.009) 0.5 (.02–.001) Ø 2.5 ±0.1 (.1±.004) 7.62 ±0.2 (.30 ±.008) 6.35–0.2 (.25 –.008) (.37 ±.004) 6.35±0.2 (.25 ±.008) 8.9 ±0.2 (.35±.008) = 6.4 –0.2 (.25 –.008) 12.2 ±0.2 (.48 ±.008) Ø2.2 +0.1 0 (Ø .09 ±.004 0 ) 0.5 ±0.03 (x3) (.02±.001) 9.5 ±0.1 Ø 5.5 = 4 –0.1 (.157–.008) 12.2 –0.2 (.48 –.008) 9.5 –0.1 (.37 –.004) 8.9 –0.2 (.35–.008) 7.62 ±0.2 (.30 ±.008) –0.03 (x3) 2.2 ±0.1 (.09 ±.04) fl2.2 +0.1 0 (fl .09 –.004 0 ) 2.2 –0.1 (.09 –.04) fl 2.5 –0.1 (.1–.004) 9.6 –0.2 (.38 –.008) 2.4 –0.1 (.1–.009) R 2.5 (.1) 7.5 ±0.2 (.3.±008) 5±0.1 (.2 ±.004) 9.6 ±0.2 (.38 ±.008) OL = 7.6 (.30) 19.8 –0.2 (.78 –.008) 6.4 ±0.2 (.25 ±.008) 83 170 Asymmetric Mounting by M2 screws Torque : 2 cm daN mm (in) Connections Ø1.3 ±0.2 0 (.11 ±.004) 4.1±0.1 (.16 ±.004) 6.35±0.1 (.35 ±.004) (.25 ±.004) 1.C 4.NO 2.NC 6 8 7.62 ±0.1 (3x2.54) (.3 ±.004) (3x1) Ø 1.6 ±0.1 (.06 ±.004) 7.62 ±0.1 (3x2.54) (.3 ±.004) (3x1) 1.C 4.NO 2.NC mm (in) Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/8 1.3 ±0.05(.05 ±.002) 1±0.1 (.04 ±.004) 5±0.2 (2 ±.008) Symmetric 4 7 8.9 ±0.1 Ø 1.6 ±0.1 (.06 ±.004) 3.5 ±0.2 (.14 ±.008) 2.8±0.1 (.11 ±.004) Printed circuit board mounting Asymmetric 5 1.3±0.05 (.05 ±.002) 5±0.2 (2 ±.008) 4.5±0.15 (.18 ±.006) 7.1±01 (.28 +.004 ) 2.2±02 (.08 +.008 -0 ) 0 1.3 ±0.1 (.05 ±.004) 1 ±0.1(.04 ±.004) 2.4±0.15 (.1±.006) 3 30° 1.3 ±0.05(.05 ±.002) Side Output PCB Front 1±0.1 (.04 ±.004) 7-8 Side Output PCB Rear 3.4 ±0.2 (.13 ±.008) 5-6 Straight PCB 3.7±02 (.15 +.008 ) 3-4 .11x.02 Quick Connects 4.3 ±0.2 (.17 ±.008) 1 Solder 6 ±0.15 (.236 ±.006) 2 3.5 ±0.2 (.14 ±.008) Subminiature Switches DIN 41 635 B Actuators Actuator mounting positions 5.9 (.23) 11.1 (.44) ABC R TP (Tripping Point) Refer to pages 3/6 & 3/7. 6.3±0.1 (.25±.004) 6.3±0.1 (.25±.004) L 13.4±0.1 (.53±.004) 3.6±0.1 (.14±.004) F E 3 mm (in.) Mounting accessories Mounting pins 2.9 ± 0.1 (.11± .004) Output on unitboîtier side : 5: X2 Sortie côte Sortie côte couvercle Output on cover side : 7 : X3 mm (in.) Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/9
831704C1.BL 价格&库存
很抱歉,暂时无法提供与“831704C1.BL”相匹配的价格&库存,您可以联系我们找货
