PCB TERMINAL BLOCKS
PCB
TERMINAL
BLOCKS
INTERCONNECTION
FUSES &
FUSEHOLDERS
LEDs &
INDICATORS
MINIATURE
SWITCHES
LIMIT &
SAFETY
SWITCHES
7.5mm Pitch Standard Profile Rising Clamp Terminal Blocks
• 2 & 3 pole double interlocking
mechanism for increased
strength
• 4-12 pole solid block
• Moulded in green UL94-V0 flame
retardant PA66
• Professional rising
clamp terminals
• 0.2-4.0mm2 (30-12AWG)
solid cable
• 0.2-2.5mm2 (30-12AWG)
stranded cable
• Guided pin alignment
approved
SPECIFICATION
Rating
CTB0110
Dielectric strength
Impulse withstand voltage
Working temperature
Moulding
Pin/terminal
Rising clamp
Screw/torque
Recommended PCB hole size
TYPE NO.
CTB0110/2
CTB0110/3
CTB0110/4
CTB0110/5
CTB0110/6
CTB0110/7
CTB0110/8
CTB0110/9
CTB0110/10
CTB0110/11
CTB0110/12
POLES
2
3
4
5
6
7
8
9
10
11
12
LENGTH
15mm
22.5mm
30mm
37.5mm
45mm
52.5mm
60mm
67.5mm
75mm
82.5mm
90mm
CONTROL
PRODUCTS
INTERFACE
MODULES &
SUPPORTS
RELAY
BASES
DIN RAIL
ENCLOSURES
BATTERIES
SOLAR
PANELS
TRANSFORMERS
We operate a constant improvement
policy, our products are subject to
change without notice.
Ver 1.1
+44 (0)1638 716101
info@camdenboss.com
www.camdenboss.com
24A/500V
UL=14A/300V, VDE&IMQ=24A/750V
≥3kV
6kV
110°C
UL94-V0 flame retardant PA66
Tinned, nickel plated brass
M3 steel zinc plated, 0.5Nm
ø1.5mm
很抱歉,暂时无法提供与“CTB0110/2”相匹配的价格&库存,您可以联系我们找货
