CTB1202/2BK
CTB1202/2BK
    CAMDENBOSS
CTB1202/2BK 数据手册
CAMBLOCK 5mm Pitch Standard Profile Terminal Block • 2-12 pole interlocking CTB1202/BK • Moulded in black UL94V-0 PA Flame retardant PA66 • Wire protector terminals • 0.3-2mm2 (22-14 AWG) • Guided pin alignment • approved TYPE NO. CTB1202/2BK CTB1202/3BK CTB1202/4BK CTB1202/5BK CTB1202/6BK CTB1202/7BK CTB1202/8BK CTB1202/9BK CTB1202/10BK CTB1202/11BK CTB1202/12BK SPECIFICATION Rating Insulation resistance Withstand Voltage Contact Resistance Working Temperature Mouldings Wire Protector Screw/Torque Recommended PCB hole size POLES 2 3 4 5 6 7 8 9 10 11 12 PCB TERMINAL BLOCKS 16A 250V 5000MΩ/1000V AC1500V/1min 20mΩ -33°C to +120°C UL94-V0 flame retardant PA66 Stainless steel M3 Steel, Nickel Plated 0.4Nm ø1.2mm-1.4mm LENGTH 10mm 15mm 20mm 25mm 30mm 35mm 40mm 45mm 50mm 55mm 60mm 5mm Pitch 45˚ Rising Clamp Terminal SPECIFICATION Rating Insulation resistance Withstand Voltage Contact Resistance Working Temperature Mouldings Screw/Torque Recommended PCB hole size POLES 2 3 4 5 6 7 8 9 10 11 12 LENGTH 10mm 15mm 20mm 25mm 30mm 35mm 40mm 45mm 50mm 55mm 60mm 12.6 12.30 TYPE NO. CTB3202/2BK CTB3202/3BK CTB3202/4BK CTB3202/5BK CTB3202/6BK CTB3202/7BK CTB3202/8BK CTB3202/9BK CTB3202/10BK CTB3202/11BK CTB3202/12BK 15A 300V 5000MΩ/1000V AC2000V/1min 20mΩ -33°C to +120°C UL94-V0 flame retardant PA66 M2.5 Steel, Nickel Plated 0.4Nm ø1.2mm-1.4mm 12.6 CTB3202 4.5 • 2-12 pole interlocking • Moulded in black UL94-V0 Flame retardant PA66 • Professional rising clamp terminal • 0.2-3.3mm2 (24-12 AWG) • approved 0.7 6.5 +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com Ver 1.0 We operate a constant improvement policy, our products are subject to change without notice. 25
CTB1202/2BK 价格&库存
很抱歉,暂时无法提供与“CTB1202/2BK”相匹配的价格&库存,您可以联系我们找货
