CSTBP92HC/3
CSTBP92HC/3
    CAMDENBOSS
    CAMDENBOSS - CSTBP92HC/3 - Pluggable Terminal Block, 2.5 mm, 3 Ways, 26AWG to 20AWG, 0.5 mm², Push I...
CSTBP92HC/3 数据手册
P C B T E R M I N A L B LO C KS S TA N D A R D PLUGGABLES SCREWLESS 002 PCB TERMINAL BLOCKS 081 TERMINAL STRIPS 2.5mm pitch pluggable screwless terminal blocks Product overview 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS • • • • • • • S P E C I F I C AT I O N 2-12 pole solid block Screwless connectivity Moulded in green UL94-V0, flame retardant PA66 Cable acceptance - 0.12mm2 - 0.5mm2 (26-20AWG) Pluggable male and female connectors Polarised mouldings US approved C Rating UL=4A/150V, IEC=5A/250V Insulation resistance 500MΩ/500V Withstand voltage AC1250V/1min Contact resistance 20mΩ (max) Working temperature -40°C to +105°C Moulding UL94-V0, flame retardant PA66 Spring Stainless steel Contact Bronze, Ni plated Recommended PCB hole size 1.4mm INTERFACE MODULES AND RELAY BASES PA R T N O . POLES LENGTH CSTBP92HC/2 2 5.6mm CSTBP92HC/3 3 8.1mm CSTBP92HC/4 4 10.6mm CSTBP92HC/5 5 13.1mm CSTBP92HC/6 6 15.6mm CSTBP92HC/7 7 18.1mm CSTBP92HC/8 8 20.6mm CSTBP92HC/9 9 23.1mm CSTBP92HC/10 10 25.6mm CSTBP92HC/11 11 28.1mm CSTBP92HC/12 12 30.6mm CSTBP92HC 3.9 5.8 158 Female connector 19.2 IP68 CONNECTORS 17.2 151 L 11.75 ᴓ1.6 1.4 Male header vertical connector 6.9mm CTBP93VC/3 3 9.4mm CTBP93VC/4 4 11.9mm CTBP93VC/5 5 14.4mm CTBP93VC/6 6 16.9mm CTBP93VC/7 7 19.4mm CTBP93VC/8 8 21.9mm CTBP93VC/9 9 24.4mm CTBP93VC/10 10 26.9mm CTBP93VC/11 11 29.4mm CTBP93VC/12 12 31.9mm CTBP93VC 8.10 3.90 2.50 0.80 6.60 LENGTH 2 2.5 POLES CTBP93VC/2 10.10 PA R T N O . 90 3 9.4mm CTBP93HC/4 4 11.9mm CTBP93HC/5 5 14.4mm CTBP93HC/6 6 16.9mm CTBP93HC/7 7 19.4mm CTBP93HC/8 8 21.9mm CTBP93HC/9 9 24.4mm CTBP93HC/10 10 26.9mm CTBP93HC/11 11 29.4mm CTBP93HC/12 12 31.9mm +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers Vers21 10.10 2.5(XX-1)+4.40 0.80 2.50 2.5(XX-1) A 0.30 8.90 Section A-A 2.5(XX-1) 2.50 8.90 CTBP93HC/3 CTBP93HC 40 6.9mm Ø1 . LENGTH 2 8.90 POLES CTBP93HC/2 8.10 *3.50+0.3 PA R T N O . 10.10 CONNECT Male header horizontal connector
CSTBP92HC/3 价格&库存
很抱歉,暂时无法提供与“CSTBP92HC/3”相匹配的价格&库存,您可以联系我们找货
