CHDX7-224
CHDX7-224
    CAMDENBOSS
    CAMDENBOSS - CHDX7-224 - ENCLOSURE, MULTIPURPOSE, PC, GREY
CHDX7-224 数据手册
H E AV Y D U T Y A N D E L E C T R I C A L E N C L O S U R E S 268 HANDHELD DIECASTCASES ACCESSORIES 292 UNIVERSAL ENCLOSURES X7 series electrical heavy duty enclosures - polycarbonate Product overview 318 HEAVY DUTY AND ELECTRICAL ENCLOSURES 342 DESKTOP AND INSTRUMENT CASES 348 DEVELOPMENT BOARD ENCLOSURES CHDX7 • • • • • • • • Heavy duty screw type enclosure Moulded in high quality polycarbonate PCB pillars in the base for PCB mounting Brass inserts in the base Gasket supplied Clear lid option available Captive, polyamide screws included Can be mounted directly to the wall or with the mount bracket accessory • X7 series has been tested and meets the requirements of IP67 (equivalent to NEMA 6) • IK08 impact tested S P E C I F I C AT I O N 367 ROOM SENSOR ENCLOSURES 370 CUSTOM SIZED ENCLOSURES Materials Polycarbonate UL94-V0 Operating temperature -40°C to +120°C Protection class X7 series has been tested and meets the requirements of IP67, IK08 Standard colours Grey, transparent lid option Standard unit Includes Box and lid, 4 screws SOLID LID Available accessories Mount plates, vents, wall mounts CHDX7-237 CHDX7-237C CHDX7-221 CHDX7-221C CHDX7-222 CHDX7-222C 380mm 190mm 130mm Yes CHDX7-223 CHDX7-223C 380mm 190mm 180mm Yes CLEAR LID LENGTH CORNER PILLARS W I DT H HEIGHT 80mm 80mm 60mm No 190mm 190mm 130mm Yes CHDX7-224 CHDX7-224C 380mm 280mm 180mm Yes CHDX7-225 CHDX7-225C 430mm 330mm 180mm Yes CHDX7-226 CHDX7-226C 280mm 190mm 130mm Yes CHDX7-227 CHDX7-227C 280mm 190mm 180mm Yes CHDX7-228 CHDX7-228C 280mm 280mm 130mm Yes CHDX7-229 CHDX7-229C 340mm 280mm 130mm Yes CHDX7-230 CHDX7-230C 380mm 280mm 130mm Yes CHDX7-231 CHDX7-231C 560mm 280mm 130mm Yes CHDX7-232 CHDX7-232C 560mm 380mm 180mm Yes K E Y F E AT U R E S P L AST I C E N C LOS U R E S Rugged heavy duty mould | IP67 rated enclosure | PCB stand offs 322 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers Vers 4 1 FM 28614 EMS 613558 H E AV Y D U T Y A N D E L E C T R I C A L E N C L O S U R E S 268 HANDHELD CASES DIECAST DIECAST ACCESSORIES ACCESSORIES X7 series electrical heavy duty enclosures - ABS Product overview 292 UNIVERSAL ENCLOSURES CHDX7 • • • • • • • Heavy duty screw type enclosure Moulded in high quality ABS PCB pillars in the base for PCB mounting Brass inserts in the base Gasket supplied Clear lid option available Can be mounted directly to the wall or with the mount bracket accessory • Captive, polyamide screws included • X7 series has been tested and meets the requirements of IP67 (equivalent to NEMA 6) • IK08 impact tested 318 HEAVY DUTY AND ELECTRICAL ENCLOSURES 342 DESKTOP AND INSTRUMENT CASES 348 DEVELOPMENT BOARD ENCLOSURES S P E C I F I C AT I O N Materials ABS UL94-HB Operating temperature -40°C to +85°C Protection class X7 series has been tested and meets the requirements of IP67, IK08 Standard colours Grey, transparent lid option Standard unit Includes Box and lid, 4 screws SOLID LID CLEAR LID LENGTH W I DT H HEIGHT CORNER PILLARS Available accessories Mount plates, vents, wall mounts CHDX7-337 CHDX7-337C 80mm 80mm 60mm No CHDX7-321 CHDX7-321C 190mm 190mm 130mm Yes CHDX7-322 CHDX7-322C 380mm 190mm 130mm Yes CHDX7-323 CHDX7-323C 380mm 190mm 180mm Yes CHDX7-324 CHDX7-324C 380mm 280mm 180mm Yes CHDX7-325 CHDX7-325C 430mm 330mm 180mm Yes CHDX7-326 CHDX7-326C 280mm 190mm 130mm