331030
331030
    STANNOL
331030 数据手册
Wenn’s ums Löten geht When it’s about soldering Quand il s’ agit du soudage Technical Data Sheet STANNOL® FLOWTIN® TC New Lead-Free Solder Alloy for Electronic Application • Eutectic Solder (melting point at 227°C) Good wetting behaviour Fine grain and smooth surface better than ECOLOY® TC (S-Sn99Cu1) Reduced dissolution of substrate metal compared to ECOLOY® TC (S-Sn99Cu1) Easy disposal – no lead containing waste. • • • • Application ® ® STANNOL FLOWTIN TC solders have been designed to eliminate the use of lead containing solders in ® electric and electronics manufacturing. Like with ECOLOY TC solder it is necessary to adjust machine settings, temperature profiles, and other parameters to the requirements of a lead free process. But there is ® ® nothing to do when switching from ECOLOY TC to FLOWTIN TC, all settings and parameters remain the same. The properties of the solder joints are at least comparable or even better than tin lead. ® The physical properties of FLOWTIN TC do not change compared to common tin/copper solder. But there are ® ® differences between ECOLOY TC and FLOWTIN TC with micro additives. • The solder joint solidifies as fine grain metal; therefore the surface is shinier • The dissolution of substrate metal is reduced • The extended service life of solder baths due to smaller copper enrichment Product Range ® ® STANNOL FLOWTIN TC is available as solder bars and solder wire Dissolution rate, Cu-wire at 300°C 2,00 1,80 metal removal/mm 1,60 1,40 FLOWTIN TC 0,53 µm/sec 1,20 1,00 0,80 0,60 0,40 ECOLOY TC 0,9 µm/sec 0,20 0,00 0 500 1000 1500 2000 2500 3000 3500 time/seconds ® Radial dissolution of copper wire in FLOWTIN TC solder bath @300°C The above values are typical and represent no form of specification. The Data Sheet serves for information purposes. Any verbal or written advise is not binding for the company, whether such information originates from the company offices or from a sales representative. This is also in respect of any protection rights of third parties, and does not release the customer from the responsibility of verifying the products of the company for suitability of use for the intended process or purpose. Should any liability on the part of the company arise, the company will only indemnify for loss or damage to the same extent as for defects in quality. TDB_ME_FLOWTIN_TC_EN.doc Page 1 of 2 Issue: 24.04.06 STANNOL GmbH Oskarstraße 3-7 • 42283 Wuppertal • Tel. +49 (0)202-585-0 • Telefax +49 (0)202-585111 • E-Mail info@stannol.de • Web www.stannol.de Wenn’s ums Löten geht When it’s about soldering Quand il s’agit du soudage Physical and Mechanical Properties of ECOLOY® and FLOWTIN ® solders compared with Sn63Pb37: ® Properties Melting Point /°C electrical Conductivity %IACS electrical resistivity / µΩ Ω cm Brinell Hardness, HB Density /g cm -3 Tensile strength, (20°C) / N mm 2 at 0,004 s 1 Shear rate Shear Strength N mm 2 -1 at 0,1mm , 20°C at 0,1mm 1, 100°C Creep Resistance* N mm 2 20°C 100°C ® ® S-Sn63Pb37 STANNOL ECOLOY TSC (Sn95,5Ag3,8Cu0,7) STANNOL ® ECOLOY TS (S-Sn96Ag4) STANNOL ® ECOLOY TC (S-Sn99Cu1) STANNOL ® FLOWTIN TC 183 217 221 227 227 11,9 13 14 - - 14,5 13 12,3 - - 17 15 15 - - 8,4 7,5 7,5 7,3 7,3 40 48 58 48 - 23 14 27 17 27 17 23 16 23 16 3,3 1,0 13,0 5,0 13,7 5,0 13,7 5,0 8,6 2,1 ® Recommended Conditions of Use Wave soldering ® The recommended operation conditions for wave soldering are the same like normal ECOLOY TC solders, since the melting point remains! Purity Sn99Cu1, Solder to DIN EN 61190-1-3 and DIN EN 29453 / ISO 9453 Contains pure tin with 0,7%Cu and micro-additives Delivery Forms ® ® STANNOL FLOWTIN TC is available as bars and sticks or as wire for wave soldering, for rework and repair application as well as for robotic processes. Health and Safety Information about Health and Safety and Disposal of used products can be found in our Safety data Sheet, which is available on request. The above values are typical and represent no form of specification. The Data Sheet serves for information purposes. Any verbal or written advise is not binding for the company, whether such information originates from the company offices or from a sales representative. This is also in respect of any protection rights of third parties, and does not release the customer from the responsibility of verifying the products of the company for suitability of use for the intended process or purpose. Should any liability on the part of the company arise, the company will only indemnify for loss or dam age to the same extent as for defects in quality. TDB_ME_FLOWTIN_TC_EN.doc Page 2 of 2 Issue: 24.04.06 STANNOL GmbH Oskarstraße 3-7 • 42283 Wuppertal • Tel. +49 (0)202-585-0 • Telefax +49 (0)202-585111 • E-Mail info@stannol.de • Web www.stannol.de
331030 价格&库存
很抱歉,暂时无法提供与“331030”相匹配的价格&库存,您可以联系我们找货
  • 1+385.30401
  • 5+344.74944
  • 10+337.85588
库存:253
