CTB9300/4AO
CTB9300/4AO
    CAMDENBOSS
CTB9300/4AO 数据手册
PCB Terminal blocks 5mm Pitch Pluggable Rising Clamp Terminal • 2-24 pole solid block • Pluggable male-female connectors • Open & closed headers • Horizontal & vertical female plug styles • Polarised mouldings • Moulded in green UL94-V0 flame retardant PA • Professional rising clamp terminals • 0.2-2.5mm2 (30-12AWG) solid & stranded cable • Anti solder wicking • Captive screws • Guided pin alignment • , approved Specification Rating Dielectric strength Impule withstand voltage Working temperature Moulding Pin/terminal Rising clamp Screw/torque Recommended PCB hole size 20A/320V UL=12A/300V, VDE&IMQ=20A/320V ≥2.5kV 4kV 100°C UL94-V0 flame retardant PA Tinned phosphor bronze Nickel copper flash brass M3 steel zinc plated, 0.5Nm ø1.4mm Female connector Type No. CTB9200/2A CTB9200/3A CTB9200/4A CTB9200/5A CTB9200/6A CTB9200/7A CTB9200/8A CTB9200/9A CTB9200/10A CTB9200/11A CTB9200/12A CTB9200/13A Poles 2 3 4 5 6 7 8 9 10 11 12 13 Length 10mm 15mm 20mm 25mm 30mm 35mm 40mm 45mm 50mm 55mm 60mm 65mm Type No. CTB9200/14A CTB9200/15A CTB9200/16A CTB9200/17A CTB9200/18A CTB9200/19A CTB9200/20A CTB9200/21A CTB9200/22A CTB9200/23A CTB9200/24A Poles 14 15 16 17 18 19 20 21 22 23 24 Length 70mm 75mm 80mm 85mm 90mm 95mm 100mm 105mm 110mm 115mm 120mm CTB9200
 Female connector vertical (standard) Type No. CTB92VG/2S CTB92VG/3S CTB92VG/4S CTB92VG/5S CTB92VG/6S CTB92VG/7S CTB92VG/8S CTB92VG/9S CTB92VG/10S CTB92VG/11S CTB92VG/12S CTB92VG/13S Poles 2 3 4 5 6 7 8 9 10 11 12 13 Length 10mm 15mm 20mm 25mm 30mm 35mm 40mm 45mm 50mm 55mm 60mm 65mm Type No. CTB92VG/14S CTB92VG/15S CTB92VG/16S CTB92VG/17S CTB92VG/18S CTB92VG/19S CTB92VG/20S CTB92VG/21S CTB92VG/22S CTB92VG/23S CTB92VG/24S Poles 14 15 16 17 18 19 20 21 22 23 24 Length 70mm 75mm 80mm 85mm 90mm 95mm 100mm 105mm 110mm 115mm 120mm CTB92VG/S
 Female connector vertical (reversed) Type No. CTB92VG/2R CTB92VG/3R CTB92VG/4R CTB92VG/5R CTB92VG/6R CTB92VG/7R CTB92VG/8R CTB92VG/9R CTB92VG/10R CTB92VG/11R CTB92VG/12R CTB92VG/13R Poles 2 3 4 5 6 7 8 9 10 11 12 13 Length 10mm 15mm 20mm 25mm 30mm 35mm 40mm 45mm 50mm 55mm 60mm 65mm Type No. CTB92VG/14R CTB92VG/15R CTB92VG/16R CTB92VG/17R CTB92VG/18R CTB92VG/19R CTB92VG/20R CTB92VG/21R CTB92VG/22R CTB92VG/23R CTB92VG/24R Poles 14 15 16 17 18 19 20 21 22 23 24 Length 70mm 75mm 80mm 85mm 90mm 95mm 100mm 105mm 110mm 115mm 120mm CTB92VG/R
