CTSOS431/12BK
CTSOS431/12BK
    CAMDENBOSS
CTSOS431/12BK 数据手册
TERMINAL STRIPS 002 PCB TERMINAL DIECAST DIECAST BLOCKS ACCESSORIES ACCESSORIES Easy break terminal strips 081 TERMINAL STRIPS Product overview CTSOS S P E C I F I C AT I O N • Easily snapped to required numbered of poles • No remaining burrs • No tools required • Supplied with screws in raised position • 12 poles as standard • Halogen free • Passes 960°C glow-wire test according to EN 60695-2-11 • Moulded in natural UL94-V2 self extinguishing PA6 • Black available on request (MOQ may apply) • approved Rating 450VAC Glow wire test (EN 606 95-2-11) 960°C Working temperature -30°C to +110°C Moulding UL94-V2 self extinguishing PA6 Materials: Insert crew Nickel plated brass Zinc plated steel 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 118 IP68 CONNECTORS 158 INTERFACE MODULES AND RELAY BASES PA R T N O . CONNECTING CAPACITY MIN CONDUCTOR SECTION TERMINAL SCREWS LENGTH W I DT H HEIGHT PITCH MAX CURRENT CTSOS431/12 2.5mm2 1mm2 M3 95.5mm 17.5mm 14.75mm 8mm 24A CTSOS433/12 6mm2 2.5mm2 M3 118mm 19mm 15.6mm 10mm 41A CTSOS434/12 10mm2 4mm2 M3.5 142mm 20.8mm 18.2mm 12mm 57A CTSOS435/12 16mm2 6mm2 M4 160mm 23mm 21.2mm 13.5mm 76A CTSOS438/12 35mm2 16mm2 M5 176.5mm 25.5mm 28mm 15mm 125A K E Y F E AT U R E S | Easily snapped to required size CONNECT Five size options +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. FM 28614 EMS 613558 Vers Vers21 89
CTSOS431/12BK 价格&库存
很抱歉,暂时无法提供与“CTSOS431/12BK”相匹配的价格&库存,您可以联系我们找货
