CTBP90HG/2
CTBP90HG/2
    CAMDENBOSS
    CAMDENBOSS - CTBP90HG/2 - Wire-To-Board Terminal Block, 5 mm, 2 Ways, 24 AWG, 12 AWG, 2.5 mm², Screw
CTBP90HG/2 数据手册
SCREWLESS PLUGGABLES S TA N D A R D P C B T E R M I N A L B LO C KS 002 PCB TERMINAL BLOCKS 5mm pitch inline screw PCB terminal blocks Product overview S P E C I F I C AT I O N System provides same-side access as wire entry • • • • • • • • • 081 TERMINAL STRIPS 1 to 12 pole interlocking Professional rising clamp terminals Standard profile Moulded in green UL94-V0 flame retardant PA66 Cable acceptance - 0.5-2mm2 (2412AWG) Available in horizontal or vertical orientations Double row pins for enhanced board stability Useful in applications with restricted vertical access, e.g. covered enclosures approved US , C Rating UL=20A/300V, VDE=24A/450V Insulation resistance 500M Ω/500V Withstand voltage AC2000V/1min Contact resistance 20mΩ (max) Working temperature -40°C to +105°C Moulding UL94-V0 flame retardant PA66 Pin/terminal Brass, tin plated Cage clamp Steel, zinc plated Screw/torque M2.5 steel, zinc plated 0.4Nm Recommended PCB hole size ø1.4mm 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 IP68 CONNECTORS 158 INTERFACE MODULES AND RELAY BASES Horizontal 12.5mm CTBP90VG/3 3 17.5mm CTBP90VG/4 4 22.5mm CTBP90VG/5 5 27.5mm CTBP90VG/6 6 32.5mm CTBP90VG/7 7 37.5mm CTBP90VG/8 8 42.5mm CTBP90VG/9 9 47.5mm CTBP90VG/10 10 52.5mm CTBP90VG/11 11 57.5mm CTBP90VG/12 12 62.5mm CTBP90VG 18.5 LENGTH 2 18.5 POLES CTBP90VG/2 0.8 2.9 0.8 3.5 PA R T N O . 5 19.5 5.3 5 Ve r t i c a l POLES LENGTH CTBP90HG/2 2 12.5mm CTBP90HG/3 3 17.5mm CTBP90HG/4 4 22.5mm CTBP90HG/5 5 27.5mm CTBP90HG/6 6 32.5mm CTBP90HG/7 7 37.5mm CTBP90HG/8 8 42.5mm CTBP90HG/9 9 47.5mm CTBP90HG/10 10 52.5mm CTBP90HG/11 11 57.5mm CTBP90HG/12 12 62.5mm CTBP90HG 18.5 PA R T N O . 0.8 9.3 5 Inline cable entry | Interlock mechanism CONNECT K E Y F E AT U R E S | Professional rising clamp +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers Vers21 29
CTBP90HG/2 价格&库存
很抱歉,暂时无法提供与“CTBP90HG/2”相匹配的价格&库存,您可以联系我们找货
