CFTBN
Call our sales team today on +44 (0)1638 716101
5 x 2 0 m m F u s e d Te r m i n a l B l o c k s
Product Overview
1 - 5 pole terminal strip with 5x20mm fuseholder
Integral spare fuse carrier
Interlocking fuseholder with CFTBN/1
Anti-rotation spigot
Cable entry 4mm2 (2.5mm2 with wire protector)
Wire protector on fuse terminal as standard
Wire protectors on earth pole to order
UL approved - UL 1059
CSA approved
Te c h n i c a l D a t a
S P E C I F I C AT I O N
Rating
Fuseholder 250V AC / Terminal 450V AC
Current Rating
Fuseholder 13A / Terminal 20A
Moulding
UL94-V0 Flame Retardant PA66
Terminal
Brass, nickel plated
Fuse clip
Phosphor bronze
Wire protector
Stainless steel
Operating Temperature
-20° to 120°C
Fuse Size
5x20mm glass or ceramic
Screws
Steel zinc plated M3, 0.5Nm
GWIT
775°C
Cable CSA
F U S E D T E R M I N A L B LO C KS
P/ N R E F.
01
Te c h n i c a l D r a w i n g
CFTBN/5
DESCRIPTION
CFTBN/x
Fused Terminal Block, M3 fixing hole and screw/washer
CFTBN/xNE
CFTBN/xWP
Fused Terminal Block, wire protected terminals, no M3 fixing hole
CFTBN/xEWP
Fused Terminal Block, wire protected terminals, M3 fixing hole with
screw/washer
CFTBN/xEWPG
Fused Terminal Block, wire protected terminals/Earth, M3 fixing hole
with screw/washer
FUSE WIRE
PROTECTOR
Accessory for CFTBN
CFTBN/1
16.1 mm
Screw/dust protection
CFTBN/2
20.6 mm
Easily cut to required size
CFTBN/3
30.8 mm
CFTBN/4
40.7 mm
CFTBN/5
50.9 mm
CFTBN/3NE
30.8 mm
CFTBN/4NE
40.7 mm
CFTBN/5NE
50.9 mm
CFTBN/3NS
30.8 mm
CFTBN/4NS
40.7 mm
CFTBN/5NS
50.9 mm
CFTBN/2WP
20.6 mm
CFTBN/3WP
30.8 mm
CFTBN/4WP
40.7 mm
M3 FIXING
HOLE
EARTH
WIRE
PROTECTED
WIRE
PROTECTED
TERMINALS
Te r m i n a l C o v e r
B O DY
DIMENSIONS
(LENGTH)
PA R T N O .
FIXING
SCREW &
WA S H E R S
GENERAL TOLERANCE OF ±0.20mm
PA R T N O .
POLES
CFTBN/3C
3 pole cover
CFTBN/5C
5 pole cover
CFTBN/5WP
50.9 mm
CFTBN/3EWP
30.8 mm
CFTBN/4EWP
40.7 mm
R E L AT E D
PRODUCTS
CFTBN/5EWP
50.9 mm
CFB0520F
Glass 5x20mm quick blow fuses
CFTBN/3EWPG
30.8 mm
CFB0520T
Glass 5x20mm time delay fuses
CFTBN/4EWPG
40.7 mm
CFB0521CF
Ceramic 5x20mm quick blow fuses
CFTBN/5EWPG
50.9 mm
CFB0521CT
Ceramic 5x20mm time delay fuses
+44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com
We operate a constant improvement policy, our products are subject to change without notice.
Vers 5
DESCRIPTION
很抱歉,暂时无法提供与“CFTBN/1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+80.66559
- 50+78.96813
- 100+76.60419
