CTB0202/3
CTB0202/3
    CAMDENBOSS
    10mm Rising Clamp Terminal 3 Way
CTB0202/3 数据手册
P C B T E R M I N A L B LO C KS S TA N D A R D PLUGGABLES SCREWLESS 002 081 TERMINAL STRIPS 10mm pitch standard profile rising clamp terminal blocks Product overview 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 IP68 CONNECTORS 158 INTERFACE MODULES AND RELAY BASES CTB0202 • • • • 2 to 12 pole interlocking Professional rising clamp terminals Standard profile Moulded in green UL94-V0 flame retardant PA66 • Cable acceptance - 0.33-3.31mm2 (22-12 AWG) • Guided pin alignment • C US approved S P E C I F I C AT I O N PA R T N O . POLES LENGTH Rating 10A 300V CTB0202/2 2 15.2mm Insulation resistance 5000M Ω/1000V CTB0202/3 3 25mm Withstand voltage AC1500V/1min CTB0202/4 4 35mm Contact resistance 20m Ω CTB0202/5 5 45mm Working temperature -33°C to +120°C CTB0202/6 6 55mm Moulding UL94-V0 flame retardant PA66 CTB0202/7 7 75mm Pin/terminal Tin plated brass CTB0202/8 8 85mm Wire clamp Nickel plated brass CTB0202/9 9 95mm Screw/torque M2.5 steel, nickel plated 0.4Nm CTB0202/10 10 105mm CTB0202/11 11 115mm CTB0202/12 12 125mm Recommended PCB hole size ø1.5mm 10.3 2.5x2.5 10 4 PCB TERMINAL BLOCKS 5 K E Y F E AT U R E S CONNECT 2-12 pole interlocking | Double interlock mechanism 52 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 | Professional rising clamp
CTB0202/3 价格&库存
很抱歉,暂时无法提供与“CTB0202/3”相匹配的价格&库存,您可以联系我们找货
