BIM6006-GY/PG
BIM6006-GY/PG
    CAMDENBOSS
BIM6006-GY/PG 数据手册
DESKTOP & INSTRUMENT CASES 6000 Series Venti Cases universal Enclosures ABS desk cases available with inclined recessed aluminium front panels. • Moulded in high impact ABS • Aluminium lid mounted by 4x M3 screws • Polished finish for ease of cleaning • PCB pillars in base • Integral PCB slots in front and rear walls • Ventilation slots in base Specification Materials Base high impact ABS as standard, UL94-V0 ABS to order Panels 1mm thick aluminium Operating temperature Resistant to temperatures up to 85°C Base grey & black as standard, white to order Standard colours Aluminium panel grey Standard unit includes Base & aluminium panel 4x M3 machine screws 4x rubber feet Black BIM6005-BLK/PG BIM6006-BLK/PG BIM6007-BLK/PG Grey BIM6005-GY/PG BIM6006-GY/PG BIM6007-GY/PG Length 143mm 143mm 214mm width 105mm 170mm 170mm Height 55mm 55mm 82mm HAND HELD CASES HEAVY DUTY ENCLOSURES DIN RAIL BOXES H INTERFACE SUPPORTS CONTROL STATIONS L W diecast & metal boxes 2600/2700 Series Terminal Cases Ideal enclosures for laboratory equipment, keyboard, access & security applications. • 2 part aluminium construction • Easy assembly with 4x M3 screws running through rubber feet into base • 4x rubber feet supplied as standard desktop & instrument cases Specification Material Protection class Standard colours Standard unit includes Type No. RTM2601-BR/B RTM2602-BR/B RTM2603-BR/B RTM2604-BR/B RTM2701-BR/B RTM2702/BR/B RTM2703-BR/B RTM2704-BR/B Base 2mm thick aluminium Lid 1.6mm thick aluminium IP40 Top beige as standard Base brown as standard Other colours available to order Lid & base 4x M3 machine screws 4x rubber feet Length 210mm 210mm 210mm 210mm 210mm 210mm 210mm 210mm width 178mm 280mm 381mm 483mm 178mm 280mm 381mm 483mm Potting Boxes 19" ENCLOSURES Height 55mm 55mm 55mm 55mm 80mm 106mm 106mm 106mm 19'' CABINETS DEVELOPMENT BOARDS H custom sized enclosures Custom Services W L +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. 70 Ver 1.0 Iss 1 ELEC T RON IC S & ENC LOSURES
BIM6006-GY/PG 价格&库存
很抱歉,暂时无法提供与“BIM6006-GY/PG”相匹配的价格&库存,您可以联系我们找货
