84137450N
84137450N
    CROUZET(高诺斯)
    CROUZET - 84137450N - Solid State Relay, 40 A, 660 VAC, Panel Mount, Screw, Zero Crossing
84137450N 数据手册
| | 10/2020 ››GNA Series Essential Solid State Relays Panel Mount - AC Output Single Phase ››Output current of 25, 40, 50 and 90 Amps ››Output voltage of 24-280 Va and 48-660 Va ››Control voltage of 4-32 Vc ››Zero cross (resistive loads) ››Integrated IP20 touch-safe removable covers ››LED input status indicator ››Cost-effective solution Zero Cross Version Product Selection - Zero Cross (Resistive Loads) Rated Load Current Output Voltage 25A 40A 50A 90A 24-280 Va 48-660 Va 48-660 Va 48-660 Va Control Voltage 84137910N 4-32 Vc 84137450N 84137460N 84137480N PART NUMBERING SYSTEM Series 8413: Single Phase 8413 Output Voltage 9: 280 Va / Zero Cross 4: 660 Va / Zero Cross 7 9 1 Cover/Layout 7: Included Output Current 1: 25 A 5: 40 A 6: 50 A 8: 90 A Generation N: New Generation 0 N Control Voltage 0: 4-32 Vc RÉFÉRENCEMENT Série 8413: Monophasé 8413 Tension de sortie 9: 280 Va / Synchrone 4: 660 Va / Synchrone 7 9 1 Do you need an adapted or customized solution? Contact us on www.crouzet.com Description: Génération N: Nouvelle génération 0 N Crouzet Solid State Relays are designed to be used in almost any application, offering very long life expectancy and are easy to install, easy to use, Couvercle Courant Tension robust and multipurpose. 7: Inclus de sortie de commande 1: 25 A 0: 4-32 Vc For more information about Crouzet’s Solid State relays, please visit www.crouzet.com. 5: 40 A 6: 50 A 8: 90 A | | WWW.CROUZET.COM || 2 | | GNA Series | | 10/2020 Accessories Type Description Heatsink 0.9 °C/W Thermal Resistance 26532752N Heatsink 1.1 °C/W Thermal Resistance 26532753N Heatsink 1.2 °C/W Thermal Resistance 26532754N Heatsink 1.75 °C/W Thermal Resistance 26532755N Heatsink 2.2 °C/W Thermal Resistance 26532756N Adapter DIN Rail 26532764N Thermal Pad Self-Adhesive Thermal Pad 26532722N Screws Screw Mounting Kit 26532001 Thermal Grease Thermal Grease for Heatsink mounting 26532003 Part-Number Output Specifications(1) Description 25A 25 40A 50A 40 90A 50 90 96 165 347 320/_ (min) 530/_ (min) 1100/_ (min) 340 (typ) 420 (typ) 580 (typ) 1200 (typ) Maximum On-State Voltage Drop @ Rated Current [Vpeak] 1.22 1.23 1.22 1.4 Thermal Resistance Junction to Case (Rjc) [°C/W] 1.7 0.7 0.55 0.3 Maximum 1/2 Cycle I² t for Fusing @ 50 Hz (min. / typical) [A² sec] 487 882 1680 7200 Minimum Heat Sink for Rated Current @ 40 °C [°C/W] 1.3 1.05 0.85 0.33 Maximum Load Current [Arms] (3) Minimum Load Current [mArms] 5 Min / Max Operating Voltage (47-63Hz) [Vrms] 24-280 Va 48-660 Va Transient Voltage [Vpk] 600 1200 Maximum Off-State Leakage Current @ Rated Voltage [mArms] 1 Minimum Off-State dV/dt @ Maximum Rated Voltage [V/µsec] 500 1 Second Surge Current (Apk. Ta=25 °C) 50/60 Hz 100 Maximum 1 Cycle Surge Current (50/60Hz) [Apeak] Typ @ 50 Hz 270/284 (min) (2) Input Specifications Description 4-32 Vc Input Voltage Range 4-32 Vc(4) Maximum Reverse Voltage -32 Vc Minimum Turn-On Voltage 3 Vc 3.5 Vc Must Turn-Off Voltage 1 Vc 2 Vc Minimum Input Current (for on-state) 10 mA Maximum Input Current [mA] 14 mA Nominal Input Impedance [Ohms] Current Limited Maximum Turn-On Time [msec] 1/2 Cycle(5) Maximum Turn-Off Time [msec] 1/2 Cycle(5) General Specifications Description 25A Dielectric Strength, Input to Output (50/60 Hz) 4000 Vrms Dielectric Strength, Input/Output to Ground (50/60 Hz) 2500 Vrms Minimum Insulation Resistance (@ 500 Vc) 10 Ω Maximum Capacitance, Input/Output 0.8 pF Ambient Operating Temperature Range -40 to 80 °C Ambient Storage Temperature Range -40 to 100 °C 9 40A 4000 Vrms 50A 90A | | WWW.CROUZET.COM || 3 | | GNA Series | | 10/2020 General Specifications Description 25A Weight (typical) 80 g Housing Material UL94 V-0 Baseplate Material Aluminum Input Terminal Screw Torque Range (in-lb/Nm) 11-18 /1.2-2.0 Load Terminal Screw Torque