BIM2004/IP-GY
BIM2004/IP-GY
    CAMDENBOSS
BIM2004/IP-GY 数据手册
U N I V E R SA L E N C LOS U R E S 268 HANDHELD CASES DIECAST DIECAST ACCESSORIES ACCESSORIES 2000 series general purpose ABS cases Product overview 292 UNIVERSAL ENCLOSURES BIM2001 Extensive range of electronic enclosures with solid ABS lid, designed for a broad range of applications. 318 HEAVY DUTY AND ELECTRICAL ENCLOSURES • Lid and base moulded in ABS • Brass inserts in base for repetitive removal of the lid (*except for 2000, 2007 or 2008 sizes) • High gloss polished finish • Excellent properties for machining • Integral mounting guides to accept 1.6mm PCBs • Available in other colours on request (subject to MOQ) • 2000 series has been designed to meet the requirements of IP54 342 DESKTOP AND INSTRUMENT CASES 348 DEVELOPMENT BOARD ENCLOSURES 367 VERSATILE IOT AND SENSOR ENCLOSURES S P E C I F I C AT I O N H L L W Materials Lid and base high impact ABS UL94-HB Operating temperature -5°C to 80°C Protection class 2000 series has been designed to meet the requirements of IP54 Standard colours Grey (GY), black (BLK), white (WH), orange (ORG) Standard unit includes Base and lid Lid screws as below Required torque setting 10 cNm (0.1Nm) Options (MOQs apply) Different colours / materials / UL94-V0 Available accessories BIM adapter (PCB adapter for horizontal PCB mounting) BIM stap (only fits BIM2006/16) 370 CUSTOM SIZED ENCLOSURES GREY B L AC K WHITE ORANGE SCREWS LENGTH W I DT H HEIGHT *BIM2008/18-GY/GY *BIM2008/18-BLK/BLK *BIM2008/18-WH/WH *BIM2008/18-ORG/ORG No2 x 5/16 CSK self tapping x 4pcs 55mm 55mm 42mm *BIM2000/10-GY/GY *BIM2000/10-BLK/BLK *BIM2000/10-WH/WH *BIM2000/10-ORG/ORG No2 x 5/16 CSK self tapping x 4pcs 75mm 50mm 27mm BIM2001/11-GY/GY BIM2001/11-BLK/BLK BIM2001/11-WH/WH BIM2001/11-ORG/ORG M3 x 10 CSK pozi screws x 4pcs 85mm 56mm 39mm BIM2002/12-GY/GY BIM2002/12-BLK/BLK BIM2002/12-WH/WH BIM2002/12-ORG/ORG M3 x 10 CSK pozi screws x 4pcs 100mm 50mm 25mm BIM2003/13-GY/GY BIM2003/13-BLK/BLK BIM2003/13-WH/WH BIM2003/13-ORG/ORG M3 x 10 CSK pozi screws x 4pcs 112mm 62mm 31mm *BIM2007/17-GY BIM2007/17-BLK BIM2007/17-WH/WH - No2 x 5/16 CSK self tapping x 4pcs 112mm 62mm 31mm BIM2004/14-GY/GY BIM2004/14-BLK/BLK BIM2004/14-WH/WH BIM2004/14-ORG/ORG M3 x 10 CSK pozi screws x 4pcs 120mm 65mm 40mm RTM2030/30-GY RTM2030/30-BLK RTM2030/30-WH/WH - M3 x 10 CSK pozi screws x 4pcs 142mm 80mm 30mm BIM2005/15-GY/GY BIM2005/15-BLK/BLK BIM2005/15-WH BIM2005/15-ORG/ORG M3 x 10 CSK pozi screws x 4pcs 150mm 80mm 50mm BIM2006/16-GY/GY BIM2006/16-BLK/BLK BIM2006/16-WH/WH BIM2006/16-ORG/ORG M3 x 10 CSK pozi screws x 6pcs 190mm 110mm 60mm BIM2009/19-GY/GY BIM2009/19-BLK/BLK BIM2009/19-WH/WH - M3 x 10 CSK pozi screws x 8pcs 250mm 200mm 65mm *Brass inserts not included in 2000, 2007 or 2008 sizes P L AST I C E N C LOS U R E S K E Y F E AT U R E S Polished finish | Horizontal PCB mounting | Moulded in ABS +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers Vers41 297 U N I V E R SA L E N C LOS U R E S 268 HANDHELD DIECASTCASES ACCESSORIES 292 UNIVERSAL ENCLOSURES 2000 series general purpose ABS cases - flanged Product overview 