88225033
88225033
    CROUZET(高诺斯)
    TIMER RESET MEM 12H 115VAC BASE
88225033 数据手册
TIMERS TIMERS 88220 SERIES MULTIFUNCTION MOTOR TIMER WITH MEMORY UL listed CSA recognized • Five Functions in One Unit • Timing Range from 0.3 sec to 12 hours • DIN-Rail, Plug-in, or Panel Mounting DESCRIPTION: The 88220 Series is a synchronous motor driven reset timer. The timer is available in 2 standard time ranges from 0.3 sec to 12 hours. Time ranges are knob adjustable and all have a progress pointer which displays the remaining time. Different functions (ON Delay, Interval, One Shot) selectable through external wiring. FUNCTION AND WIRING DIAGRAMS: (Octal plug-in mounting shown) "ON DELAY" Maintained Start Switch 4 SPECIFICATIONS: 5 3 6 2 7 1 Start N.O. . . 24 VAC, 110 VAC, 220 VAC . . ±10%, 60 Hz . 3 VA . . 1 x SPST Relay & 1 x SPDT . . Relay . . AgCdO . . 8 Amp 1/3 HP . . 220 VAC . . 2.5 million operations . . ±1.5% (except 4% on 6 sec . . range) . . +2% (except 5% on 6 sec . . range) . . 200 ms . . -20° to +70°C (-4° to 158°F) . . -20° to +55°C (-4° to 131°F) 4 Power (Start Switch) 8 Output 5 3 6 2 7 Start N.O. Load Input Power . . . . . . . . . . . . . . ......................... Maximum power consumption Output . . . . . . . . . . . . . . . . . . . ......................... Contact material . . . . . . . . . . . Maximum loading . . . . . . . . . . Maximum switching voltage . Mechanical life of relay . . . . . Repeat accuracy . . . . . . . . . . . ......................... Setting Accuracy . . . . . . . . . . . ......................... Reset time . . . . . . . . . . . . . . . Storage temp. rating . . . . . . . Operating temp. rating . . . . . . "ON DELAY" Momentary Push Button 1 Momentary Contact 8 Delay Output Load AC Supply Delay AC Supply "INTERVAL" Maintained Start Switch 4 5 3 6 2 7 1 Start N.O. "INTERVAL" Momentary Push Button 4 Power (Start Switch) 8 5 3 6 2 7 1 Output Load Start N.O. Delay AC Supply Momentary Contact 8 Output Load Delay AC Supply Reset "ONE SHOT" CROSS REFERENCE TABLE FOR: Octal Plug Pins = Screw Terminals 4 3 6 2 7 1 Momentary Contact Load 5 8 Output AC Supply 4 6 2 Delay 1 2 3 4 5 6 7 8 5 3 7 1 8 Start N.O. DIMENSIONS: inches (mm) = = = = = = = = 24 A1 23 -16 18 A2 15 A1 15 24 23 16 18 A2 Type 88 225 0 (DIN - rail mounting) 1.48 (37.5) Type 88 226 5 (octal plug-in) with memory 1.38 (35) without memory 8 6 7 1.89 (48) .51 (13) 3.54 (90) 2.75 (70) 2.36 (60) 3.19 (81) 1.77 (45) 3.58 (91) . (5 20 .2 ) 1 2 1.17 (45) 5 1.89 (48) 4 3 2.46 (62.5) .16 (4.2) FIXED 2.16 (55) 3.03 (77) 1.97 (50) 4.05 (103) Max. Thickness of panel .39 (10) 3.27 (83) Nut M3 Type 88 226 0 (paneling mounting) 1.81 (46) 1.89 (48) 1.71 (45) Panel cut-out 1.89 (48) Max. Thickness of panel .39 (10) .47 (12) 3.94 (100) 1.81 (46) Products and specifications subject to change without notice. Consult factory for application assistance. 204 Airline Drive, Suite 300, Coppell, Texas 75019 / Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 4-8 TIMERS TIMERS TRANSIENT IMMUNITY GENERAL FEATURES: Built-in MULTI-RANGE MULTI-FUNCTION 2 model/3 time ranges each cover from 0.3 sec to 12 hours on-delay, interval and single shot in on timer CYCLE PROGRESS dial shows time remaining in cycle ±2% SETTING ACCURACY MEMORY ±1.5% REPEAT ACCURACY when “on,” holds time during power interruption 4 ADAPTER PLATE available for field interchangeability (not shown) OFF MEMORY ON TIME RANGES Model 1 (12 min.): .3 to 6 s, .5 to 12 min. Model 2 (12 hrs.): .3 to 6 min., 3 to 60 min, .5 to 12 hrs. ORDERING INFORMATION: EXAMPLE MODEL 1 (12 MIN.), 115V/60Hz, OCTAL PLUG-IN, 88 226 510 When ordering, select model, voltage/frequency and mounting to determine part number in chart below MODELING MODEL VOLTAGE/FREQ.* OCTAL PLUG-IN (PART NUMBER) PANEL MOUNTING (PART NUMBER) BASE MOUNTING (PART NUMBER) MODEL 1 MODEL 1 MODEL 1 MODEL 1 (12 (12 (12 (12 MIN.) MIN.) MIN.) MIN.) 24 V/60 Hz 115 V/60 Hz 220 V/60 Hz 220 V/50 Hz 88 226 509 88 226 510 88 226 511 88 226 504 88 226 029 88 226 030 88 226 031 88 226 011 88 225 029 88 225 030 88 225 031 88 225 011 MODEL 2 MODEL 2 MODEL 2 MODEL 2 (12 (12 (12 (12 HRS.) HRS.) HRS.) HRS.) 24 V/60 Hz 115 V/60 Hz 220 V/60 Hz 220 V/50 Hz 88 88 88 88 88 88 88 88 88 88 88 88 226 226 226 226 512 513 514 508 226 226 226 226 032 033 034 014 225 225 225 225 032 033 034 014 Products and specifications subject to change without notice. Consult factory for application assistance. 204 Airline Drive, Suite 300, Coppell, Texas 75019 / Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 4-9
88225033 价格&库存
很抱歉,暂时无法提供与“88225033”相匹配的价格&库存,您可以联系我们找货