Range (in-lb/Nm) 18-26 / 2-3 SSR Mounting Screw Torque Range (in-lb/Nm) 11-16 /1.2-1.8 Humidity per IEC60068-2-78 40-85% LED Input Status Indicator Green MTBF (Mean Time Between Failures) at 40 °C ambient temperature (years)(5) 72 MTBF (Mean Time Between Failures) at 60 °C ambient temperature (years)(5) 46 40A 50A 90A General Notes (1) All parameters at 25 °C unless otherwise specified (2) Output will self trigger between 450-600 Vpk not suitable for capacitive loads (3) Heat sinking required, see derating curves (4) Increase minimum voltage by 1 V for operations from -20 to -40 °C (5) All parameters at 50 % power rating and 100 % duty cycle (contact tech support for detailed report) Diagrams Wiring GNA AC V TERMINALS 1 1 (a) 2 (a) 4 (-/a) Load STRANDED Terminal Screw Torque (N.m) Input 18..14 AWG (0.75..2.5 mm²) 2 x 18..14 AWG (0.75..2.5 mm²) 18..14 AWG (0.75..2.5 mm²) 2 x 18..14 AWG (0.75..2.5 mm²) 1.2 - 2 Output 16..8 AWG (1.5..10 mm²) 2 x 16..8 AWG (1.5..10 mm²) 16..8 AWG (1.5..6 mm²) 2 x 16..10 AWG (1.5..6 mm²) 2-3 3 (+/a) Recomended overvoltage external protection: TVS Diode B WIRE SIZE SOLID | | WWW.CROUZET.COM || 4 | | GNA Series | | 10/2020 Diagrams Equivalent Circuit Block GNA Series DC control / Thyristor 40 A / 50 A / 90 A Input current vs Input Voltage Standard Regulated DC inputs 14 12 Input Current (mA) 10 8 6 4 2 0 0 2 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 20 22 24 26 28 30 32 Input Voltage (V) GNA Series DC control / Triac 25 A Input current vs Input Voltage Standard Regulated DC inputs Current Limiter 14 12 OUTPUT 10 Input Current (mA) INPUT 8 6 4 2 0 0 2 4 6 8 10 12 14 16 18 Input Voltage (V) Diagrams Dimensions (mm) GNA front view GNA side view 28 2 M5 3 47,6 59,4 16,3 29,1 Ø4,7 44,5 (±0,3) 4,7 25,4 2 M4 | | WWW.CROUZET.COM || 5 | | GNA Series | | 10/2020 Curves Surge Current Information GNA - 25 A GNA - 40 A 350 300 250 200 Itsm ( Apeak) Itsm ( Apeak) 300 100 200 150 100 50 0 0 0,01 0,1 1 T (s) 10 0,01 No Repetitive Surge Current Repetitive Surge Current 0,1 T (s) 1 10 1 10 No Repetitive Surge Current Repetitive Surge Current GNA - 50 A GNA - 90 A 1200 600 1100 1000 500 Itsm ( Apeak) Itsm ( Apeak) 900 400 300 200 800 700 600 500 400 300 200 100 100 0 0 0,01 0,1 1 T (s) 10 0,01 0,1 No Repetitive Surge Current Repetitive Surge Current T (s) No Repetitive Surge Current Repetitive Surge Current Curves Thermal Derating Curves GNA - 25 A GNA - 40 A 30 GNA - 50 A 55 45 50 40 25 45 35 40 30 15 10 35 25 Current (Arms) Current (Arms) Current (Arms) 20 20 15 10 25 20 15 10 5 0 30 5 0 0 10 20 30 40 50 60 70 80 1,1 1 5 0 10 20 2,2 2 1,75 1,5 C°/W 40 50 60 70 80 0 0 10 20 Ambient Temperature (°C) Ambient Temperature (°C) 3 30 2,2 2 1,75 1,5 C°/W 1 30 40 50 60 70 80 Ambient Temperature (°C) 0,9 0,7 2 1,75 1,5 1,1 1 0,9 0,7 C°/W Current (Arms) GNA - 90 A 95 90 85 80 75 70 65 60 55 50 45 40 35 30 25 20 15 10 5 0 0 10 20 30 40 50 60 70 80 Ambient Temperature (°C) 1,5 1,2 1,1 0,9 0,7 0,5 0,3 C°/W Warning: The product information contained in this catalogue is given purely as information and does not constitute a representation, warranty or any form of contractual commitment. Crouzet and its subsidiaries reserve the right to modify their products without notice. It is imperative that we should be consulted over any particular use or application of our products and it is the responsibility of the buyer to establish, particularly through all the appropriate tests, that the product is suitable for the use or application. Under no circumstances will our warranty apply, nor shall we be held responsible for any application (such as any modification, addition, deletion, use in conjunction with other electrical or electronic components, circuits or assemblies, or any other unsuitable material or substance) which has not been expressly agreed by us prior to the sale of our products.
84137450N 价格&库存
很抱歉,暂时无法提供与“84137450N”相匹配的价格&库存,您可以联系我们找货
