CTBP0708/3
CTBP0708/3
    CAMDENBOSS
    Conn Terminal Block F 3 POS 5.08mm Solder ST Thru-Hole 20A
CTBP0708/3 数据手册
SCREWLESS PLUGGABLES S TA N D A R D P C B T E R M I N A L B LO C KS 002 PCB TERMINAL BLOCKS 5.08mm pitch high power rising clamp terminal blocks Product overview 081 TERMINAL STRIPS CTBP0708 • 2 and 3 pole double interlocking mechanism for increased strength • Professional rising clamp terminals • High profile • Moulded in green UL94-V0 flame retardant PA66 • Cable acceptance - 0.4-2mm2 (26-12AWG) • 20A 300V • Guided pin alignment • C approved US , 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 Insulation resistance 500M Ω/500V Withstand voltage Contact resistance AC2000V/1min 20mΩ (max) Working temperature -40°C to +105°C Moulding UL94-V0 flame retardant PA66 Pin/terminal Rising clamp Screw/torque Recommended PCB hole size Tin plated brass Brass, nickel plated M3 steel, zinc plated 0.5Nm ø1.6mm LENGTH CTBP0708/2 2 10.16mm CTBP0708/3 3 15.24mm CTBP0708/4 4 20.32mm CTBP0708/5 5 25.4mm CTBP0708/6 6 30.48mm CTBP0708/7 7 35.56mm CTBP0708/8 8 40.64mm CTBP0708/9 9 45.72mm CTBP0708/10 10 50.8mm CTBP0708/11 11 55.88mm 0.8 CTBP0708/12 12 60.96mm 4.3 5.08 10.5 UL=20A/300V, VDE=20A/250V POLES 158 INTERFACE MODULES AND RELAY BASES 18 Rating IP68 CONNECTORS PA R T N O . 6 S P E C I F I C AT I O N K E Y F E AT U R E S | Professional rising clamp CONNECT High powered 20A | Double interlock mechanism +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 35
CTBP0708/3 价格&库存
很抱歉,暂时无法提供与“CTBP0708/3”相匹配的价格&库存,您可以联系我们找货