318 HEAVY DUTY AND ELECTRICAL ENCLOSURES 342 DESKTOP AND INSTRUMENT CASES 348 DEVELOPMENT BOARD ENCLOSURES 367 BIM2000 For applications requiring surface or wall mounting and protection against dust and water ingress. Provides extra security once mounted by restricting access to the screws in the lid. • Flanged lid and base moulded in ABS • High gloss polished finish • Brass inserts in base for repetitive removal of the lid (*except for 2000 or 2008 sizes) • Excellent properties for machining • Integral mounting guides to accept 1.6mm PCBs • Plastic standoffs in lid for PCB mounting • Available in other colours on request (subject to MOQ) • 2000 series flanged has been designed to meet the requirements of IP54 and IP65 with gasket accessory VERSATILE IOT AND SENSOR ENCLOSURES S P E C I F I C AT I O N 370 Materials Lid and base high impact ABS UL94-HB Operating temperature -5°C to 80°C Protection class 2000 series flanged has been designed to meet the requirements of IP54 or additionally, IP65 with the gasket accessory Standard colours Grey (GY) and black (BLK) Standard unit includes Base and flanged lid Lid screws as below Required torque setting 10 cNm (0.1Nm) Options (MOQs apply) Different colours / materials / UL94-V0 Available accessories IP65 gasket kits BIM adapter (PCB adapter for horizontal PCB mounting) BIM stap (only fits BIM2006/16) CUSTOM SIZED ENCLOSURES IP65 gasket kits GREY B L AC K SCREWS LENGTH W I DT H HEIGHT PA R T N O . DESCRIPTION *BIM2008/IP-GY *BIM2008/IP-BLK No2 x 5/16 CSK self tapping x 4pcs 78.3mm 57.3mm 43mm SA00 2000/IP gasket kit *BIM2000/IP-GY *BIM2000/IP-BLK No2 x 5/16 CSK self tapping x 4pcs 99mm 52mm 28mm SA1-5 BIM2001/IP-GY BIM2001/IP-BLK M3 x 10 CSK pozi screws x 4pcs 105mm 58mm 39.5mm 2001/IP, 2002/IP, 2003/IP, 2004/IP, 2005/IP, 2030/IP gasket kit BIM2002/IP-GY BIM2002/IP-BLK M3 x 10 CSK pozi screws x 4pcs 123mm 52mm 25.5mm SA6 2006/IP gasket kit BIM2003/IP-GY BIM2003/IP-BLK M3 x 10 CSK pozi screws x 4pcs 136mm 64.6mm 31.5mm SA8 2008/1P gasket kit BIM2004/IP-GY BIM2004/IP-BLK M3 x 10 CSK pozi screws x 4pcs 143.3mm 67.3mm 40.3mm BIM2030/IP-GY BIM2030/IP-BLK M3 x 10 CSK pozi screws x 4pcs 167mm 84mm 31mm BIM2005/IP-GY BIM2005/IP-BLK M3 x 10 CSK pozi screws x 4pcs 173.4mm 82.4mm 50.5mm BIM2006/IP-GY BIM2006/IP-BLK M3 x 10 CSK pozi screws x 6pcs 213mm 112.3mm 60.7mm *Brass inserts not included in 2000 or 2008 sizes K E Y F E AT U R E S P L AST I C E N C LOS U R E S IP65 flanged lid | PCB mounting | Base moulded in ABS 298 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 2 14 U N I V E R SA L E N C LOS U R E S 268 HANDHELD CASES DIECAST DIECAST ACCESSORIES ACCESSORIES 2000 series general purpose ABS cases - lugged lid Product overview 292 UNIVERSAL ENCLOSURES BIM2005 Electronic enclosures with lugged lid, for a broad range of surface mounting applications. Provides extra security once mounted by restricting access to the screws in the lid. 318 HEAVY DUTY AND ELECTRICAL ENCLOSURES • Lugged lid and base moulded in ABS • High gloss polished finish • Brass inserts in base for repetitive removal of the lid • Excellent properties for machining • Integral mounting guides to accept 1.6mm PCBs • Available in other colours on request (subject to MOQ) • 2000 series has been designed to meet the requirements of IP54 342 DESKTOP AND INSTRUMENT CASES 348 DEVELOPMENT BOARD ENCLOSURES 367 S P E C I F I C AT I O N VERSATILE IOT AND SENSOR ENCLOSURES Materials Lid and base high impact ABS UL94-HB Operating temperature -5°C to 80°C Protection class 2000 series has been designed to meet the requirements of IP54 Standard colours Grey (GY) Black (BLK) White (WH) 370 CUSTOM SIZED ENCLOSURES Standard unit includes Base and lugged lid Lid screws as below Required torque setting 10 cNm (0.1Nm) Options (MOQs apply) Different colours / materials / UL94-V0 Available accessories BIM adapter (PCB adapter for horizontal PCB mounting) GREY B L AC K WHITE SCREWS LENGTH W I DT H HEIGHT BIM2003/LUG-GY/GY BIM2003/LUG-BLK/BLK BIM2003/LUG-WH/WH M3 x 10 CSK pozi screws x 4pcs 131.5mm 62mm 31mm BIM2004/LUG-GY/GY BIM2004/LUG-BLK/BLK BIM2004/LUG-WH/WH M3 x 10 CSK pozi screws x 4pcs 139mm 65mm 40mm BIM2005/LUG-GY/GY BIM2005/LUG-BLK/BLK BIM2005/LUG-WH/WH M3 x 10 CSK pozi screws x 4pcs 171.5mm 80mm 50mm K E Y F E AT U R E S P L AST I C E N C LOS U R E S Polished finish | Horizontal PCB mounting | Moulded in ABS +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers Vers41 299 U N I V E R SA L E N C LOS U R E S 268 HANDHELD DIECASTCASES ACCESSORIES 292 UNIVERSAL ENCLOSURES 2000 series general purpose ABS cases - deep profile Product overview 318 HEAVY DUTY AND ELECTRICAL ENCLOSURES 342 DESKTOP AND INSTRUMENT CASES 348 DEVELOPMENT BOARD ENCLOSURES 367 VERSATILE IOT AND SENSOR ENCLOSURES 370 BIM2005/25 Multi-purpose enclosures for application where extra height is required. The deep profile 2000 series provides increased internal volume. • Deep profile lid and base moulded in ABS • Brass inserts in base for repeated removal of the lid • Excellent properties for machining • Integral mounting guides in base to accept 1.6mm PCB’s • Available in other colours on request (subject to MOQ) • 2000 series has been designed to meet the requirements of IP54 S P E C I F I C AT I O N Materials Lid and base high impact ABS UL94-HB Operating temperature -5°C to 80°C Protection class 2000 series has been designed to meet the requirements of IP54 Standard colours Grey (GY), black (BLK), white (WH) Standard unit includes Base and deep profile lid Lid screws as below Required torque setting 10 cNm (0.1Nm) Options (MOQs apply) Different colours / materials / UL94-V0 Available accessories BIM adapter (PCB adapter for horizontal PCB mounting) BIM stap (only fits BIM2006/16) CUSTOM SIZED ENCLOSURES B L AC K WHITE SCREWS LENGTH W I DT H HEIGHT BIM2002/22-GY/GY BIM2002/22-BLK/BLK BIM2002/22-WH/WH M3 x 10 CSK pozi screws x 4pcs 100mm 50mm 40mm BIM2004/24-GY/GY BIM2004/24-BLK/BLK BIM2004/24-WH/WH M3 x 10 CSK pozi screws x 4pcs 120mm 65mm 60mm BIM2005/25-GY/GY BIM2005/25-BLK/BLK BIM2005/25-WH/WH M3 x 10 CSK pozi screws x 4pcs 150mm 80mm 76mm BIM2006/26-GY/GY BIM2006/26-BLK/BLK BIM2006/26-WH/WH M3 x 10 CSK pozi screws x 6pcs 190mm 110mm 90mm P L AST I C E N C LOS U R E S GREY 300 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers1 3 Vers U N I V E R SA L E N C LOS U R E S 268 HANDHELD CASES DIECAST DIECAST ACCESSORIES ACCESSORIES 2000 series general purpose ABS cases - EMC Product overview 292 UNIVERSAL ENCLOSURES BIM2001 A range of enclosures with conductive coating for enhanced electro-magnetic compatibility (EMC). 