Yes CHDX7-327 CHDX7-327C 280mm 190mm 180mm Yes CHDX7-328 CHDX7-328C 280mm 280mm 130mm Yes CHDX7-329 CHDX7-329C 340mm 280mm 130mm Yes CHDX7-330 CHDX7-330C 380mm 280mm 130mm Yes CHDX7-331 CHDX7-331C 560mm 280mm 130mm Yes CHDX7-332 CHDX7-332C 560mm 380mm 180mm Yes 367 ROOM SENSOR ENCLOSURES 370 CUSTOM SIZED ENCLOSURES K E Y F E AT U R E S P L AST I C E N C LOS U R E S Rugged heavy duty mould | IP67 rated enclosure | PCB stand offs +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. FM 28614 EMS 613558 Vers Vers 41 323 H E AV Y D U T Y A N D E L E C T R I C A L E N C L O S U R E S 268 HANDHELD DIECASTCASES ACCESSORIES 292 UNIVERSAL ENCLOSURES 318 HEAVY DUTY AND ELECTRICAL ENCLOSURES ACC E SS O R I E S Ve n t s t o f i t X 6 , X 7 and X8 enclosures • Vents in two sizes for heat extraction • The vent includes a gasket for water resistant applications • Designed to meet the requirements of IP34 PA R T N O . CUTOUT DIAMETER M AT E R I A L CHDA201V 63 Polycarbonate CHDA202V 88 Polycarbonate CHDA301V 63 ABS CHDA302V 88 ABS 342 DESKTOP AND INSTRUMENT CASES 348 DEVELOPMENT BOARD ENCLOSURES 367 ROOM SENSOR ENCLOSURES Mounting brackets to fit X6, X7 and X8 enclosures • Brackets to mount each enclosure to any surface/wall PA R T N O . SIZE CHDAPB01 1 CHDAPB02 2 • See cross reference page 328 to select the correct size for your enclosure • Sold individually 370 CUSTOM SIZED ENCLOSURES Mounting plates to fit X6, X7 and X8 enclosures • Material: Steel • Mounting plates for each enclosure available P L AST I C E N C LOS U R E S • See cross reference page 329 to select the correct size for your enclosure 326 PA R T N O . L E N G T H mm W I DT H CHDASMP21 65mm 95mm CHDASMP22 65mm 115mm CHDASMP23 65mm 165mm CHDASMP24 65mm 235mm CHDASMP25 101mm 161mm CHDASMP26 159mm 159mm CHDASMP27 159mm 248mm CHDASMP28 248mm 348mm CHDASMP29 295mm 395mm CHDASMP30 85mm 232mm CHDASMP32 129mm 179mm CHDASMP33 129mm 224mm CHDASMP34 170mm 266mm CHDASMP35 179mm 179mm CHDASMP36 216mm 316mm CHDASMP37 262mm 262mm CHDASMP38 265mm 365mm CHDASMP39 358mm 458mm CHDASMP40 450mm 555mm CHDASMP41 550mm 755mm CHDASMP42 248mm 248mm CHDASMP43 248mm 308mm CHDASMP44 232mm 535mm CHDASMP45 345mm 535mm CHDASMP46 159mm 348mm CHDASMP49 65mm 65mm +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers Vers 5 1 FM 28614 EMS 613558 H E AV Y D U T Y A N D E L E C T R I C A L E N C L O S U R E S 268 HANDHELD CASES DIECAST DIECAST ACCESSORIES ACCESSORIES ACC E SS O R I E S Dual door to fit the X8 enclosure • Dual door avaliable for some sizes 292 PA R T N O . KIT INCLUDES CHDX807DD 4 legs, 1 door, 1 door handle, 1 frame, 8 screws • Easy to assemble, sturdy construction CHDX808DD 4 legs, 1 door, 1 door handle, 1 frame, 8 screws • See cross reference page 328 to select the correct size for your enclosure CHDX810DD 4 legs, 1 door, 1 door handle, 1 frame, 8 screws CHDX811DD 4 legs, 1 door, 1 door handle, 1 frame, 8 screws CHDX812DD 4 legs, 1 door, 1 door handle, 1 frame, 8 screws CHDX813DD 4 legs, 1 door, 1 door handle, 1 frame, 8 screws CHDX814DD 4 legs, 1 door, 1 door handle, 1 frame, 8 screws UNIVERSAL ENCLOSURES 318 HEAVY DUTY AND ELECTRICAL ENCLOSURES 342 DESKTOP AND INSTRUMENT CASES Lock to fit the X8 enclosure • One or two locks can be fitted, depending on security level required • See cross reference page 328 to select the correct size for your enclosure • Moulded in high quality polycarbonate 348 PA R T N O . SIZE CHDA01IL 1 CHDA02IL 