PCB TERMINAL BLOCKS
6.35mm Pitch High Power Rising Clamp Terminal Blocks
• 2 & 3 pole double
interlocking mechanism for
increased strength
• Moulded in green UL94-V0
flame retardant PA66
• Professional rising
clamp terminals
• 0.2-6.0mm2 (30-10AWG)
solid & stranded cable
• Guided pin alignment
• Captive screws
approved
CTB04VY
SPECIFICATION
Rating
Dielectric strength
Impulse withstand voltage
Working temperature
Moulding
Pin/terminal
Rising Clamp
Screw/torque
Recommended PCB hole size
PCB
TERMINAL
BLOCKS
32A/400V
UL=24A/300V, VDE&IMQ=32A/450V
≥2.5kV
6kV
110°C
UL94-V0 flame retardant PA66
Tinned, nickel plated brass
Zinc plated steel
M3 steel zinc plated, 0.5Nm
ø1.5mm
INTERCONNECTION
FUSES &
FUSEHOLDERS
LEDs &
INDICATORS
MINIATURE
SWITCHES
TYPE NO.
CTB04VY/2
CTB04VY/3
CTB04VY/4
CTB04VY/5
CTB04VY/6
CTB04VY/7
CTB04VY/8
CTB04VY/9
CTB04VY/10
CTB04VY/11
CTB04VY/12
POLES
2
3
4
5
6
7
8
9
10
11
12
LENGTH
12.7mm
19.1mm
25.4mm
31.8mm
38.1mm
44.5mm
50.8mm
57.2mm
63.5mm
69.9mm
76.2mm
LIMIT &
SAFETY
SWITCHES
CONTROL
PRODUCTS
INTERFACE
MODULES &
SUPPORTS
RELAY
BASES
DIN RAIL
ENCLOSURES
BATTERIES
SOLAR
PANELS
TRANSFORMERS
+44 (0)1638 716101
info@camdenboss.com
www.camdenboss.com
We operate a constant improvement
policy, our products are subject to
change without notice.
Ver 1.1
很抱歉,暂时无法提供与“CTB04VY/3”相匹配的价格&库存,您可以联系我们找货
