FD 150/E
FD 150/E
    PROXXON
    PROXXON - FD 150/E - PRECISION LATHE, 360X150X150MM, 4.5KG
FD 150/E 数据手册
Light, stable and precise. 2-stage belt drive and additional electronic 5,000rpm. The right cutting speed for even the smallest pieces. Precision lathe FD 150/E For face turning, longitudinal turning, boring, taper turning, slicing and drilling. Complete with 3-jaw chuck and live centre. / DM 07817 5 Al l XO N Design Patent r igh ts by PROX Centre distance 150mm. Swing 55mm. Height over cross slide 33mm. Machine bed with dovetail guides of continuous casting aluminium. Die-cast aluminium spindle headstock. With quiet special DC motor, 2-stage belt drive and additional electronic speed control for high engine power at low speeds for larger work pieces and for the appropriate cutting speed, even for the smallest pieces. Main switch with emergency stop function and restart protection. Precision bearing mounted main spindle with continuous 8.5mm bore. Chuck fit for standard ER 11 type collets. Three-jaw chuck, self-centering (inside jaws 1.5 – 32mm), outside jaws 20 – 60mm). Die-cast aluminium tailstock with spindle and live centre (fitting MK 0/ short). Processing via top slide (60mm, travel distance Z) and cross slide (40mm, travel distance X). The angle adjustment of the upper carriage makes it possible to turn tapers up to +/- 45°. Handwheels with zero adjustable scale ring (1 division = 0.05mm, 1 revolution = 1.0mm). Other technical data: 220 – 240V. 50/60Hz. Distance between centres 150mm. Swing 55mm. Height over cross slide 33mm. Cross slide travel (X) 40mm, top slide travel (Z) 60mm. Steel tool post for turning steels 6 x 6mm. Spindle bore 8.5mm. 2-stage belt drive with electronic speed control: Stage 1 = 800 – 2,800rpm. Stage 2 = 1,500 – 5,000rpm. Dimensions approx. 360 x 150 x 150mm. Weight 4.5kg. Insulated to class 1. NO 24 150 Support: To be shifted manually on the bed and clamped with lever. Rotating tool post for turning steels 6 x 6mm. 52
FD 150/E
- 物料型号:FD 150/E - 器件简介:精密车床,适用于面车、纵向车、镗孔、锥形车、切片和钻孔等操作。配备三爪自定心卡盘和活顶尖。 - 引脚分配:主轴头采用铝合金铸造,配备静音特殊直流电机,双级皮带驱动和额外的电子速度控制。 - 参数特性: - 中心距:150mm - 摆动:55mm - 过横滑板高度:33mm - 横滑板行程(X轴):40mm - 上滑板行程(Z轴):60mm - 转速范围:第一阶段800-2800rpm,第二阶段1500-5000rpm - 功能详解:车床设计用于实现高精度加工,具有零位可调刻度手轮(1格=0.05mm,1圈=1.0mm)。 - 应用信息:适用于加工各种材料,包括钢材料。 - 封装信息:220-240V,50/60Hz,尺寸约为360 x 150 x 150mm,重量4.5kg,绝缘等级1。
FD 150/E 价格&库存
很抱歉,暂时无法提供与“FD 150/E”相匹配的价格&库存,您可以联系我们找货
