CHDASMP28
CHDASMP28
    CAMDENBOSS
    CAMDENBOSS - CHDASMP28 - MOUNTING PLATE, STEEL, ENCLOSURE
CHDASMP28 数据手册
H E AV Y D U T Y A N D E L E C T R I C A L E N C L O S U R E S 268 HANDHELD CASES DIECAST DIECAST ACCESSORIES ACCESSORIES ACC E SS O R I E S Ve n t s t o f i t X 6 , X 7 and X8 enclosures 292 • Vents in two sizes for heat extraction • The vent includes a gasket for water resistant applications • Designed to meet the requirements of IP34 PA R T N O . CUTOUT DIAMETER M AT E R I A L CHDA201V 63 Polycarbonate CHDA202V 88 Polycarbonate CHDA301V 63 ABS CHDA302V 88 ABS UNIVERSAL PLASTIC ENCLOSURES 317 HEAVY DUTY AND ELECTRICAL ENCLOSURES 341 DEVELOPMENT BOARD ENCLOSURES Mounting brackets to fit X6, X7 and X8 enclosures • Brackets to mount each enclosure to any surface/wall • See cross reference page 328 to select the correct size for your enclosure PA R T N O . SIZE CHDAPB014/4 1 Size 1 Bracket, 4x12 S/T Screw, 4pc kit CHDAPB015/4 1 Size 1 Bracket, 5x12 S/T Screw, 4pc kit CHDAPB025/4 2 Size 2 Bracket, M5x12 Screw, 4pc kit CHDAPB025/6 2 Size 2 Bracket, M5x12 Screw, 6pc kit CHDAPB026/6 2 Size 2 Bracket, M6x12 Screw, 6pc kit 369 VERSATILE IOT AND SENSOR ENCLOSURES Mounting plates to fit X6, X7 and X8 enclosures • Material: Steel • Mounting plates for each enclosure available PA R T N O . L E N G T H mm W I DT H CHDASMP21 65mm 95mm CHDASMP22 65mm 115mm CHDASMP23 65mm 165mm CHDASMP24 65mm 235mm CHDASMP25 101mm 161mm CHDASMP26 159mm 159mm CHDASMP27 159mm 248mm CHDASMP28 248mm 348mm CHDASMP29 295mm 395mm CHDASMP30 85mm 232mm CHDASMP32 129mm 179mm CHDASMP33 129mm 224mm CHDASMP34 170mm 266mm CHDASMP35 179mm 179mm CHDASMP36 216mm 316mm CHDASMP37 262mm 262mm CHDASMP38 265mm 365mm CHDASMP39 358mm 458mm CHDASMP40 450mm 555mm CHDASMP41 550mm 755mm CHDASMP42 248mm 248mm CHDASMP43 248mm 308mm CHDASMP44 232mm 535mm CHDASMP45 345mm 535mm CHDASMP46 159mm 348mm CHDASMP49 65mm 65mm P L AST I C E N C LOS U R E S • See cross reference page 329 to select the correct size for your enclosure +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. FM 28614 Vers 12 Vers 325 H E AV Y D U T Y A N D E L E C T R I C A L E N C L O S U R E S 268 HANDHELD DIECASTCASES ACCESSORIES 292 UNIVERSAL PLASTIC ENCLOSURES 317 HEAVY DUTY AND ELECTRICAL ENCLOSURES ACC E SS O R I E S Dual door to fit the X8 enclosure PA R T N O . KIT INCLUDES CHDX807DD 4 legs, 1 door, 1 door handle, 1 frame, 8 screws • Easy to assemble, sturdy construction CHDX808DD 4 legs, 1 door, 1 door handle, 1 frame, 8 screws • See cross reference page 328 to select the correct size for your enclosure CHDX810DD 4 legs, 1 door, 1 door handle, 1 frame, 8 screws CHDX811DD 4 legs, 1 door, 1 door handle, 1 frame, 8 screws CHDX812DD 4 legs, 1 door, 1 door handle, 1 frame, 8 screws CHDX813DD 4 legs, 1 door, 1 door handle, 1 frame, 8 screws CHDX814DD 4 legs, 1 door, 1 door handle, 1 frame, 8 screws • Dual door avaliable for some sizes 341 DEVELOPMENT BOARD ENCLOSURES 369 VERSATILE IOT AND SENSOR ENCLOSURES Lock to fit the X8 enclosure • One or two locks can be fitted, depending on security level required • See cross reference page 328 to select the correct size for your enclosure SIZE CHDA01IL 1 CHDA02IL 2 CHDA03IL 3 CHDA04IL 4 P L AST I C E N C LOS U R E S • Moulded in high quality polycarbonate PA R T N O . 