SCREWLESS
PLUGGABLES
S TA N D A R D
P C B T E R M I N A L B LO C KS
002
5.08mm DIN rail mounted inverted/
reverse terminal blocks
Product overview
PCB TERMINAL
BLOCKS
081
TERMINAL STRIPS
S P E C I F I C AT I O N
Horizontal orientations
Polarized moldings
Can be reversed on DIN clips
Also available in 5.08mm pitch
Molded in green UL94-V0 flame retardant PA 66
2.5mm2 (28-14AWG)
approved
US ,
C
6-12 poles standard (13-24 also available)
Rating
UL=15A/300V IEC 20A/450V
Insulation resistance
500MΩ/500V
Withstand Voltage
AC2000V/1min
Contact Resistance
20mΩ (max)
Working Temperature
-40°C to 105+°C
Mouldings
UL94-V0 Flame retardant PA66
Pin/Terminal
Brass, Tin plated
Rising Clamp
Brass, nickel plated
Screw/Torque
M3 Steel, zinc plated 0.5Nm
095
WIRE TO BOARD
CONNECTORS
100
CIRCULAR
CONNECTORS
151
IP68 CONNECTORS
DIN rail mounting male vertical
POLES
LENGTH
CTBPD96VJ/6
6
32.0mm
CTBPD96VJ/7
7
37.1mm
CTBPD96VJ/8
8
42.2mm
CTBPD96VJ/9
9
47.2mm
CTBPD96VJ/10
10
52.3mm
CTBPD96VJ/11
11
57.4mm
CTBPD96VJ/12
12
62.5mm
CTBPD96VJ
20.6
32
5.08
158
17.3
17.3
INTERFACE
MODULES AND
RELAY BASES
33.9
16.5
11.6
3.6
PA R T N O .
42.5
11.6
20.6
DIN rail mounting male vertical flanged
LENGTH B
41.8mm
CTBPD96VJ/7FL
7
37.1mm
46.9mm
CTBPD96VJ/8FL
8
42.2mm
52.0mm
CTBPD96VJ/9FL
9
47.2mm
57.0mm
CTBPD96VJ/10FL
10
52.3mm
62.1mm
CTBPD96VJ/11FL
11
57.4mm
67.2mm
CTBPD96VJ/12FL
12
62.5mm
72.3mm
CTBPD96VJ/FL
Length B
Length A
20.6
17.3
33.9
LENGTH A
32.0mm
21.5
12.3
11.6
3.6
POLES
6
5.08
PA R T N O .
CTBPD96VJ/6FL
42.5
11.6
20.6
DIN rail mounting male horizontal
LENGTH
CTBPD96HJ/6
6
32.0mm
CTBPD96HJ/7
7
37.1mm
CTBPD96HJ/8
8
42.2mm
CTBPD96HJ/9
9
47.2mm
CTBPD96HJ/10
10
52.3mm
CTBPD96HJ/11
11
57.4mm
CTBPD96HJ/12
12
62.5mm
CTBPD96HJ/FL
19.2
31.8
5.08
1
20.2
12.3
11.6 8.5 11.6
42.5
CONNECT
POLES
20.5
32.6
PA R T N O .
19.2
+44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com
We operate a constant improvement policy, our products are subject to change without notice.
Vers 1
69
很抱歉,暂时无法提供与“CTBPD96VJ/12”相匹配的价格&库存,您可以联系我们找货
