CTBP0700/2
CTBP0700/2
    CAMDENBOSS
    CAMDENBOSS - CTBP0700/2 - Wire-To-Board Terminal Block, 5 mm, 2 Ways, 26 AWG, 12 AWG, 3.31 mm², Scre...
CTBP0700/2 数据手册
P C B T E R M I N A L B LO C KS S TA N D A R D PLUGGABLES SCREWLESS 002 PCB TERMINAL BLOCKS 081 TERMINAL STRIPS 5mm high power vertical rising clamp terminal blocks Product overview 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS CTBP0700 • 2 and 3 pole double interlocking mechanism for increased strength • 4-12 pole solid block • Moulded in green UL94-V0 flame retardant PA66 • Professional rising clamp terminals • Cable acceptance - 0.13-3.31mm2 (26-12AWG) • Guided pin alignment • Captive screw • C approved US , 151 IP68 CONNECTORS LENGTH 2 10mm CTBP0700/3 3 15mm CTBP0700/4 4 20mm CTBP0700/5 5 25mm UL94-V0 flame retardant PA66 CTBP0700/6 6 30mm Tinned, nickel plated brass CTBP0700/7 7 35mm CTBP0700/8 8 40mm CTBP0700/9 9 45mm CTBP0700/10 10 50mm CTBP0700/11 11 55mm CTBP0700/12 12 60mm Impulse withstand voltage 2kV/1min Working temperature -40°C to +105°C Moulding Pin/terminal Rising clamp Screw/torque Recommended PCB hole size Tinned, nickel plated brass M3 steel zinc plated, 0.5Nm ø1.5mm Ø1.50 10.50 POLES CTBP0700/2 UL=20A/300V, VDE=24A/250V 3.10 5.00 5.00(xx-1) K E Y F E AT U R E S | Professional rising clamp CONNECT High power | Double interlock mechanism 28 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 0.60 5.0xx A PCB layout 0.80 5.20 5.00±0.3 PA R T N O . Rating 5.20 S P E C I F I C AT I O N 0.60 18.00 INTERFACE MODULES AND RELAY BASES 10.50 158 Section: A-A 1.00 3.10 A 5.00 5.00(xx-1)
CTBP0700/2 价格&库存
很抱歉,暂时无法提供与“CTBP0700/2”相匹配的价格&库存,您可以联系我们找货
