CTBP0158/3
CTBP0158/3
    CAMDENBOSS
    CAMDENBOSS - CTBP0158/3 - Wire-To-Board Terminal Block, 5.08 mm, 3 Ways, 22 AWG, 12 AWG, 3.31 mm², S...
CTBP0158/3 数据手册
SCREWLESS PLUGGABLES S TA N D A R D P C B T E R M I N A L B LO C KS 002 PCB TERMINAL BLOCKS 5.08mm pitch standard profile 90° rising clamp terminal blocks Product overview 081 TERMINAL STRIPS CTBP0158 • 2 and 3 pole double interlocking mechanism for increased strength • Moulded in green UL94-V0 flame retardant PA • 90° mounting • Cable acceptance - 0.3-3.31mm2 (22-12AWG) • Professional rising clamp terminals • Guided pin alignment • Captive screws • C US approved 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 IP68 CONNECTORS 500MΩ / 500V CTBP0158/3 3 15.24mm Withstand voltage AC1600V / 1min CTBP0158/4 4 20.32mm Contact resistance 20mΩ (max) CTBP0158/5 5 25.4mm Working temperature -40°C to +105°C CTBP0158/6 6 30.48mm Moulding UL94-V0 flame retardant PA CTBP0158/7 7 35.56mm Pin/terminal Tin plated brass CTBP0158/8 8 40.64mm Rising clamp Nickel plated brass CTBP0158/9 9 45.72mm Screw/torque M2.5 steel, zinc plated / 0.4Nm CTBP0158/10 10 50.8mm CTBP0158/11 11 55.88mm CTBP0158/12 12 60.96mm Recommended PCB hole size Ø1.5mm 2.54 5.08 5.08 5.08(xx-1) 158 0.90 INTERFACE MODULES AND RELAY BASES 10.20 Insulation resistance 5.08(xx-1) 2.54 PCB layout 0.60 5.08xx A 14.10 10.16mm (15.70) 2 14.50 LENGTH CTBP0158/2 0.80 POLES 16A / 300V .50 Ø1 PA R T N O . Rating 14.50 S P E C I F I C AT I O N A *4.60±0.3 Section A-A K E Y F E AT U R E S | Rising clamp terminals CONNECT Standard profile | Double interlock mechanism +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 33
CTBP0158/3 价格&库存
很抱歉,暂时无法提供与“CTBP0158/3”相匹配的价格&库存,您可以联系我们找货
