TERMINAL STRIPS
002
PCB
TERMINAL
DIECAST
BLOCKS
ACCESSORIES
12 way nylon terminal strips
081
TERMINAL STRIPS
Product overview
095
WIRE TO BOARD
CONNECTORS
100
CIRCULAR
CONNECTORS
151
IP68 CONNECTORS
S P E C I F I C AT I O N
• Moulded from: Voltage
Natural PA6 (standard, CTSN400)
Working temperature
Cream PA66 (CTSN500)
Grey PA66 glass fibre (CTSN600)
• Available with or without wire protection
Moulding
• Passes 960°C glow-wire test according to EN
60695-2-11
Standard insert
• Printing available on request
Terminal screws
• Easily cut to size
Wire protectors
• Supplied cut to length on request
• Closed inserts (middle barrier) option
CTSN400
• Captive terminal screws
• C
approved
US ,
CTSN431-433
CTSN434-438
450VAC
750VAC (UL600VAC)
CTSN400
CTSN500
CTSN600
-30°C to +110°C
-30°C to +110°C
-30°C to +160°C
CTSN400
CTSN500
CTSN600
UL94-V2 PA6
UL94-V0 PA66
UL94-V0 PA66 + GF
Nickel-plated brass
Zinc-plated steel CQ-15
Stainless steel
CTSN500 raised base
Part Numbers shown are for standard PA6
material (e.g. CTSN433/12)
158
INTERFACE
MODULES AND
RELAY BASES
For CSTN500 PA66 material change first
number to 5 (e.g. CTSN533/12)
For CSTN600 PA66+GF material change first
number to 6 (e.g. CTSN633/12)
Standard type
PA R T N O .
WIRE
PROTECTION
INSERT
DIAMETER
CABLE
A C C E P TA N C E
TERMINAL
SCREWS
LENGTH
W I DT H
HEIGHT
PITCH
FIXING
HOLE
DIAMETER
MAX
CURRENT
UL
R AT I N G
CTSN431/12W
No
3.2mm
4.0mm2/12AWG
M3
94mm
18mm
15mm
8mm
2.8mm
32A
20A
CTSN431/12
Yes
3.2mm
2.5mm2/14AWG
M3
94mm
18mm
15mm
8mm
2.8mm
24A
15A
CTSN433/12W
No
3.5mm
2
M3
116mm
21mm
16mm
10mm
2.8mm
41A
30A
2
6.0mm /10AWG
CTSN433/12
Yes
3.5mm
4.0mm /12AWG
M3
116mm
21mm
16mm
10mm
2.8mm
32A
20A
CTSN434/12W
No
4.4mm
10.0mm2/8AWG
M3.5
140mm
23mm
18mm
12mm
2.8mm
57A
50A
2
CTSN434/12
Yes
4.4mm
6.0mm /10AWG
M3.5
140mm
23mm
18mm
12mm
2.8mm
41A
30A
CTSN435/12W
No
6.0mm
16.0mm2/6AWG
M4
159mm
26mm
22.5mm
14mm
N/A
76A
65A
CTSN435/12
Yes
6.0mm
2
M4
159mm
26mm
22.5mm
14mm
N/A
57A
65A
M5
177mm
31mm
27.5mm
15mm
N/A
125A
85A
CTSN438/12W
No
7.5mm
10.0mm /8AWG
2
35mm /2AWG
Standard type, no wire protection
L
W
P
CONNECT
H
96
+44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com
We operate a constant improvement policy, our products are subject to change without notice.
Vers
Vers 2
1
FM 28614
EMS 613558 Vers
2
TERMINAL STRIPS
002
PCB TERMINAL
DIECAST
DIECAST
BLOCKS
ACCESSORIES
ACCESSORIES
Raised base
PITCH
MAX
CURRENT
UL
R AT I N G
17mm
8mm
2.8mm
32A
20A
18mm
17mm
8mm
2.8mm
24A
20A
21mm
17.5mm
10mm
2.8mm
41A
30A
PA R T N O .
