PCB TERMINAL BLOCKS
PCB
TERMINAL
BLOCKS
INTERCONNECTION
FUSES &
FUSEHOLDERS
7.5mm & 7.62mm Pitch Pluggable Rising Clamp Terminal Blocks
• 2-12 pole solid block
• Pluggable male-female
connectors
• Open & closed headers
• Horizontal female plug style
• Polarised mouldings
• Moulded in green UL94-V0
flame retardant PA
• Professional rising
clamp terminals
• 0.2-2.5mm2 (30-12AWG)
solid & stranded cable
• Anti solder wicking
• Captive screws
• Guided pin alignment
approved
7.5mm
7.62mm
SPECIFICATION
Rating
Dielectric strength
Impulse withstand voltage
Working temperature
Moulding
Pin/terminal
Rising clamp
Screw/torque
Recommended PCB hole size
LEDs &
INDICATORS
MINIATURE
SWITCHES
LIMIT &
SAFETY
SWITCHES
CONTROL
PRODUCTS
TYPE NO.
CTB9400/2
CTB9400/3
CTB9400/4
CTB9400/5
CTB9400/6
CTB9400/7
CTB9400/8
CTB9400/9
CTB9400/10
CTB9400/11
CTB9400/12
POLES
2
3
4
5
6
7
8
9
10
11
12
LENGTH
13mm
20.5mm
28mm
35.5mm
43mm
50.5mm
58mm
65.5mm
73mm
80.5mm
88mm
TYPE NO.
CTB9408/2
CTB9408/3
CTB9408/4
CTB9408/5
CTB9408/6
CTB9408/7
CTB9408/8
CTB9408/9
CTB9408/10
CTB9408/11
CTB9408/12
POLES
2
3
4
5
6
7
8
9
10
11
12
LENGTH
13.2mm
20.9mm
28.5mm
36.1mm
43.7mm
51.3mm
59mm
66.6mm
74.2mm
81.8mm
89.4mm
CTB9400
INTERFACE
MODULES &
SUPPORTS
RELAY
BASES
DIN RAIL
ENCLOSURES
BATTERIES
SOLAR
PANELS
TRANSFORMERS
We operate a constant improvement
policy, our products are subject to
change without notice.
Ver 1.2
+44 (0)1638 716101
info@camdenboss.com
www.camdenboss.com
20A/500V
UL=12A/300V, VDE&IMQ=20A/500V
≥3kV
6kV
110°C
UL94-V0 flame retardant PA
Copper alloy, NI & SN
M3 steel zinc plated, 0.5Nm
ø1.4mm
很抱歉,暂时无法提供与“CTB9400/3”相匹配的价格&库存,您可以联系我们找货
