574410
574410
    STANNOL
574410 数据手册
Wenn’s ums Löten geht When it’s about soldering Quand il s’agit du soudage Technical Data Sheet STANNOL® - Solder Wires of the KS-Series STANNOL® KS-Series electronic solder wires have been designed for special requirements of lead-free soldering. They meet all demands of industrial manufacturing as well as for rework and repair. Description: STANNOL® solder wires KS110 and KS115 contain a rosin-free, halide activated synthetic resin. The STANNOL® KS100 is based on the same synthetic resin however it is halide free activated. All mentioned flux types are an excellent combination of high activity at thermal stress with amber bright and electrically safe residues. The flux formulations KS110 and KS115 are classified to DIN EN 29454-1 Type 1.2.2.B. Due to their high activity (1.0 and 1.5%), the fluxes are classified as REM1 to DIN EN 61190. The KS100 is classified to DIN EN 29541- Type 1.2.3.B and REL0 to DIN EN 61190. The synthetic resins offer more advantages as natural rosin: ¾ Active flux • fast wetting of solder pads and pins • shorter cycle times ¾ Bright amber residues • low thermal decomposition at soldering temperatures • optical impression ok ¾ Solid residues • high softening point • chemical and physical safety ¾ Low fuming • low decomposition and evaporation at high temperatures • low contamination of work place and around the solder joint ¾ Low spitting • high viscosity of the flux reduces spitting • low contamination Application: STANNOL® solder wires KS110 and KS115 are designed for use with robotic and manual soldering for electric and electronic devices. Flux residues may remain uncleaned. This must be examined in individual cases, where environmental stress is applied to the circuit. If cleaning is necessary for optical or technical reasons, we recommend the use of the cleaner STANNOL® Flux-Ex Ex 500. The above values are typical and represent no form of specification. The Data Sheet serves for information purposes. Any verbal or written advise is not binding for the company, whether such information originates from the company offices or from a sales representative. This is also in respect of any protection rights of third parties, and does not release the customer from the responsibility of verifying the products of the company for suitability of use for the intended process or purpose. Should any liability on the part of the company arise, the company will only indemnify for loss or damage to the same extent as for defects in quality. TDB_LD_ KS-Serie_EN Page 1 of 2 Issue: 22.06.06 STANNOL GmbH Oskarstraße 3-7 • 42283 Wuppertal • Tel. +49 (0)202-585-0 • Telefax +49 (0)202-585111 • E-Mail info@stannol.de • Web www.stannol.de Wenn’s ums Löten geht When it’s about soldering Quand il s’agit du soudage Physical Properties of the Flux: General properties KS100 EN 29454-1 KS110 KS115 1.2.3 (F-SW33) 1.2.2 (F-SW28) REL0 REM1 Flux type: EN 61190-1-1 Flux content: EN 12224 3.0 weight % ± 0.3 Halide content: EN 29455-6 Corrosivity: EN 29455-15 none Surface Insulation Resistance: 85 °C / 85 %RH, IPC TM 650 2.6.3.3 >108Ω 0.0% 1.0% 1.5% lead-free (ECOLOY® Series): ECOLOY® TC (S-Sn99Cu1) patent-free ECOLOY® TSC (Sn95,5Ag3,8Cu0,7) ECOLOY® TSC305 (Sn96,5Ag3,0Cu0,5) Standard alloys: ECOLOY® TSC263 (Sn97,1Ag2,6Cu0,3) patent-free lead-free (FLOWTIN® Series): FLOWTIN® TC (Sn99Cu1+ML) Stannol patent pending FLOWTIN® TSC (Sn95,5Ag3,8Cu0,7+ML) Stannol patent pending FLOWTIN® TSC263 (Sn97,1Ag2,6Cu0,3+ML) Stannol patent pending Available diameters: from 0.3 mm Available reel sizes: 250 g, 500 g, 1 kg Other alloys, flux contents or reel sizes are available on request. Health and Safety Detailed information about health, operational safety and disposal can be found in our material safety data sheets, which are available upon request. The above values are typical and represent no form of specification. The Data Sheet serves for information purposes. Any verbal or written advise is not binding for the company, whether such information originates from the company offices or from a sales representative. This is also in respect of any protection rights of third parties, and does not release the customer from the responsibility of verifying the products of the company for suitability of use for the intended process or purpose. Should any liability on the part of the company arise, the company will only indemnify for loss or damage to the same extent as for defects in quality. TDB_LD_ KS-Serie_EN Page 2 of 2 Issue: 22.06.06 STANNOL GmbH Oskarstraße 3-7 • 42283 Wuppertal • Tel. +49 (0)202-585-0 • Telefax +49 (0)202-585111 • E-Mail info@stannol.de • Web www.stannol.de
574410 价格&库存
很抱歉,暂时无法提供与“574410”相匹配的价格&库存,您可以联系我们找货
