P C B T E R M I N A L B LO C KS
S TA N D A R D
PLUGGABLES
SCREWLESS
002
PCB TERMINAL
BLOCKS
081
TERMINAL STRIPS
5mm pitch pluggable rising clamp
terminal blocks
Product overview
095
WIRE TO BOARD
CONNECTORS
100
CIRCULAR
CONNECTORS
151
IP68 CONNECTORS
S P E C I F I C AT I O N
2-12 pole solid block
Professional rising clamp terminals
Moulded in green UL94-V0 flame retardant PA66
Cable acceptance - 0.32 to 1.6mm2 (28-14AWG) solid
and stranded cable
Pluggable male and female connectors
Open and closed headers
Horizontal and vertical female plug styles
Polarised mouldings
Anti solder wicking
Captive screws and guided pin alignment
approved
US ,
C
Rating
UL=15A/300V, VDE=20A/450V
Insulation resistance
500M Ω/500V
Withstand voltage
AC2000V/1min
Contact resistance
20mΩ (max)
Working temperature
-40°C to +105°C
Moulding
Pin/terminal
Tin plated brass
Rising clamp
Brass, nickel plated
Screw/torque
M3 steel, zinc plated 0.5Nm
Recommended PCB hole size
ø1.7mm
Female connector
LENGTH
2
10mm
CTBP9200/3
3
15mm
CTBP9200/4
4
20mm
CTBP9200/5
5
25mm
CTBP9200/6
6
30mm
CTBP9200/7
7
35mm
CTBP9200/8
8
40mm
CTBP9200/9
9
45mm
CTBP9200/10
10
50mm
CTBP9200/11
11
55mm
CTBP9200/12
12
60mm
CTBP9200
18.1
POLES
CTBP9200/2
8.3
INTERFACE
MODULES AND
RELAY BASES
PA R T N O .
5
15.05
158
Female vertical connector (standard)
LENGTH
2
10mm
CTBP92VG/3S
3
15mm
CTBP92VG/4S
4
20mm
CTBP92VG/5S
5
25mm
CTBP92VG/6S
6
30mm
CTBP92VG/7S
7
35mm
CTBP92VG/8S
8
40mm
CTBP92VG/9S
9
45mm
CTBP92VG/10S
10
50mm
CTBP92VG/11S
11
55mm
CTBP92VG/12S
12
60mm
CTBP92VG S
5
12.6
26
POLES
CTBP92VG/2S
8.3
PA R T N O .
62
POLES
LENGTH
CTBP92VG/2R
2
10mm
CTBP92VG/3R
3
15mm
CTBP92VG/4R
4
20mm
CTBP92VG/5R
5
25mm
CTBP92VG/6R
6
30mm
CTBP92VG/7R
7
35mm
CTBP92VG/8R
8
40mm
CTBP92VG/9R
9
45mm
CTBP92VG/10R
10
50mm
CTBP92VG/11R
11
55mm
CTBP92VG/12R
12
60mm
CTBP92VG R
+44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com
We operate a constant improvement policy, our products are subject to change without notice.
Vers 1
12.6
5
26
PA R T N O .
8.3
CONNECT
Female connector (reversed)
SCREWLESS
PLUGGABLES
S TA N D A R D
002
PCB TERMINAL
BLOCKS
PCB mounting male vertical connector (closed ended)
LENGTH
2
11.4mm
CTBP9300/3
3
16.4mm
CTBP9300/4
4
21.4mm
CTBP9300/5
5
26.4mm
CTBP9300/6
6
31.4mm
CTBP9300/7
7
36.4mm
CTBP9300/8
8
41.4mm
CTBP9300/9
9
46.4mm
CTBP9300/10
10
51.4mm
CTBP9300/11
11
56.4mm
CTBP9300/12
12
61.4mm
CTBP9300
7.8
5
4
POLES
CTBP9300/2
8.5
100
CIRCULAR
CONNECTORS
151
11.4mm
CTBP9350/3
3
16.4mm
CTBP9350/4
4
21.4mm
CTBP9350/5
5
26.4mm
CTBP9350/6
6
31.4mm
CTBP9350/7
7
36.4mm
CTBP9350/8
8
41.4mm
CTBP9350/9
9
46.4mm
CTBP9350/10
10
51.4mm
CTBP9350/11
11
56.4mm
CTBP9350/12
12
61.4mm
CTBP9350
4
7.8
12
LENGTH
2
IP68 CONNECTORS
2
POLES
CTBP9350/2
095
WIRE TO BOARD
CONNECTORS
PCB mounting male horizontal connector (closed ended)
PA R T N O .
081
TERMINAL STRIPS
3.9
1
12
PA R T N O .
158
INTERFACE
MODULES AND
RELAY BASES
8.5
5
1
POLES
LENGTH
CTBP9300/2AO
2
10mm
CTBP9300/3AO
3
15mm
CTBP9300/4AO
4
20mm
CTBP9300/5AO
5
25mm
CTBP9300/6AO
6
30mm
CTBP9300/7AO
7
35mm
CTBP9300/8AO
8
40mm
CTBP9300/9AO
9
45mm
CTBP9300/10AO
10
50mm
CTBP9300/11AO
11
55mm
CTBP9300/12AO
12
60mm
7.8
3.9
CTBP9300 AO
5
1
12
PA R T N O .
4
PCB mounting male vertical connector (open ended)
8.5
PCB mounting male horizontal connector (open ended)
10mm
CTBP9350/3AO
3
15mm
CTBP9350/4AO
4
20mm
CTBP9350/5AO
5
25mm
CTBP9350/6AO
6
30mm
CTBP9350/7AO
7
35mm
CTBP9350/8AO
8
40mm
CTBP9350/9AO
9
45mm
CTBP9350/10AO
10
50mm
CTBP9350/11AO
11
55mm
CTBP9350/12AO
12
60mm
CTBP9350 AO
4
7.8
8.5
5
1
CONNECT
LENGTH
2
12
POLES
CTBP9350/2AO
2
PA R T N O .
Vers 1
63
很抱歉,暂时无法提供与“CTBP9350/9”相匹配的价格&库存,您可以联系我们找货
