CTBP2054/3
CTBP2054/3
    CAMDENBOSS
    CAMDENBOSS - CTBP2054/3 - Wire-To-Board Terminal Block, 2.54 mm, 3 Ways, 26 AWG, 18 AWG, 1 mm², Scre...
CTBP2054/3 数据手册
P C B T E R M I N A L B LO C KS S TA N D A R D SCREWLESS PLUGGABLES 002 Product overview 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 IP68 CONNECTORS 2-12 pole solid block Professional rising clamp terminals Low profile Moulded in green UL94-V0 flame retardant PA66 • Cable acceptance - 0.4 to 1mm2 (26-18AWG) solid and stranded cable • Guided pin alignment • C US approved S P E C I F I C AT I O N Rating Insulation resistance 158 INTERFACE MODULES AND RELAY BASES CTBP2054 • • • • Withstand voltage UL=6A/150V, IEC=8A/130V 500MΩ/500V AC 1300V/1min Contact resistance 20mΩ (max) Working temperature -40°C to +105°C Moulding UL94-V0, flame retardant PA66 Pin/terminal Brass, tin plated Rising clamp Brass, Ni plated Screw M1.6 steel, zinc plated/0.1Nm Recommeded PCB hole size 1.0mm PA R T N O . POLES LENGTH CTBP2054/2 2 5.54mm CTBP2054/3 3 8.08mm CTBP2054/4 4 10.62mm CTBP2054/5 5 13.16mm CTBP2054/6 6 15.70mm CTBP2054/7 7 18.24mm CTBP2054/8 8 20.78mm CTBP2054/9 9 23.32mm CTBP2054/10 10 25.86mm CTBP2054/11 11 28.40mm CTBP2054/12 12 30.94mm 6.2 8.5 TERMINAL STRIPS 3.5 081 2.54mm pitch rising clamp terminal blocks 6.2 PCB TERMINAL BLOCKS 0.8 1.5 2.54 K E Y F E AT U R E S CONNECT Professional rising clamp | Space saving profile 12 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 | F l a m e r e t a r d a n t PA 6 6 0.5 3.1
CTBP2054/3 价格&库存
很抱歉,暂时无法提供与“CTBP2054/3”相匹配的价格&库存,您可以联系我们找货
