535768
535768
    STANNOL
535768 数据手册
STANNOL TECHNICAL DATA SHEET SOLDER WIRE HS10 developed to meet high quality requirements in industrial electronic production as well as quick rework DESCRIPTION The electronic solder wire HS10 is a proven and reliable product of Stannol research, which was developed to meet high quality requirements in industrial electronic production as well as for quick rework. The solder wire HS10 is very efficient by its high activity, which results in quick spread of solder and electrical safe residues. It is a halide activated rosin (colophony) flux. The solder wire HS10 conforms to IEC 61190-1-3 type ROM1 CHARACTERISTICS This activated rosin shows following properties/advantages:  Solid and dry residues, pin testable  Fast soldering, high spread speed  High reliability APPLICATION The solder wire HS10 can be used for hand and robot soldering in electronics and electrical assembly, audio devices and telecommunication. Flux residues can remain on surfaces without cleaning. If cleaning is necessary for optical or technical reasons, we recommend the use of the cleaner Stannol Flux-Ex 200B or Stannol Flux-Ex 500. PHYSICAL PROPERTIES AND DATA GENERAL PROPERTIES Flux type: HS10 ROM1 (IEC 61190-1-3) / 1.1.2.B (DIN EN 29454-1) / F-SW26 Flux content: standard 2,5 weight % ± 0,3 % Halide content: 0,9% Corrosion effect: none, acc. to DIN 8516 Lead-containing: Standard alloys acc. to ISO 9453:2006 Lead-free (Ecoloy Serie) S-Sn60Pb40 Ecoloy TS (S-Sn96Ag4) S-Sn60Pb39Cu1 Ecoloy TSC (S-Sn95Ag4Cu1) S-Pb60Sn40 Ecoloy TC (S-Sn99Cu1) S-Sn62Pb36Ag2 Ecoloy TSC305 (S-Sn96Ag3Cu1) S-Sn63Pb37* --- S-Pb93Sn5Ag2 --- Available diameters: from 0,3 mm Available reel sizes: 250 g, 500 g, 1 kg * This alloy is subject to a MOQ Other alloys, diameters flux contents or reel sizes are available on request. STANNOL GmbH • TDB_LD_HS10_EN • Issue: 25.08.14 Haberstr. 24 • 42551 Velbert • Tel: +49 (0)2051-3120-0 • Fax: +49 (0)2051-3120-111 • E-Mail: info@stannol.de • www.stannol.de 1 HEALTH AND SAFETY Before using please read the material safety data sheet carefully and observe the safety precautions described. NOTICE The above values are typical and represent no form of specification. The Data Sheet serves for information purposes. Any verbal or written advise is not binding for the company, whether such information originates from the company offices or from a sales representative. This is also in respect of any protection rights of third parties, and does not release the customer from the responsibility of verifying the products of the company for suitability of use for the intended process or purpose. Should any liability on the part of the company arise, the company will only indemnify for loss or damage to the same extent as for defects in quality. STANNOL GmbH • TDB_LD_HS10_EN • Issue: 25.08.14 Haberstr. 24 • 42551 Velbert • Tel: +49 (0)2051-3120-0 • Fax: +49 (0)2051-3120-111 • E-Mail: info@stannol.de • www.stannol.de 2
535768
1. 物料型号:型号为EL817,是一款光隔离型光电晶体管。
2. 器件简介:EL817是一种光隔离型光电晶体管,具有高输入阻抗和低输出阻抗,适用于高速光耦合器。
3. 引脚分配:EL817有3个引脚,分别为阳极、阴极和发射极。
4. 参数特性:主要参数包括最大正向电流150mA,最大反向电压5V等。
5. 功能详解:EL817通过光电效应实现电信号的传输,具有隔离作用,可应用于高速光耦合器。
6. 应用信息:EL817适用于高速光耦合器、光电开关等应用。
7. 封装信息:EL817采用DIP-6封装。
535768 价格&库存
很抱歉,暂时无法提供与“535768”相匹配的价格&库存,您可以联系我们找货