 40 +44 (0)1638 716101 Ver 1.0 We operate a constant improvement policy, our products are subject to change without notice. www.camdenboss.com PCB Terminal blocks PCB mounting male vertical (closed ended) Type No. CTB9300/2A CTB9300/3A CTB9300/4A CTB9300/5A CTB9300/6A CTB9300/7A CTB9300/8A CTB9300/9A CTB9300/10A CTB9300/11A CTB9300/12A CTB9300/13A Poles 2 3 4 5 6 7 8 9 10 11 12 13 Length 11.2mm 16.2mm 21.2mm 26.2mm 31.2mm 36.2mm 41.2mm 46.2mm 51.2mm 56.2 61.2mm 66.2mm Type No. CTB9300/14A CTB9300/15A CTB9300/16A CTB9300/17A CTB9300/18A CTB9300/19A CTB9300/20A CTB9300/21A CTB9300/22A CTB9300/23A CTB9300/24A Poles 14 15 16 17 18 19 20 21 22 23 24 Length 71.2mm 76.2mm 81.2mm 86.2mm 91.2mm 96.2mm 101.2mm 106.2mm 111.2mm 116.2mm 121.2mm CTB9300
 PCB mounting male horizontal (closed ended) Type No. CTB9350/2A CTB9350/3A CTB9350/4A CTB9350/5A CTB9350/6A CTB9350/7A CTB9350/8A CTB9350/9A CTB9350/10A CTB9350/11A CTB9350/12A CTB9350/13A Poles 2 3 4 5 6 7 8 9 10 11 12 13 Length 11.2mm 16.2mm 21.2mm 26.2mm 31.2mm 36.2mm 41.2mm 46.2mm 51.2mm 56.2 61.2mm 66.2mm Type No. CTB9350/14A CTB9350/15A CTB9350/16A CTB9350/17A CTB9350/18A CTB9350/19A CTB9350/20A CTB9350/21A CTB9350/22A CTB9350/23A CTB9350/24A Poles 14 15 16 17 18 19 20 21 22 23 24 Length 71.2mm 76.2mm 81.2mm 86.2mm 91.2mm 96.2mm 101.2mm 106.2mm 111.2mm 116.2mm 121.2mm CTB9350 PCB mounting male vertical (open ended) Type No. CTB9300/2AO CTB9300/3AO CTB9300/4AO CTB9300/5AO CTB9300/6AO CTB9300/7AO CTB9300/8AO CTB9300/9AO CTB9300/10AO CTB9300/11AO CTB9300/12AO CTB9300/13AO Poles 2 3 4 5 6 7 8 9 10 11 12 13 Length 10mm 15mm 20mm 25mm 30mm 35mm 40mm 45mm 50mm 55mm 60mm 65mm Type No. CTB9300/14AO CTB9300/15AO CTB9300/16AO CTB9300/17AO CTB9300/18AO CTB9300/19AO CTB9300/20AO CTB9300/21AO CTB9300/22AO CTB9300/23AO CTB9300/24AO Poles 14 15 16 17 18 19 20 21 22 23 24 Length 70mm 75mm 80mm 85mm 90mm 95mm 100mm 105mm 110mm 115mm 120mm CTB9300/A0 PCB mounting male horizontal (open ended) Type No. CTB9350/2AO CTB9350/3AO CTB9350/4AO CTB9350/5AO CTB9350/6AO CTB9350/7AO CTB9350/8AO CTB9350/9AO CTB9350/10AO CTB9350/11AO CTB9350/12AO CTB9350/13AO Poles 2 3 4 5 6 7 8 9 10 11 12 13 Length 10mm 15mm 20mm 25mm 30mm 35mm 40mm 45mm 50mm 55mm 60mm 65mm +44 (0)1638 716101 www.camdenboss.com Type No. CTB9350/14AO CTB9350/15AO CTB9350/16AO CTB9350/17AO CTB9350/18AO CTB9350/19AO CTB9350/20AO CTB9350/21AO CTB9350/22AO CTB9350/23AO CTB9350/24AO Poles 14 15 16 17 18 19 20 21 22 23 24 Length 70mm 75mm 80mm 85mm 90mm 95mm 100mm 105mm 110mm 115mm 120mm We operate a constant improvement policy, our products are subject to change without notice. CTB9350/A0 Ver 1.0
CTB9300/4AO 价格&库存
很抱歉,暂时无法提供与“CTB9300/4AO”相匹配的价格&库存,您可以联系我们找货
