CTBP92VE/12R
CTBP92VE/12R
    CAMDENBOSS
    CAMDENBOSS - CTBP92VE/12R - Pluggable Terminal Block, 3.81 mm, 12 Ways, 28AWG to 16AWG, 1 mm², Clamp...
CTBP92VE/12R 数据手册
SCREWLESS PLUGGABLES S TA N D A R D P C B T E R M I N A L B LO C KS 002 PCB TERMINAL BLOCKS 3.81mm pitch pluggable rising clamp terminal blocks Product overview • • • • • • • • • • • 081 TERMINAL STRIPS S P E C I F I C AT I O N  2-12 pole solid block Professional rising clamp terminals Moulded in green UL94-V0 flame retardant PA66 Cable acceptance - 0.32 to 1.3mm2 (28-16AWG) solid and stranded cable Pluggable male and female connectors Closed headers Horizontal and vertical female plug styles Polarised mouldings Anti solder wicking Captive screws and guided pin alignment approved US , C Rating UL=8A/300V, VDE=10A/250V Insulation resistance 500M Ω/500V Withstand voltage AC2000V/1min Contact resistance 20mΩ (max) Working temperature -40°C to +105°C Moulding UL94-V0 flame retardant PA66 Pin/terminal Tin plated brass Rising clamp Brass, nickel plated Screw/torque M2 steel, zinc plated 0.2Nm Recommended PCB hole size ø1.4mm 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 IP68 CONNECTORS Female connector LENGTH 2 8.4mm CTBP92HE/3 3 12.2mm CTBP92HE/4 4 16mm CTBP92HE/5 5 19.8mm CTBP92HE/6 6 23.7mm CTBP92HE/7 7 27.5mm CTBP92HE/8 8 31.3mm CTBP92HE/9 9 35.1mm CTBP92HE/10 10 38.9mm CTBP92HE/11 11 42.7mm CTBP92HE/12 12 46.5mm CTBP92HE 158 INTERFACE MODULES AND RELAY BASES 16.4 6.6 6.5 POLES CTBP92HE/2 11.2 PA R T N O . 3.81 Female vertical connector (standard) LENGTH 2 8.4mm CTBP92VE/3S 3 12.2mm CTBP92VE/4S 4 16mm CTBP92VE/5S 5 19.8mm CTBP92VE/6S 6 23.7mm CTBP92VE/7S 7 27.5mm CTBP92VE/8S 8 31.3mm CTBP92VE/9S 9 35.1mm CTBP92VE/10S 10 38.9mm CTBP92VE/11S 11 42.7mm CTBP92VE/12S 12 46.5mm CTBP92VE S 3.81 10.4 19.2 POLES CTBP92VE/2S 6.6 PA R T N O . Female vertical connector (reversed) 8.4mm CTBP92VE/3R 3 12.2mm CTBP92VE/4R 4 16mm CTBP92VE/5R 5 19.8mm CTBP92VE/6R 6 23.7mm CTBP92VE/7R 7 27.5mm CTBP92VE/8R 8 31.3mm CTBP92VE/9R 9 35.1mm CTBP92VE/10R 10 38.9mm CTBP92VE/11R 11 42.7mm CTBP92VE/12R 12 46.5mm CTBP92VE R 3.81 10.4 CONNECT LENGTH 2 19.2 POLES CTBP92VE/2R 6.6 PA R T N O . +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 65 P C B T E R M I N A L B LO C KS S TA N D A R D PLUGGABLES SCREWLESS 002 PCB TERMINAL BLOCKS PCB mounting male horizontal connector (closed ended) 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 POLES LENGTH CTBP93HE/2 2 8.4mm CTBP93HE/3 3 12.2mm CTBP93HE/4 4 16.0mm CTBP93HE/5 5 19.8mm CTBP93HE/6 6 23.7mm CTBP93HE/7 7 27.5mm CTBP93HE/8 8 31.3mm CTBP93HE/9 9 35.1mm CTBP93HE/10 10 38.9mm CTBP93HE/11 11 42.7mm CTBP93HE/12 12 46.5mm CTBP93HE 9.2 7 7.2 TERMINAL STRIPS PA R T N O . 3.4 081 3.81 1.2 PCB mounting male vertical connector (closed ended) IP68 CONNECTORS 8.4mm CTBP93VE/3 3 12.2mm CTBP93VE/4 4 16.0mm CTBP93VE/5 5 19.8mm CTBP93VE/6 6 23.7mm CTBP93VE/7 7 27.5mm CTBP93VE/8 8 31.3mm CTBP93VE/9 9 35.1mm CTBP93VE/10 10 38.9mm CTBP93VE/11 11 42.7mm CTBP93VE/12 12 46.5mm CTBP93VE 7 LENGTH 2 3.4 9.2 3.81 A S S O C I AT E D P R O D U C T S CTB92HE, CTB92VE S and CTBP92VE R can be replaced with a screwless type terminal block for a reduced assembly time. - page 78 CONNECT CSTBP92HE 66 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 7.2 INTERFACE MODULES AND RELAY BASES POLES CTBP93VE/2 3 158 PA R T N O .
CTBP92VE/12R 价格&库存
很抱歉,暂时无法提供与“CTBP92VE/12R”相匹配的价格&库存,您可以联系我们找货
