310457
310457
    STANNOL
310457 数据手册
STANNOL ® Wenn’s ums Löten geht When it’s about soldering Quand il s’agit du soudage Technical Data Sheet STANNOL® Solder Sn60Pb40 and Sn63Pb37  Excellent wetting  Fast flowing solder  Excellent shape of solder joints  Shiny joints Description ® STANNOL Solder is a soft solder with alloys Sn60Pb40 and Sn63Pb37 which is even produced according to S-Sn60Pb40E or S-Sn63Pb37E (ISO 9453:2006) in most cases. Application STANNOL® SOLDER with alloys Sn60Pb40 and Sn63Pb37 is used in shape of bars and ingots for application in wave or dip soldering. Solid solder can be used in combination with fluxes for soft soldering dependent on the type of application. Fields of application are hand craft, industrial art, electric and electronics. Physical properties of Sn60Pb40 and Sn63Pb37 alloys Properties Melting point /-range Density Therm. Coefficient of Expansion Electrical Conductivity Sn60Pb40 183-190 °C 8.5 g/cm3 23.9*10-6 K-1 11.5% IACS Sn63Pb37 183 °C 8.,4 g/cm3 24.0*10-6 K-1 11.9% IACS Supply forms Solder Wire (solid and flux cored) Triangular bars Kg-bars Ingots with hanging hole Health and Safety Before using please read the material safety data sheet carefully and observe the safety precautions described. The above values are typical and represent no form of specification. The Data Sheet serves for information purposes. Any verbal or written advise is not binding for the company, whether such information originates from the company offices or from a sales representative. This is also in respect of any protection rights of third parties, and does not release the customer from the responsibility of verifying the products of the company for suitability of use for the intended process or purpose. Should any liability on the part of the company arise, the company will only indemnify for loss or damage to the same extent as for defects in quality. TDB_ME_Loetzinn_Sn60+Sn63_EN Page 1 of 1 Issue: 27.10.11 STANNOL GmbH Oskarstraße 3-7 • 42283 Wuppertal • Tel. +49 (0)202-585-0 • Telefax +49 (0)202-585111 • E-Mail info@stannol.de • Web www.stannol.de
310457 价格&库存
很抱歉,暂时无法提供与“310457”相匹配的价格&库存,您可以联系我们找货