2 CHDA03IL 3 CHDA04IL 4 DEVELOPMENT BOARD ENCLOSURES 367 ROOM SENSOR ENCLOSURES 370 P L AST I C E N C LOS U R E S CUSTOM SIZED ENCLOSURES +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. FM 28614 EMS 613558 Vers 21 327 H E AV Y D U T Y A N D E L E C T R I C A L E N C L O S U R E S ACC E SS O R I E S F O R X 6 , X 7 A N D X 8 S E R I E S DUAL DOOR 318 CHDX6-221 CHDX6-321  CHDX6-222 CHDX6-322  CHDX6-223 CHDX6-323  CHDX6-224 CHDX6-324  CHDX6-225 CHDX6-325  CHDX6-226 CHDX6-326  CHDX6-227 CHDX6-327  CHDX6-228 CHDX6-328  CHDX6-229 CHDX6-329  CHDX6-230 CHDX6-330  CHDX7-221 CHDX7-321  CHDX7-222 CHDX7-322  CHDX7-223 CHDX7-323  CHDX7-224 CHDX7-324  CHDX7-225 CHDX7-325  CHDX7-226 CHDX7-326  CHDX7-227 CHDX7-327  CHDX7-228 CHDX7-328  CHDX7-229 CHDX7-329  CHDX7-230 CHDX7-330  CHDX7-231 CHDX7-331  CHDX7-232 CHDX7-332  CHDX8-221 CHDX8-321   CHDX8-222 CHDX8-322   CHDX8-223 CHDX8-333   CHDX8-224 CHDX8-324   CHDX8-225 CHDX8-325   CHDX8-226 CHDX8-326   CHDX8-227 CHDX8-327   CHDX8-228 CHDX8-328   CHDX8-229 CHDX8-329  CHDX8-230 CHDX8-330   CHDX8-231 CHDX8-331   CHDX8-232 CHDX8-332   CHDX8-233 CHDX8-333  CHDX8-234 CHDX8-334   CHDX8-235 CHDX8-335   CHDX8-236 CHDX8-336   HEAVY DUTY AND ELECTRICAL ENCLOSURES 342 DESKTOP AND INSTRUMENT CASES 348 DEVELOPMENT BOARD ENCLOSURES 367 ROOM SENSOR ENCLOSURES 370 P L AST I C E N C LOS U R E S CUSTOM SIZED ENCLOSURES 328 C H DA 0 4 I L C H DA 0 3 I L C H DA 0 1 I L C H DA P B 0 1 C H DX 8 0 7 D D ABS C H DA 0 2 I L P O LY UNIVERSAL ENCLOSURES C H DA P B 0 2 292 C H DX 8 1 4 D D LO C KS C H DX 8 1 3 D D W/ M O U N T C H DX 8 1 2 D D E N C L O S U R E PA R T N O . C H DX 8 1 1 D D ACCESSORIES C H DX 8 0 1 0 D D HANDHELD DIECASTCASES C H DX 8 0 8 D D 268          *Add 'c' suffix for clear lid versions +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 FM 28614 EMS 613558 H E AV Y D U T Y A N D E L E C T R I C A L E N C L O S U R E S 268 HANDHELD CASES DIECAST DIECAST ACCESSORIES ACCESSORIES C H DA S M P 4 6 C H DA S M P 4 5 C H DA S M P 4 4 C H DA S M P 4 3 C H DA S M P 4 2 C H DA S M P 4 1 C H DA S M P 4 0 C H DA S M P 3 9 C H DA S M P 3 8 C H DA S M P 3 7 C H DA S M P 3 6 C H DA S M P 3 5 C H DA S M P 3 4 C H DA S M P 3 2 C H DA S M P 3 1 C H DA S M P 3 0 C H DA S M P 2 9 C H DA S M P 2 8 C H DA S M P 2 7 ABS C H DA S M P 2 6 P O LY C H DA S M P 2 5 E N C L O S U R E PA R T N O . C H DA S M P 3 3 M O U N T I N G P L AT E S CHDX6-229 CHDX6-329  CHDX6-230 CHDX6-330  CHDX7-221 CHDX7-321 CHDX7-222 CHDX7-322  CHDX7-223 CHDX7-323  CHDX7-224 CHDX7-324 CHDX7-225 CHDX7-325 CHDX7-226 CHDX7-326  CHDX7-227 CHDX7-327  CHDX7-228 CHDX7-328 CHDX7-229 CHDX7-329 CHDX7-230 CHDX7-330 CHDX7-231 CHDX7-331 CHDX7-232 CHDX7-332 CHDX8-221 CHDX8-321  CHDX8-222 CHDX8-322  CHDX8-223 CHDX8-323  CHDX8-224 CHDX8-324  CHDX8-225 CHDX8-325 CHDX8-226 CHDX8-326 CHDX8-227 CHDX8-327  CHDX8-228 CHDX8-328  CHDX8-229 CHDX8-329 CHDX8-230 CHDX8-330 CHDX8-231 CHDX8-331 CHDX8-232 CHDX8-332 CHDX8-233 CHDX8-333 CHDX8-234 CHDX8-334 CHDX8-235 CHDX8-335  CHDX8-236 CHDX8-336  292 UNIVERSAL ENCLOSURES 318 HEAVY DUTY AND ELECTRICAL ENCLOSURES  342  DESKTOP AND INSTRUMENT CASES  348 DEVELOPMENT BOARD ENCLOSURES    367 ROOM SENSOR ENCLOSURES   370 CUSTOM SIZED ENCLOSURES         P L AST I C E N C LOS U R E S *Add 'c' suffix for clear lid versions +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. FM 28614 EMS 613558 Vers Vers21 329
CHDX7-224 价格&库存
很抱歉,暂时无法提供与“CHDX7-224”相匹配的价格&库存,您可以联系我们找货
