CTB0758/12
CTB0758/12
    CAMDENBOSS
CTB0758/12 数据手册
PCB TERMINAL BLOCKS 5.08mm Pitch High Power 90˚ Rising Clamp Terminal Blocks • 2 & 3 pole double interlocking mechanism for increased strength • 4-12 pole solid block • Moulded in green UL94-V0 flame retardant PA • Professional rising clamp terminals • 0.2-4.0mm2 (30-12AWG) solid cable • 0.2-2.5mm2 (30-12AWG) stranded cable • Guided pin alignment • Captive screw • , , approved SPECIFICATION Rating CTB0758 Dielectric strength Impulse withstand voltage Working temperature Moulding Pin/terminal Rising clamp Screw/torque Recommended PCB hole size PCB TERMINAL BLOCKS 24A/320V UL=16A/300V, VDE&IMQ=24A/450V ≥2.5kV 4kV 110°C UL94-V0 flame retardant PA Tinned, nickel plated brass Tinned, nickel plated brass M3 steel zinc plated, 0.5Nm ø1.5mm INTERCONNECTION FUSES & FUSEHOLDERS LEDs & INDICATORS TYPE NO. CTB0758/2 CTB0758/3 CTB0758/4 CTB0758/5 CTB0758/6 CTB0758/7 CTB0758/8 CTB0758/9 CTB0758/10 CTB0758/11 CTB0758/12 POLES 2 3 4 5 6 7 8 9 10 11 12 LENGTH 10.16mm 15.24mm 20.32mm 25.4mm 30.48mm 35.56mm 40.64mm 45.72mm 50.8mm 55.88mm 60.96mm 11.2 MINIATURE SWITCHES LIMIT & SAFETY SWITCHES For other dimensions see CTB0708 CONTROL PRODUCTS INTERFACE MODULES & SUPPORTS RELAY BASES DIN RAIL ENCLOSURES BATTERIES SOLAR PANELS TRANSFORMERS +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Ver 1.1
CTB0758/12 价格&库存
很抱歉,暂时无法提供与“CTB0758/12”相匹配的价格&库存,您可以联系我们找货
