P C B T E R M I N A L B LO C KS
S TA N D A R D
SCREWLESS
PLUGGABLES
002
TERMINAL STRIPS
Product overview
095
100
WIRE TO BOARD
CONNECTORS
CIRCULAR
CONNECTORS
151
IP68 CONNECTORS
2 and 3 pole interlocking
Wire protector terminals
Standard profile 90° mounting
Moulded in UL94-V0 flame retardant
PA66
Cable acceptance - 0.6-1.6mm2 (2214AWG)
Guided pin alignment
Anti solder wicking terminals
approved
US ,
C
S P E C I F I C AT I O N
PA R T N O .
POLES
LENGTH
UL=16A/300V, VDE=24A/250V
CTBP1050/2
2
10mm
Insulation resistance
500M Ω/500V
CTBP1050/3
3
15mm
Withstand voltage
AC2000V/1min
CTBP1050/4
4
20mm
20mΩ (max)
CTBP1050/5
5
25mm
CTBP1050/6
6
30mm
CTBP1050/7
7
35mm
CTBP1050/8
8
40mm
CTBP1050/9
9
45mm
CTBP1050/10
10
50mm
CTBP1050/11
11
55mm
CTBP1050/12
12
60mm
Rating
158
INTERFACE
MODULES AND
RELAY BASES
CTBP1050
Contact resistance
Working temperature
Moulding
-40°C to +105°C
UL94-V0 flame retardant PA66
Pin/terminal
Tin plated brass
Wire protector
Phosphor bronze, nickel plated
Screw/torque
M2.5 steel, zinc plated 0.4Nm
Recommended PCB
hole size
ø1.5mm
5.0 2.5
1
0.7
12.5
081
5mm pitch standard profile 90˚
screw terminal blocks
4.2
3.5
PCB TERMINAL
BLOCKS
9
K E Y F E AT U R E S
| Standard profile
CONNECT
Wire protector terminals | Interlock mechanism
22
+44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com
We operate a constant improvement policy, our products are subject to change without notice.
Vers 1
FM 28614
EMS 613558
很抱歉,暂时无法提供与“CTBP1050/3”相匹配的价格&库存,您可以联系我们找货
