631900
631900
    STANNOL
631900 数据手册
STANNOL ® Wenn’s ums Löten geht When it’s about soldering Quand il s’agit du soudage Technical Data Sheet STANNOL® Solder Wire HS10 The electronic solder wire HS10 is a proven and reliable product of Stannol research, which was developed to meet high quality requirements in industrial electronic production as well as for quick rework. Description STANNOL® solder wire HS10 is very efficient by its high activity, which results in quick spread of solder and electrical safe residues. STANNOL® solder wire HS10 is a halide activated rosin (colophony) flux. STANNOL® solder wire HS10 conforms to IEC 61190-1-3 type ROM1 This activated rosin shows following properties/advantages: ¾ solid and dry residues, pin testable ¾ fast soldering, high spread speed ¾ high reliability Application STANNOL® solder wire HS10 can be used for hand and robot soldering in electronics and electrical assembly, audio devices and telecommunication. Flux residues can remain on surfaces without cleaning. If cleaning is necessary for optical or technical reasons, we recommend the use of the cleaner STANNOL® Flux-Ex 200B or STANNOL® Flux-Ex 500. Physical Properties and Data STANNOL® solder wire HS10 General properties ROM1 (IEC 61190-1-3) / 1.1.2.B (DIN EN 29454-1) / F-SW26 standard 2.5 weight % ± 0.3 % 0.9 % none, according to DIN 8516 Flux type: Flux content: Halide content: Corrosion effect: Standard alloys acc. to ISO 9453:2006 Available diameters: Available reel sizes: lead-containing: lead-free (ECOLOY® Series): S-Sn60Pb40 S-Sn60Pb39Cu1 S-Pb60Sn40 S-Sn62Pb36Ag2 from 0.3 mm 250 g, 500 g, 1 kg ECOLOY® TS (S-Sn96Ag4) ECOLOY® TSC (S-Sn95Ag4Cu1)* ECOLOY® TC (S-Sn99Cu1) ECOLOY® TSC305 (S-Sn96Ag3Cu1) * The use of this solder can mean that solder joints / soldered parts on products, which are destined for export to the USA, can become patent-protected and therefore liable to licence fees. As a licence holder, we can discharge the royalties for our clients. Please contact us. Other alloys, diameters flux contents or reel sizes are available on request. Health and Safety Before using please read the material safety data sheet carefully and observe the safety precautions described. The above values are typical and represent no form of specification. The Data Sheet serves for information purposes. Any verbal or written advise is not binding for the company, whether such information originates from the company offices or from a sales representative. This is also in respect of any protection rights of third parties, and does not release the customer from the responsibility of verifying the products of the company for suitability of use for the intended process or purpose. Should any liability on the part of the company arise, the company will only indemnify for loss or damage to the same extent as for defects in quality. TDB_LD_HS10_EN Page 1 of 1 Issue: 25.07.11 STANNOL GmbH Oskarstraße 3-7 • 42283 Wuppertal • Tel. +49 (0)202-585-0 • Telefax +49 (0)202-585111 • E-Mail info@stannol.de • Web www.stannol.de
631900 价格&库存
很抱歉,暂时无法提供与“631900”相匹配的价格&库存,您可以联系我们找货
