CSTBP508H/3
CSTBP508H/3
    CAMDENBOSS
    CAMDENBOSS - CSTBP508H/3 - Wire-To-Board Terminal Block, 5.08 mm, 3 Ways, 28 AWG, 16 AWG, 1.3 mm², P...
CSTBP508H/3 数据手册
P C B T E R M I N A L B LO C KS S TA N D A R D SCREWLESS PLUGGABLES 002 PCB TERMINAL BLOCKS 5.08mm screwless terminal blocks 081 TERMINAL STRIPS Product overview 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS • • • • • • • S P E C I F I C AT I O N Interlocking modules Easily breakable to desired number of poles Guided pin alignment Choice of vertical or horizontal cable entry Moulded in green UL94-V0 PA66 0.34-2.5mm2 cable (22-14AWG) US approved C Rating 10A/300V Insulation withstand voltage AC2500V/1 min Insulation resistance 500MΩ at DC500V Operating temperature -40°C to +115°C Moulding UL94-V0 PA66 Pin/contact Tin plated brass Recommended PCB hole size 1.2mm 151 33.0mm CSTBP508V/7 7 38.1mm CSTBP508V/8 8 43.2mm CSTBP508V/9 9 48.3mm CSTBP508V/10 10 53.3mm CSTBP508V/11 11 58.4mm CSTBP508V/12 12 63.5mm PA R T N O . POLES LENGTH CSTBP508H/2 2 12.7mm CSTBP508H/3 3 17.8mm CSTBP508H/4 4 22.9mm CSTBP508H/5 5 27.9mm CSTBP508H/6 6 33.0mm CSTBP508H/7 7 38.1mm CSTBP508H/8 8 43.2mm CSTBP508H/9 9 48.3mm CSTBP508H/10 10 53.3mm CSTBP508H/11 11 58.4mm CSTBP508H/12 12 63.5mm 0.50 5.08x(N-1) 5.08xN+2.54 5.08 Ø1.20 Ø2.20 Ø2.20 CSTBP508H CONNECT D u a l r o w p i n s | Ve r t i c a l o r h o r i z o n t a l c a b l e e n t r y +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 2 1 3.15 5.08x(N-1) 1.05 5.08 7.62 0.50 5.08x(N-1) 5.08x(N-1) 5.08xN+2.54 5.08 Ø1.20 PCB LAYOUT K E Y F E AT U R E S 88 5.08 1.00 7.62 1.45 6 10.50 27.9mm CSTBP508V/6 | Modular design 14.20 5 1.80 22.9mm CSTBP508V/5 7.62 17.8mm 4 7.62 3 CSTBP508V/4 14.20 CSTBP508V/3 CSTBP508V 13.60 12.7mm 10.50 LENGTH 2 10.50 INTERFACE MODULES AND RELAY BASES POLES CSTBP508V/2 14.20 158 PA R T N O . 13.55 IP68 CONNECTORS
CSTBP508H/3 价格&库存
很抱歉,暂时无法提供与“CSTBP508H/3”相匹配的价格&库存,您可以联系我们找货
