SCREWLESS
PLUGGABLES
S TA N D A R D
P C B T E R M I N A L B LO C KS
002
PCB TERMINAL
BLOCKS
3.81mm pitch pluggable rising
clamp terminal blocks
Product overview
081
TERMINAL STRIPS
S P E C I F I C AT I O N
2-12
pole solid block
Professional rising clamp terminals
Moulded in green UL94-V0 flame retardant PA66
Cable acceptance - 0.32 to 1.3mm2 (28-16AWG) solid
and stranded cable
Pluggable male and female connectors
Closed headers
Horizontal and vertical female plug styles
Polarised mouldings
Anti solder wicking
Captive screws and guided pin alignment
approved
US ,
C
Rating
UL=8A/300V, VDE=10A/250V
Insulation resistance
500M Ω/500V
Withstand voltage
AC2000V/1min
Contact resistance
20mΩ (max)
Working temperature
-40°C to +105°C
Moulding
Pin/terminal
Tin plated brass
Rising clamp
Brass, nickel plated
Screw/torque
M2 steel, zinc plated 0.2Nm
Recommended PCB hole size
ø1.4mm
095
WIRE TO BOARD
CONNECTORS
100
CIRCULAR
CONNECTORS
151
IP68 CONNECTORS
Female connector
LENGTH
2
8.4mm
CTBP92HE/3
3
12.2mm
CTBP92HE/4
4
16mm
CTBP92HE/5
5
19.8mm
CTBP92HE/6
6
23.7mm
CTBP92HE/7
7
27.5mm
CTBP92HE/8
8
31.3mm
CTBP92HE/9
9
35.1mm
CTBP92HE/10
10
38.9mm
CTBP92HE/11
11
42.7mm
CTBP92HE/12
12
46.5mm
CTBP92HE
158
INTERFACE
MODULES AND
RELAY BASES
16.4
6.6
6.5
POLES
CTBP92HE/2
11.2
PA R T N O .
3.81
Female vertical connector (standard)
LENGTH
2
8.4mm
CTBP92VE/3S
3
12.2mm
CTBP92VE/4S
4
16mm
CTBP92VE/5S
5
19.8mm
CTBP92VE/6S
6
23.7mm
CTBP92VE/7S
7
27.5mm
CTBP92VE/8S
8
31.3mm
CTBP92VE/9S
9
35.1mm
CTBP92VE/10S
10
38.9mm
CTBP92VE/11S
11
42.7mm
CTBP92VE/12S
12
46.5mm
CTBP92VE S
3.81
10.4
19.2
POLES
CTBP92VE/2S
6.6
PA R T N O .
Female vertical connector (reversed)
8.4mm
CTBP92VE/3R
3
12.2mm
CTBP92VE/4R
4
16mm
CTBP92VE/5R
5
19.8mm
CTBP92VE/6R
6
23.7mm
CTBP92VE/7R
7
27.5mm
CTBP92VE/8R
8
31.3mm
CTBP92VE/9R
9
35.1mm
CTBP92VE/10R
10
38.9mm
CTBP92VE/11R
11
42.7mm
CTBP92VE/12R
12
46.5mm
CTBP92VE R
3.81
10.4
CONNECT
LENGTH
2
19.2
POLES
CTBP92VE/2R
6.6
PA R T N O .
+44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com
We operate a constant improvement policy, our products are subject to change without notice.
Vers 1
65
S TA N D A R D
PLUGGABLES
SCREWLESS
002
PCB TERMINAL
BLOCKS
PCB mounting male horizontal connector (closed ended)
095
WIRE TO BOARD
CONNECTORS
100
CIRCULAR
CONNECTORS
151
POLES
LENGTH
CTBP93HE/2
2
8.4mm
CTBP93HE/3
3
12.2mm
CTBP93HE/4
4
16.0mm
CTBP93HE/5
5
19.8mm
CTBP93HE/6
6
23.7mm
CTBP93HE/7
7
27.5mm
CTBP93HE/8
8
31.3mm
CTBP93HE/9
9
35.1mm
CTBP93HE/10
10
38.9mm
CTBP93HE/11
11
42.7mm
CTBP93HE/12
12
46.5mm
CTBP93HE
9.2
7
7.2
TERMINAL STRIPS
PA R T N O .
3.4
081
3.81
1.2
PCB mounting male vertical connector (closed ended)
IP68 CONNECTORS
8.4mm
CTBP93VE/3
3
12.2mm
CTBP93VE/4
4
16.0mm
CTBP93VE/5
5
19.8mm
CTBP93VE/6
6
23.7mm
CTBP93VE/7
7
27.5mm
CTBP93VE/8
8
31.3mm
CTBP93VE/9
9
35.1mm
CTBP93VE/10
10
38.9mm
CTBP93VE/11
11
42.7mm
CTBP93VE/12
12
46.5mm
CTBP93VE
7
LENGTH
2
3.4
9.2
3.81
A S S O C I AT E D P R O D U C T S
CTB92HE, CTB92VE S and CTBP92VE R can be replaced with a screwless type terminal
block for a reduced assembly time.
page 78
CONNECT
CSTBP92HE
66
Vers 1
7.2
INTERFACE
MODULES AND
RELAY BASES
POLES
CTBP93VE/2
3
158
PA R T N O .
很抱歉,暂时无法提供与“CTBP92VE/4R”相匹配的价格&库存,您可以联系我们找货