INSERT
DIAMETER
CABLE
A C C E P TA N C E
TERMINAL
SCREWS
LENGTH
W I DT H
HEIGHT
CTSN431/12WR
No
3.2mm
4.0mm2/12AWG
M3
94mm
18mm
CTSN431/12R
Yes
3.2mm
2.5mm2/14AWG
M3
94mm
CTSN433/12WR
No
3.5mm
6.0mm2/10AWG
M3
116mm
2
081
FIXING
HOLE
DIAMETER
WIRE
PROTECTION
CTSN433/12R
Yes
3.5mm
4.0mm /12AWG
M3
116mm
21mm
17.5mm
10mm
2.8mm
32A
30A
CTSN434/12WR
No
4.4mm
10.0mm2/8AWG
M3.5
140mm
23mm
20mm
12mm
2.8mm
57A
50A
CTSN434/12R
Yes
4.4mm
6.0mm /10AWG
M3.5
140mm
23mm
20mm
12mm
2.8mm
41A
50A
CTSN435/12WR
No
6.0mm
16.0mm2/6AWG
M4
159mm
26mm
26mm
14mm
3.6mm
76A
65A
CTSN435/12R
Yes
6.0mm
10.0mm2/8AWG
M4
159mm
26mm
26mm
14mm
3.6mm
57A
65A
2
TERMINAL STRIPS
095
WIRE TO BOARD
CONNECTORS
100
CIRCULAR
CONNECTORS
118
IP68 CONNECTORS
Raised base types - provides increased isolation
L
W
158
P
INTERFACE
MODULES AND
RELAY BASES
H
3
K E Y F E AT U R E S
| V0 types meet 960°C GWT
CONNECT
V2 or V0 material | Easily cut to required size
FM 28614
EMS 613558
Vers
2.31
Vers
97
TERMINAL STRIPS
002
PCB
TERMINAL
DIECAST
BLOCKS
ACCESSORIES
Pluggable terminal strips
081
TERMINAL STRIPS
Product overview
151
IP68 CONNECTORS
158
INTERFACE
MODULES AND
RELAY BASES
450V AC
Working temperature
-30°C to +110°C (PA6.6 to +150°C)
Moulding
UL94-V2 self extinguishing PA6
Conducting bush
Nickel-plated brass
Terminal screws
Zinc-plated steel
Standard type
PA R T N O .
PITCH/ UL
R AT I N G
INSERT
DIAMETER
CABLE
A C C E P TA N C E
TERMINAL
SCREWS
LENGTH
W I DT H
HEIGHT
PITCH
FIXING
HOLE
DIAMETER
MAX
CURRENT
CTSN431/12MF
8mm/6A
2.9mm
4.0mm2/12AWG
M3
94mm
16mm
15.5mm
8mm
2.75mm
17.5A
CTSN433/12MF
10.25mm/10A
3.4mm
2.5mm2/14AWG
M3
119.4mm
20.5mm
16.4mm
10.25mm
3.2mm
24A
CTSN434/12MF
12.5mm/16A
4.3mm
6.0mm2/10AWG
M3.5
143mm
23.5mm
19mm
12.3mm
3.5mm
57A
16
94
10.2
20.5
143
20.5
23.5
Ø5
Ø3.2
CTSN433/12MF
CTSN431/12MF
20.5
10.2
8
3.4
16.4
2.85
3
15.5
Ø2.75
20.5
119.4
16
8
3.2
CIRCULAR
CONNECTORS
Voltage (max
4.3
100
• Moulded in natural PA6, self
extinguishing to UL94-V2
according to EN 60695-2-11
approved
3.2
WIRE TO BOARD
CONNECTORS
19
095
CTSN MF
CTSN434/12MF
Strain relief
Product overview
CSR
CONNECT
• Clamps external conductors in
lighting fixtures according to
EN60598
• Natural colour PA6
• Relieves strain on cables
• Prevents conductors from twisting
• Protects wire coating from abrasion
and friction
98
L
H
PA R T N O .
TERMINAL STRIP
LENGTH
W I DT H
HEIGHT
CSR1
CTSN431
49.5mm
31mm
22.5mm
CSR2
CTSN433
52.5mm
31mm
22.5mm
CSR3
CTSN434
54.5mm
31mm
22.5mm
W
P
P
Pluggable style
| V0 to GWT 960°C
Vers 1
FM 28614
EMS 613558 Vers
2
很抱歉,暂时无法提供与“CTSN431/12R”相匹配的价格&库存,您可以联系我们找货