326 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 FM 28614 H E AV Y D U T Y A N D E L E C T R I C A L E N C L O S U R E S 268 HANDHELD CASES DIECAST DIECAST ACCESSORIES ACCESSORIES ACC E SS O R I E S F O R X 6 , X 7 A N D X 8 S E R I E S C H DX 8 1 4 D D C H DX 8 1 3 D D C H DX 8 1 2 D D 292 C H DX 8 1 1 D D C H DX 8 0 1 0 D D C H DX 8 0 8 D D C H DX 8 0 7 D D C H DA 0 4 I L DUAL DOOR C H DA 0 3 I L C H DA 0 2 I L C H DA 0 1 I L C H DA P B 0 2 6 / 6 LO C KS C H DA P B 0 2 5 / 6 C H DA P B 0 2 5 /4 UNIVERSAL PLASTIC ENCLOSURES 317 HEAVY DUTY AND ELECTRICAL ENCLOSURES CHDX6-221 CHDX6-321  CHDX6-222 CHDX6-322  CHDX6-223 CHDX6-323  CHDX6-224 CHDX6-324  CHDX6-225 CHDX6-325  CHDX6-226 CHDX6-326  CHDX6-227 CHDX6-327  CHDX6-228 CHDX6-328  CHDX6-229 CHDX6-329  CHDX6-230 CHDX6-330  CHDX7-221 CHDX7-321  CHDX7-222 CHDX7-322  CHDX7-223 CHDX7-323  CHDX7-224 CHDX7-324  CHDX7-225 CHDX7-325  CHDX7-226 CHDX7-326  CHDX7-227 CHDX7-327  CHDX7-228 CHDX7-328  CHDX7-229 CHDX7-329  CHDX7-230 CHDX7-330  CHDX7-231 CHDX7-331  CHDX7-232 CHDX7-332  CHDX7-237 CHDX7-327 CHDX8-221 CHDX8-321   CHDX8-222 CHDX8-322   CHDX8-223 CHDX8-333   CHDX8-224 CHDX8-324   CHDX8-225 CHDX8-325   CHDX8-226 CHDX8-326   CHDX8-227 CHDX8-327   CHDX8-228 CHDX8-328   CHDX8-229 CHDX8-329  CHDX8-230 CHDX8-330   CHDX8-231 CHDX8-331   CHDX8-232 CHDX8-332   CHDX8-233 CHDX8-333  CHDX8-234 CHDX8-334 CHDX8-235 CHDX8-335   CHDX8-236 CHDX8-336   341 DEVELOPMENT BOARD ENCLOSURES 369 VERSATILE IOT AND SENSOR ENCLOSURES            P L AST I C E N C LOS U R E S ABS C H DA P B 0 1 5 /4 P O LY W/ M O U N T C H DA P B 0 1 4 /4 E N C L O S U R E PA R T N O . *Add 'c' suffix for clear lid versions +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. FM 28614 1 Vers 2 327 H E AV Y D U T Y A N D E L E C T R I C A L E N C L O S U R E S 268 HANDHELD DIECASTCASES ACCESSORIES M O U N T I N G P L AT E S E N C L O S U R E PA R T N O . 317 HEAVY DUTY AND ELECTRICAL ENCLOSURES 341 DEVELOPMENT BOARD ENCLOSURES 369 VERSATILE IOT AND SENSOR ENCLOSURES CHDX7-328 CHDX7-229 CHDX7-329 CHDX7-230 CHDX7-330 CHDX7-231 CHDX7-331 CHDX7-232 CHDX7-332 CHDX8-221 CHDX8-321  CHDX8-222 CHDX8-322  CHDX8-223 CHDX8-323  CHDX8-224 CHDX8-324  CHDX8-225 CHDX8-325 CHDX8-226 CHDX8-326 CHDX8-227 CHDX8-327  CHDX8-228 CHDX8-328  CHDX8-229 CHDX8-329 CHDX8-230 CHDX8-330 CHDX8-231 CHDX8-331 CHDX8-232 CHDX8-332 CHDX8-233 CHDX8-333 CHDX8-234 CHDX8-334 CHDX8-235 CHDX8-335  CHDX8-236 CHDX8-336  C H DA S M P 4 6  CHDX7-228 C H DA S M P 4 5 CHDX7-327 C H DA S M P 4 4  CHDX7-227 C H DA S M P 4 3 CHDX7-326 C H DA S M P 4 2 CHDX7-226 C H DA S M P 4 1 CHDX7-325 C H DA S M P 4 0 CHDX7-324 CHDX7-225 C H DA S M P 3 9 CHDX7-224 C H DA S M P 3 8  C H DA S M P 3 7 CHDX7-323 C H DA S M P 3 6  CHDX7-223 C H DA S M P 3 5 CHDX7-322 C H DA S M P 3 4 CHDX7-222 C H DA S M P 3 3 CHDX7-321 C H DA S M P 3 2  CHDX7-221 C H DA S M P 3 0 CHDX6-330 C H DA S M P 2 9  CHDX6-230 C H DA S M P 2 8 CHDX6-329 UNIVERSAL PLASTIC ENCLOSURES C H DA S M P 2 7 CHDX6-229 292 C H DA S M P 2 6 ABS C H DA S M P 2 5 P O LY                 P L AST I C E N C LOS U R E S *Add 'c' suffix for clear lid versions 328 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 2 1 FM 28614
CHDASMP28 价格&库存
很抱歉,暂时无法提供与“CHDASMP28”相匹配的价格&库存,您可以联系我们找货