318 HEAVY DUTY AND ELECTRICAL ENCLOSURES • • • • Lid and base moulded in ABS Graphite grey paint finish Conductive coating Brass inserts in base for repetitive removal of the lid (*except for 2000, 2007 or 2008 sizes) • Excellent properties for machining • Integral mounting guides to accept 1.6mm PCBs • 2000 series has been designed to meet the requirements of IP54 342 DESKTOP AND INSTRUMENT CASES 348 DEVELOPMENT BOARD ENCLOSURES 367 VERSATILE IOT AND SENSOR ENCLOSURES S P E C I F I C AT I O N Materials Lid and base high impact ABS UL94-HB Operating temperature -5°C to 80°C Protection class 2000 series has been designed to meet the requirements of IP54 Standard colours Graphite grey Standard unit includes Base and lid Lid screws as below Required torque setting 10 cNm (0.1Nm) Options (MOQs apply) Different colours / materials / UL94-V0 Available accessories BIM adapter (PCB adapter for horizontal PCB mounting) BIM stap (only fits BIM2006/16) 370 CUSTOM SIZED ENCLOSURES GREY SCREWS LENGTH W I DT H HEIGHT *BIM2008/18-EMI/RFI No2 x 5/16 CSK self tapping x 4pcs 55mm 55mm 42mm *BIM2000/10-EMI/RFI No2 x 5/16 CSK self tapping x 4pcs 75mm 50mm 27mm BIM2001/11-EMI/RFI M3 x 10 CSK pozi screws x 4pcs 85mm 56mm 39mm BIM2002/12-EMI/RFI M3 x 10 CSK pozi screws x 4pcs 100mm 50mm 25mm BIM2003/13-EMI/RFI M3 x 10 CSK pozi screws x 4pcs 112mm 62mm 31mm *BIM2007/17-EMI/RFI No2 x 5/16 CSK self tapping x 4pcs 112mm 62mm 31mm BIM2004/14-EMI/RFI M3 x 10 CSK pozi screws x 4pcs 120mm 65mm 40mm BIM2005/15-EMI/RFI M3 x 10 CSK pozi screws x 4pcs 150mm 80mm 50mm BIM2006/16-EMI/RFI M3 x 10 CSK pozi screws x 6pcs 190mm 110mm 60mm BIM2009/19-EMI/RFI M3 x 10 CSK pozi screws x 8pcs 250mm 200mm 65mm *Brass inserts not included in 2000, 2007 or 2008 sizes K E Y F E AT U R E S P L AST I C E N C LOS U R E S Conductive graphite paint finish | Shielded | Moulded in ABS ACC E SS O R I E S BIM adapter • For horizontal PCB mounting • Suitable for all BIM2000 series enclosures PA R T N O . DESCRIPTION BIM/ADAPTER BIM adapter (PCB adapter for horizontal PCB mounting) BIM STRAP BLK BIM Strap for BIM2006 black BIM STRAP GY BIM Strap for BIM2006 grey BIM STRAP ORG BIM Strap for BIM2006 orange BIM STRAP WH BIM Strap for BIM2006 white +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers Vers41 301
BIM2004/IP-GY
1. 物料型号:文档列出了多个型号的电子外壳,包括BIM2001、BIM2002、BIM2003等,每个型号都有不同的尺寸和颜色选项。
2. 器件简介:这些电子外壳采用高冲击ABS UL94-HB材料制成,设计用于广泛的应用,包括IP54防护等级的2000系列。
3. 引脚分配:部分型号提供了用于横向PCB安装的集成安装指南。
4. 参数特性:外壳的操作温度范围为-5°C至80°C,标准颜色包括灰色、黑色、白色和橙色。部分型号还提供了IP65防护等级的配件。
5. 功能详解:文档详细介绍了外壳的特点,如抛光完成、ABS内模、塑料支撑柱用于PCB安装等。
6. 应用信息:这些外壳适用于需要表面或墙面安装并防止灰尘和水侵入的应用,提供了额外的安全性。
7. 封装信息:提供了不同尺寸的外壳,包括长度、宽度和高度的详细规格。
BIM2004/IP-GY 价格&库存
很抱歉,暂时无法提供与“BIM2004/IP-GY”相匹配的价格&库存,您可以联系我们找货
BIM2004/IP-GY
    • 1+76.90619
    库存:13
