CIRCULAR CONNECTORS
PLUGS
SOCKETS
ACC E SS O R I E S
002
PCB
TERMINAL
DIECAST
BLOCKS
ACCESSORIES
081
TERMINAL STRIPS
095
WIRE TO BOARD
CONNECTORS
100
CIRCULAR
CONNECTORS
151
IP68 CONNECTORS
158
Push-pull connectors female
fixed socket CCB series
CCB2S1/04
4 pole
CCB2S1/04
• Premium range of circular connectors
• IP68 sealed using vacuum technology
(when connected and using
environmental cable clamp)
• Tough, high performance interconnection
solution
• Compact panel mounting design
• Ideal for harsh and extreme environments
• Suitable for broadcasting, autosport,
military, rail, marine, security, industrial
and agricultural applications
• Key coded to prevent misconnection
• Will not disconnect when the cable is
under load or stress
• Tested to IEC 60512-3-5a
S P E C I F I C AT I O N
Shell style/model
D type fixed socket, female
contact
Codes
Code 1
Contact type
Solder type
Contact diameter
0.9mm
Max. stranded conductor
AWG 21-22
Max diameter
1.18mm
Vtest (contact-shell)
1100V(AC)
1900V(DC)
Vtest (contact-contact)
1400V(AC)
2200V(DC)
Rated current
7.0A
Rated voltage
≤250V
PA R T N O .
DESCRIPTION
POLES
SERIES
Mechanical operation
5000 mating cycles
CCB2S1/04
Female fixed
socket
04
CCB
series
Housing material
Brass (natural chrome
plated) shell and collet nut,
nickel plated brass latch
sleeve and mid pieces
Insulator
PPS
Contacts
Brass (gold plated)
Humidity (max)
72 hr
Climatical category
50/175/21
Shielding (min)
75 dB (10 MHz)
Shielding (min)
40 dB (1 GHz)
IP rating
IP68 (when connected
and using
INTERFACE
MODULES AND
RELAY BASES
23
0 min - 8 max
Ø14
M12*1.0
1.5
14
K E Y F E AT U R E S
Key coded
| Panel mounting socket
| Flat face
ACC E SS O R I E S
Metal and rubber caps for sockets
Low profile
PA R T N O .
DESCRIPTION
CCT21
Camcirc metal cap for sockets A2
CONNECT
A S S O C I AT E D P R O D U C T S
134
C C A 2 P 1 /A 0 4
- C C A S e r i e s A 2 s i z e p l u g
page 108
+44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com
We operate a constant improvement policy, our products are subject to change without notice.
Vers 1
FM 28614
很抱歉,暂时无法提供与“CCB2S1/04”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+193.34330
- 5+189.46936
