CTB922HD/2
CTB922HD/2
    CAMDENBOSS
    3.5mm Female Connector 2 Way
CTB922HD/2 数据手册
SCREWLESS PLUGGABLES S TA N D A R D P C B T E R M I N A L B LO C KS ECONOMY RANGE 3.5mm pitch pluggable rising clamp terminal blocks Product overview • • • PA R T N O . POLES LENGTH CTB922HD/2 2 7mm CTB922HD/3 3 10.5mm CTB922HD/4 4 14mm CTB922HD/5 5 17.5mm CTB922HD/6 6 21mm CTB922HD/7 7 24.5mm CTB922HD/8 8 28mm CTB922HD/9 9 31.5mm CTB922HD/10 10 35mm CTB922HD/11 11 38.5mm CTB922HD/12 12 42mm PA R T N O . POLES LENGTH CTB932VD/2 2 8.4mm CTB932VD/3 3 11.9mm CTB932VD/4 4 15.4mm CTB932VD/5 5 18.9mm CTB932VD/6 6 22.4mm CTB932VD/7 7 25.9mm CTB932VD/8 8 29.4mm CTB932VD/9 9 32.9mm CTB932VD/10 10 36.4mm CTB932VD/11 11 39.9mm CTB932VD/12 12 43.4mm PA R T N O . POLES LENGTH CTB932HD/2 2 8.4mm CTB932HD/3 3 11.9mm CTB932HD/4 4 15.4mm CTB932HD/5 5 18.9mm CTB932HD/6 6 22.4mm CTB932HD/7 7 25.9mm CTB932HD/8 8 29.4mm CTB932HD/9 9 32.9mm CTB932HD/10 10 36.4mm CTB932HD/11 11 39.9mm CTB932HD/12 12 43.4mm 10A/200V Dielectric strength ≥2.5kV Working temperature -33°C to +120°C Moulding UL94-V0 flame retardant PA Pin/terminal Tinned phosphor bronze Rising clamp Nickel copper flash brass Screw/torque M2 steel tin plated, 0.3Nm Recommended PCB hole size ø1.2mm CTB922HD CTB932VD E CO N O M Y R A N G E P C B T E R M I N A L B LO C KS • 2-12 pole solid block Up to 20 poles available Pluggable male-female connectors Professional rising clamp terminals Closed headers Polarised mouldings Moulded in green UL94-V0 flame retardant PA66 0.13-1.3mm2 (26-16AWG) solid & stranded cable Captive screws Guided pin alignment approved CTB932HD 3.5 3.5 2.3 3.5 • • • • • • • S P E C I F I C AT I O N Rating +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. FM 28614 EMS 613558 Vers 1 14
CTB922HD/2 价格&库存
很抱歉,暂时无法提供与“CTB922HD/2”相匹配的价格&库存,您可以联系我们找货
