CTB2202/2
CTB2202/2
    CAMDENBOSS
    CTB2202/2
CTB2202/2 数据手册
SCREWLESS PLUGGABLES S TA N D A R D P C B T E R M I N A L B LO C KS ECONOMY RANGE 10mm pitch standard profile terminal block Product overview CTB2202 2-12 pole interlocking Moulded in black UL94-V0 PA66 Wire protector terminals 0.13-1.3mm2 (26-16 AWG) Guided pin alignment PA R T N O . POLES LENGTH Rating 16A 250V CTB2202/2 2 15mm Insulation resistance 5000MΩ/1000V CTB2202/3 3 25mm Withstand voltage AC1500V/1min CTB2202/4 4 35mm Contact resistance 20mΩ CTB2202/5 5 45mm Working temperature -33°C to +120°C CTB2202/6 6 55mm Mouldings UL94-V0 flame retardant PA66 CTB2202/7 7 65mm Wire protector Stainless steel CTB2202/8 8 75mm Screw/torque M3 Steel, Nickel Plated 0.4Nm CTB2202/9 9 85mm Recommended PCB hole size ø1.1mm CTB2202/10 10 95mm CTB2202/11 11 105mm CTB2202/12 12 115mm 10 9.1 12.3 S P E C I F I C AT I O N 4.4 • • • • • 2.5 5.1 K E Y F E AT U R E S E CO N O M Y R A N G E P C B T E R M I N A L B LO C KS W i r e p r o t e c t o r t e r m i n a l s | U L 9 4 -V 0 PA m o u l d i n g | I n t e r l o c k i n g +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. FM 28614 EMS 613558 Vers 1 12
CTB2202/2 价格&库存
很抱歉,暂时无法提供与“CTB2202/2”相匹配的价格&库存,您可以联系我们找货
