ACC E SS O R I E S
SOCKETS
PLUGS
CIRCULAR CONNECTORS
002
PCB TERMINAL
DIECAST
DIECAST
BLOCKS
ACCESSORIES
ACCESSORIES
Push-pull connectors female
fixed socket CCE series
CCE2S1/07
7 pole
CCE2S1/07
• Premium range of circular connectors
• IP68 sealed using vacuum technology
(when connected and using
environmental cable clamp)
• Tough, high performance interconnection
solution
• Ideal for harsh and extreme environments
• Suitable for broadcasting, autosport,
military, rail, marine, security, industrial
and agricultural applications
• Key coded to prevent misconnection
• Will not disconnect when the cable is
under load or stress
• Tool slots for secure and tight mounting
• Tested to IEC 60512-3-5a
081
TERMINAL STRIPS
S P E C I F I C AT I O N
Shell style/model
DBEU type fixed socket,
female contact
Codes
Code 1
Contact type
Solder type
Contact diameter
0.7mm
Max. stranded conductor
AWG 21-22
Max diameter
0.79mm
Vtest (contact-shell)
1000V(AC)
2000V(DC)
Vtest (contact-contact)
1300V(AC)
2000V(DC)
Rated current
5.0A
Rated voltage
≤250V
095
WIRE TO BOARD
CONNECTORS
100
CIRCULAR
CONNECTORS
151
IP68 CONNECTORS
PA R T N O .
DESCRIPTION
POLES
SERIES
Mechanical operation
5000 mating cycles
CCE2S1/07
Female fixed
socket
07
CCE
series
Housing material
Brass (natural chrome
plated) shell and collet nut,
nickel plated brass latch
sleeve and mid pieces
Insulator
PPS
Contacts
Brass (gold plated)
Humidity (max)
72 hr
Climatical category
50/175/21
Shielding (min)
75 dB (10 MHz)
Shielding (min)
40 dB (1 GHz)
IP rating
IP68 (when connected
and using
~ 23
Ø18
M14*1
13
17
14
0-4
3
158
INTERFACE
MODULES AND
RELAY BASES
K E Y F E AT U R E S
Key coded
| Panel mounting socket
ACC E SS O R I E S
Metal and rubber caps for sockets
| Raised plug for location in low light conditions
PA R T N O .
DESCRIPTION
CCT21
Camcirc metal cap for sockets A2
PA R T N O .
DESCRIPTION
CCT22
Camcirc rubber cap for sockets A2
C C A 2 P 1 /A 0 7
- C C A S e r i e s A 2 s i z e p l u g
CONNECT
A S S O C I AT E D P R O D U C T S
page 111
+44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com
We operate a constant improvement policy, our products are subject to change without notice.
FM 28614
Vers 1
143
很抱歉,暂时无法提供与“CCE2S1/07”相匹配的价格&库存,您可以联系我们找货
